what is the best way to store dvd-r's after you burn them? i have been putting them in my slimline cd cases but someone here said that was a bad idea...
thanks!
Results 1 to 11 of 11
Did they say why that was a bad idea? That is what I always do.
Hello. -
I think thats a silly question.I say just store them in the same safe way that you've been storeing your CD-Rs and offical DVDs and everything should be fineOriginally Posted by allen074
With all due respect Star Warrior, the silly questions are the ones not asked.
Hello. -
im just new at dvd recording and want to make sure that the dvds work in a yr or two or 20...
thanks -
I've been storing my DVD-R data discs in nylon sleeves (two discs per) and putting groups of thoses in plastic baggies. I then store these groups of baggies in a plastic container. I do this for space (I've created over 50 DVD-R data discs so far) and to protect the discs. I'm probably over doing this but the process works for me.
Most important for longer term storage: (like CD's) store them in a closed box away from light and heat;
for very important things I always store on 2 DVD's, each of a different brand, for example Maxell and Fuji
PS: there are no stupid questions, only ..... answers -
The valuable part of the discs, the one you have to protect at any cost, is the top side. Never scratch , never heat , never mark with any ink on the top side. Don't even touch with dirty fingers if possible!
... and above all else, do not, under any circumstance, microwave the buggers !
Best format to store DVD's on a hard drive
By robrpb in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2010, 22:46 -
Looking for the Best Way to Backup DVD Movies and store on Computer HD
By jet757f in forum DVD RippingReplies: 2Last Post: 31st Aug 2010, 21:39 -
What Happens To Faulty CD/DVD's After You Return Them To The Store?
By Nitro89 in forum Off topicReplies: 1Last Post: 1st Nov 2009, 15:44 -
Store photos on a dvd
By smalld in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 15:43 -
Trying to rip scenes from a store bought DVD...no dice
By Huntr777 in forum MacReplies: 2Last Post: 4th Nov 2007, 08:14
