  1. Hi,
    I'm looking for dvd ripping software that can rip specific segments off DVDs rather than whole chapters. Right now I am using SmartRipper and then taking out the scenes I need with DVD2AVI, but it would be so much faster if I could just rip the specific scenes to begin with. Is there anything out there that can do this?
    Thanks,
    Kristin
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yes, dvdshrink can. Here's a snapshot of how to do it. I used the film UHF as the test object. You can select as short of a clip as you want without being forced to use the actual chapter.
    You open the disc. Choose reauthor mode. Select the main movie. Then click the start/end button to choose which scene you want to copy.
    Kevin
