  1. Anonymous
    Guest
    Hello Friends.
    I have a DVD with my you tube collection
    which consists of 22 multi session burns.
    Now I want to make its IMAGE, for that I used:
    ALCOHOL 52%
    POWER-ISO
    MAGIC DISC
    STAR BURN
    And I made Images like ISO, UIF, BIN/CUE, MDF, NRG.
    Now the problem is when i try to mount the image file(any of the above mentioned)
    containing 22 Multi Session image files
    only the 1st one runs properly, rest of them gives error.
    The DVD is totally fine no scratches.
    I can't make whole DVD image, it takes too too much time.
    Now please suggest me which software should I use
    and which Image Extension should I use.
    Thnkx.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just take those 22 pieces....copy them to a folder on your desktop and start over again. What is so hard about that?
    Jun 2004
    Victoria, Australia
    ImgBurn - Build mode - select all files on source disk - output to new ISO file - click START
  4. Anonymous
    Guest
    Excellent hech54....
    Why I didn't thought of that...
    I should have done that, but why to do double work...
    plz give me a better (feasible) solution...
    Thnkx.
    Aug 2005
    Palo Alto, California USA
    Given how much time you've already spent, it would seem that hech54's suggestion is eminently feasible and practical. Not sure what you're looking for, but there's no "instant" solution. But copying from DVD to hard drive is a reasonably fast operation, and building the image from the hard drive pieces should also be quite fast. I don't know why you're seeking an alternative, so I guess I'm not fully understanding what you are trying to do. Could you please explain a bit more about your goals and constraints?
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Thnkx.
    You would be done by now. What part of that don't you understand?
    Feb 2004
    Australia
    A is : Nero > continue multisession
    B is : Nero > Import and finalize disc ... done.
  8. Anonymous
    Guest
    only thing is want to know that copying the contents of the DVD
    is an obvious solution, but making its image is not.
    I questioned how to make a better (Multi-session DVD) Image.
    Now it can be done by other means as per "tomlee59" and "hech54"
    suggested. But I was waiting for the answer related to what I asked.
    Anyways...
    The problem has been solved..
    Other Softwares that I used were not up-to the mark.
    I used IMGBURN..
    So, thnkx TJohns
