I have captured a tape from my camera to the computer and I ended up with 17GB for one tape. Now I want to transform this 17GB into 4.7,the capacity of a DVD. How can I do that? What software should I use.
Thank you in advance
Results 1 to 9 of 9
I use TMPGnc, there are others. Have a look in "tools' on the left side of the page.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Hi alintatoc,
I, too, use TMPGEnc Plus. Other encoders to MPG2 (that's the file format you need to end up with) that are highly regarded are (in no particular order):
MainConcept MPEG Encoder
Cinemacraft Encoder
Canopus Procoder
People tend to go for TMPGEnc because it's cheaper and produces excellent results. The downside is that it's slower than the others. I leave mine running overnight.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thank you very very much guys! I will try one of those and I will see the best result.
Have a nice day! -
Just to make one thing clear, the capacity of a DVD is 4.37 GB.Originally Posted by alintatoc
[quote="cd090580"]Probably because DivxToDVD is not designed to handle DV files (as its name say)[/quote
I have captured the movie from my camcorder and I has 17Gb and I want to make it smaller,the size of a DVD. Which software can do that.
The movie is DV and I want to make it smaller.
