    Feb 2005
    EARTH
    hello!
    is it possible to convert wmv files that have digital media licence in another format?
    thank you
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes.
    If in doubt, Google it.
    Feb 2005
    EARTH
    thanks!
    which tool and file format should I choose for best quality results ?
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Yes...do tell. Last I heard this could not be done.
    Google is your Friend
  5. He cant..
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by canadateck
    He cant..
    exactly
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Well .... a mod has looked at this thread and it is still open, so one can only assume that it is OK. Soooooo ....
    http://members.dodo.net.au/~jimmalenko/drm2wmv.zip should help you out
