I want to be able to make certain DVDs family friendly by deleting sound bits where swearing appears, and deleting either the video, or simply a short chunk of the movie during nude scenes. I then want to be able to burn the finished product to DVD-R. Preferably, I would edit the .VOB files directly, while keeping all the original extras on the DVD. What is the easiest way to do this (using any software available)?
https://www.videohelp.com/forum/viewtopic.php?t=266232
keeping extras would require tons of work.
bleeping swearing would also require lots of work...easiest is just to cut it. -
This might help with the swearing:
https://www.videohelp.com/forum/viewtopic.php?p=706711#706711If in doubt, Google it. -
Thanks for the replies. I am familiar with various sound editing programs, but what my lazy self is hoping for is something where I can simply import the .VOB files and it will take care of the rest automatically - all I want to have to do is select the parts I want cut and hit cut. Software accessibility is not a problem. Do you know of any software that will do it that simply?
Copying DVDs to bluray
By Raffaz in forum Authoring (Blu-ray)Replies: 8Last Post: 26th Feb 2012, 01:54 -
copying to dvds
By kopkid in forum MacReplies: 3Last Post: 17th Feb 2009, 10:49 -
Help with copying DVDs. Thanks very much.
By seymoria in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jan 2009, 13:06 -
Jerky video and chopped sound when playing DVDs
By Willietom in forum Newbie / General discussionsReplies: 7Last Post: 11th Jul 2008, 08:26 -
Problem Copying DVDs
By poppy56 in forum DVD RippingReplies: 2Last Post: 8th Jan 2008, 18:54
