    Dec 2003
    Montreal / Canada
    Hi,
    I just edit a vacation movie, and burned it on a DVD. After everything was done, I noticed an error in the name of the City in my intro.
    I was using Adobe Premiere Elements for the editing. Now if I want to correct this, I have to find a way to send back to my HD my movie, so I can make the corrections.
    How do I do that ? How to transfer my movie on a DVD back to an AVI format ?
    George
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    better to use your original source files -
    a lot better
    but otherwise there is a ton of guides here on how to extract dvd to a avi file for editing
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If at all avoidable, you shouldn't go back to AVI and then mpg again at all, since that would be two more reencodings, ruining the overall video quality.
    To get the DVD back to HDD, rip with DVDDecrypter.
    /Mats
    Dec 2003
    Montreal / Canada
    Thanks for your e-mail.
    After burning the final DVD, I erased the sources files. It would have been very easy to fix the spelling error in the intro section.
    Now I have to transfer DVD to AVI, and I do not know how to do it ...
    George
    Dec 2003
    Montreal / Canada
    /Mats
    Thanks Mats for your infos.
    I do have DVD decrypter. Could you give me the steps to follow ?
    George
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    or vob2mpg(no video conversion) and reauthor with premiere elements....if it supports authoring from mpg files.
    or other methods: https://www.videohelp.com/guides.php?guideid=638#638
