Hello Friends.
I have a DVD with my you tube collection
which consists of 22 multi session burns.
Now I want to make its IMAGE, for that I used:
ALCOHOL 52%
POWER-ISO
MAGIC DISC
STAR BURN
And I made Images like ISO, UIF, BIN/CUE, MDF, NRG.
Now the problem is when i try to mount the image file(any of the above mentioned)
containing 22 Multi Session image files
only the 1st one runs properly, rest of them gives error.
The DVD is totally fine no scratches.
I can't make whole DVD image, it takes too too much time.![]()
Now please suggest me which software should I use
and which Image Extension should I use.![]()
Thnkx.
AnonymousGuest
Just take those 22 pieces....copy them to a folder on your desktop and start over again. What is so hard about that?
AnonymousGuest
Excellent hech54....
Why I didn't thought of that...
I should have done that, but why to do double work...
plz give me a better (feasible) solution...
Thnkx. -
Given how much time you've already spent, it would seem that hech54's suggestion is eminently feasible and practical. Not sure what you're looking for, but there's no "instant" solution. But copying from DVD to hard drive is a reasonably fast operation, and building the image from the hard drive pieces should also be quite fast. I don't know why you're seeking an alternative, so I guess I'm not fully understanding what you are trying to do. Could you please explain a bit more about your goals and constraints?
You would be done by now. What part of that don't you understand?Originally Posted by Anurag
AnonymousGuest
only thing is want to know that copying the contents of the DVD
is an obvious solution, but making its image is not.
I questioned how to make a better (Multi-session DVD) Image.
Now it can be done by other means as per "tomlee59" and "hech54"
suggested. But I was waiting for the answer related to what I asked.
Anyways...
The problem has been solved..
Other Softwares that I used were not up-to the mark.
I used IMGBURN..
So, thnkx TJohns
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Vdubmod "Source image format incorrect" when cropping with filter
By Gruelius in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 19:37 -
How to create a crystal clear image in "infinite white" space
By RevolutionOfTheMind in forum Newbie / General discussionsReplies: 9Last Post: 25th Oct 2008, 17:14 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08
