always getting green blocks in vcd and svcd release, any idea why?
if you need further information to help me with that ask and i'll say them, all my movies are 90% green blocks and the sound is glitching and the file ain't corrupted
Try to figure out exactly what stage in the process it is going wrong.
1) If these are CD's someone else made, do they play on another machine?
2) If you made these CD's are you able to play the mpgs on your computer before you burn the CD's?
3) If the mpgs play before you burn the CD, what program are you using to burn and what settings? -
all the vcd and svcd movie release you can find on the net (before and after burning) don't work and I assume they play well on other computer or else they wouldn't release these anymore
Blocks in dark areas
By santosx in forum Video ConversionReplies: 22Last Post: 12th Oct 2010, 19:54 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 12:48 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 02:53 -
blocks in dvd?
By wingfan in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2008, 11:25 -
Did I release a virus on my PC?
By mn072065 in forum ComputerReplies: 11Last Post: 18th Aug 2008, 18:33
