I have a Panasonic DVD recorder and also a PC with a drive that supports DVD-RAM. I regularly transfer video from the DVD recorder to the PC. This is easy because when I put the DVD-RAM disk into the PC the files can be read with Windows Explorer with no problems.
What I'd also like to be able to do however is to transfer data the other way. So I'd like to be able to burn a video file onto the DVD-RAM disk on the PC and have it readable by the DVD recorder. I haven't so far been able to achieve this. The DVD drive on the PC came with Nero software for burning video, and I can use that to write data to the disk, but I have been unable to find a way to write the disk in a way that the DVD recorder can read. All methods I have tried so far just show the disk as unreadable when I put it into the DVD recorder.
Has anyone got any suggestions?
I'd forget about the RAM media for that.
I'd use -RW media - burn it just like a regular DVD;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I know it sounds ridiculous but the Pan doesn't work with RW. I realised this might be a problem when I bought it but it had a 400GB HDD which at the time was easily the biggest available so it was a choice and I came down on the side of the bigger HDD.
Well , I dont have a ram disc laying about , but ulead videostudio 9 can write to dvd-ram ... whether it would work is another thing in the other unit would need testing .
Tfr file from PC to DVD Recorder via RAM disk
By barry_w2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2010, 10:47 -
Complete novice, transfer DVD-RAM video to PC
By Mount1003 in forum Newbie / General discussionsReplies: 18Last Post: 30th Dec 2009, 19:57 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 14:01 -
DVD Recorder hard disk to PC
By aqctv in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st Jan 2008, 17:36 -
Burning to DVD RAM DISK and then play on your TV
By pmorris1 in forum Newbie / General discussionsReplies: 5Last Post: 25th Dec 2007, 19:15
