Results 1 to 9 of 9
  1. I have captured a tape from my camera to the computer and I ended up with 17GB for one tape. Now I want to transform this 17GB into 4.7,the capacity of a DVD. How can I do that? What software should I use.
    Thank you in advance
  2. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    I use TMPGnc, there are others. Have a look in "tools' on the left side of the page.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi alintatoc,
    I, too, use TMPGEnc Plus. Other encoders to MPG2 (that's the file format you need to end up with) that are highly regarded are (in no particular order):
    MainConcept MPEG Encoder
    Cinemacraft Encoder
    Canopus Procoder
    People tend to go for TMPGEnc because it's cheaper and produces excellent results. The downside is that it's slower than the others. I leave mine running overnight.
    Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. Thank you very very much guys! I will try one of those and I will see the best result.
    Have a nice day!
  5. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Originally Posted by alintatoc
    ...4.7,the capacity of a DVD...
    Just to make one thing clear, the capacity of a DVD is 4.37 GB.
  6. I've tried to convert the 17GB movie with DIVXtoDVD and it converted only a part of the movie, not the whole movie.
    Does anybody know why?
  7. Probably because DivxToDVD is not designed to handle DV files (as its name say)
  8. [quote="cd090580"]Probably because DivxToDVD is not designed to handle DV files (as its name say)[/quote
    I have captured the movie from my camcorder and I has 17Gb and I want to make it smaller,the size of a DVD. Which software can do that.
    The movie is DV and I want to make it smaller.
  9. Use TmpgEnc to encode your dv to DVD
