With the release of the 5th Generation IPOD which has the capability to playback video, many owners have been disappointed to find that under the best conditions, video playback on a fully charged battery is limited to between 2 and 4 hours. While there are many external battery extenders available for the IPOD, I was unable to find one that allows you to attach the battery pack to the IPOD while keeping the device in it's case. While I wanted function, I also wanted form. Below is my solution for the time being using off the shelf products with a minimal amount of time to make the modification work and still retain a clean look. The backup pack can be removed and attached in a matter of seconds. Tests so far using NI-MH 2200mAh 1.25 AA batteries have shown 7 hours video playback time and 20 hours radio/music playback. It is also important to note that the Belkin Battery Pack does not charge the IPODs internal battery. During playback the external pack is used first and then the IPODs battery second after the external pack is depleted. The Belkin backup battery pack has a series of four green LEDs and a test button to show approximate remaining battery time. I hope this will give some IPOD owners a solution and maybe some the opportunity to improve on the idea. B. Hall
Results 1 to 12 of 12
For some reason I cannot load all the pics in one shot so I will do it this way.
All you have to do is put the image tags in the original post and just keep hitting the "Edit" button over and over and keep uploading each photo to get them all in the same postOriginally Posted by jdizzy40
Me thinks you are just trying to raise your post count!!!! you PW!!!!!!!
And scott was just having a good ol' time hacking me about doing an upload with the link :P
But that is cool!!! something i might come up with.... if i ever planned on buying an Ipod
I personally don't have a need for one for music let alone trying to squint my old ass eye's trying to watch a WS movie on a 1.5" screen
Look's cool though!!!
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 00:04 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
any Ipod experts? way to restore lost music on Ipod
By scustalow in forum Portable VideoReplies: 2Last Post: 9th Jul 2008, 00:56 -
IPod nano with video and IPod touch
By SingSing in forum Latest Video NewsReplies: 0Last Post: 6th Sep 2007, 10:11 -
Videora iPod Converter (DVD to IPOD)
By Denman007 in forum DVD RippingReplies: 0Last Post: 15th Aug 2007, 19:06
