Results 1 to 17 of 17
    Jul 2017
    Los Angeles
    Hello. I’m sure this has been discussed before, and I noticed some threads here. But, none seem to be recent (within the past year or so).
    I have a VidBox, and as far as I know, I have the latest software for it. I’m running this with a 2020 MBP (dual-core 2GHz i5s, 16GB pf RAM).
    Over the past year and a half to two years, I notice periodic / occasional "hiccups" in the playback. Basically, the audio continues along unaffected, but for a second or so, the video will actually stop. One second later, it will resume, but not where it left off (which is good because then it would be out of sync with the audio), but rather the video resumes about where it would have been had it never been interrupted. (I can upload a file that demonstrates this problem, if anyone needs to see it.)
    The VidBox is connected to a TB3 port, via a TB3 / USB adaptor (type A USB? whichever is the wide, rectangular species of USB).
    My question is: Is there a way to get a better result using my set-up, or do I need to purchase something new? Bear in mind a new laptop is not realistic at this time. But, I am open to hearing digitizer options -- unless, again, there's a way to make the VidBox perform better.
    Thank you!
  2. Member VWestlife's Avatar
    Mar 2026
    New Jersey, USA
    The "hiccups" are due to the VidBox's lack of a time base corrector (TBC). Searching that phrase will turn up all sorts of stern warnings why you absolutely need one, and why anyway not using one when capturing from analog videotape should be tarred and feathered.
    Jul 2017
    Los Angeles
    Hmm... Could you recommend a device that has this feature? Although if I’m covered with tar and feathers, I may need someone to perform the labor as well.
  4. Member VWestlife's Avatar
    Mar 2026
    New Jersey, USA
    None are cheap, unless you use the passthrough mode of a DVD recorder as an ersatz TBC.
    Or you can just use the DVD recorder for its intended purpose, and the rip the disc on your computer.
    And if you're capturing from a Super VHS-C or Hi8 camcorder, most of those have a built-in TBC. Some later/nicer VHS-C camcorders have one as well.
    Jul 2017
    Los Angeles
    Alright... what are the non-cheap options, and what would be an approximate price range?
    I’ve been looking at YouTube videos on this, but they’re recommending the El Gato (among other devices), and I’ve not read great things about it. Also, they recommend an S-VHS deck with TBC. On eBay, they’re going for $200 to $300 (some, way beyond, and while those are outside consideration, I would consider a $250 model).
    What are your thoughts on this?
  6. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    What "VidBox" model do you have exactly?
    As already mentioned, probably it is the "unstabilized" signal from the VHS source.
    You have the problem with all or certain tapes?
    Always a good test is to do captures with another known stable analogue source if you have that available like cable box/DVD output etc.
    I don't know the capabilities of the "VidBox" and what VHS player you are using but the DVD recorder pass-through option as "ersatz TBC" almost always will improve your captures a lot without too much cost/risk.
    Some recent discussions:
    Good VCRs with auto tracking
    Originally Posted by The_Doman View Post
    Now with good working S-VHS machines getting more and more difficult/expensive to find/get it is often much more feasible and flexible to use the DVD pass-thru option with a good working regular VCR.
    Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
    But a known problem with those, not only Panasonic, older devices are failing capacitors causing the device to fail/operating normally.
    I have several Panasonic DMR ES/EH recorders here (thrift/flea/car boot sale etc) including 1 DMR-ES10 set aside for later repair because the capacitors need replacing.
    I always check first the inside for a visual indication of the capacitors when getting/finding a new recorder.
    Some examples in this topic:
    Panasonic ES10 display very low
    Aug 2018
    Wrocław
    A VCR with TBC is a great solution (just avoid JVC), but a DVD recorder will also suffice. Another option is to use a miniDV or Digital8 camcorder with a video input and transfer the footage via FireWire. In this case, you don't even need a VCR with TBC.
    Jul 2017
    Los Angeles
    I do have a Canon HDV30 from 2008 that still functions. Actually, I have two. But, I do not have a FW port — except on a MacPro tower that I cannot currently boot into.
    To answer some questions:
    It has occurred on multiple tapes and through two VCRs.
    I do not know the VidBox version, I bought it in... 2020 I believe?
    There are FW800 to TB adaptors, yes? But... do they impede the signal at all?
    Re: Making DVDs.. My objections to this are that I’d need a DVD recorder, and is not the file compressed rather appreciably?
  9. Member VWestlife's Avatar
    Mar 2026
    New Jersey, USA
    If you mean the Canon HV30, it can do a fine job of digitization, via its DV passthrough mode.
    Doesn't really matter, they're all basically a glorified EasyCap, based on an Empia chip.
    No, it's lossless. But a bigger problem for you may be that as of Tahoe, Mac OS has dropped support for FireWire.
    Yes, much less so than what you get from the software the VidBox comes with.
    You can get these self-contained Sony "DVDirect" recorders all day long for $15 - $20 because nobody cares about them, but I think they're an absolute steal in terms if the quality you get out of them:
    VHS to DVD without a PC - Sony DVDirect VRD-MC5
  10. I have not recorded VHS to DVD for a long time.
    I never had a VCR with TBC so I can't say how well those work.
    I do still have a working combo Magnavox connected to a TV.
    So if I need to play a VHS I can.
    That being said. I watched the video,
    I wanted to see what it said about Macrovision.
    Basically the video said:"Buy the commercial DVD if you run into Macrovision".
    I have a Dimax Grex digital video stabilizer & Macrovision remover.
    This device always worked well for me.
    Devices like this are usually frowned on by the "own & use a VCR with a TBC" crowd.
    Like in VWestlife's post#2.
    Jul 2017
    Los Angeles
    Yes… I was unaware of this mode / functionality, but I always wondered that, if I never put a cassette inside, could I still just pass a signal — either a live shooting or from a connected VCR — into a computer?
    Well, I was less worried about compression, and more concerned with actual interference and signal limitation because of the adaptor being “in the way”. It’s one more step the data stream has to go through.
    As for Tahoe, I am still on OS 15.7.4. So, one other reason not to “upgrade”.
    Hmm… really. And, as someone suggested, I could rip the DVDs and just save the QT files.
    Holy crap that’s cheap. I guess streaming’s made everything else near-obsolete (personally, I prefer hard media). Although, that'll be almost 200 DVDs I'd have to burn... unless I can continuously burn a DVD-RW...
    Thank you for all that. Not bad for someone who wanted to turn me into a chicken!
    [Attachment 93182 - Click to enlarge]
    It seems the cheapest option for me would be the FW800 to TB adaptor... assuming I have software that would recognize the camera. Crap... that’s another potential problem. Anyone know anything about that?
  12. Member VWestlife's Avatar
    Mar 2026
    New Jersey, USA
    Yes, that's how the DV passthrough mode works. Canon called it "AV -> DV" mode:
    https://www.manualslib.com/manual/275535/Canon-Vixia-Hv30.html?page=74#manual
    Use QuickTime 7.x Pro (registration code available online) and set its recording quality to "device native".
    Jul 2017
    Los Angeles
    Dude... thanks.
    Now, the search for a good adaptor. I found this article:
    https://www.recordingbase.com/how-to-convert-firewire-to-usb-c-thunderbolt/
    Aug 2018
    Wrocław
    Dude... thanks.
    For the FW-to-USB adapter to work, the camera must support it. Only a few Sony models are capable of this.
    Jul 2017
    Los Angeles
    Well, we’re talking FW-to-TB3. Or... is TB a species of USB?
    Aug 2018
    Wrocław
    Since it was hard to do with USB, I doubt it would be better with TB.
    It's better to invest in a laptop with FireWire, capture it, and then sell it.
    Jul 2017
    Los Angeles
    That's actually not a bad idea. I used to have a 2010 MBP that I would capture video with. The OS and hardware ought to be compatible -- if I could find a working one.
    I seem to have 4 options:
    1. Buy an old (and hopefully working) machine with FW...
    2. Buy a DVD burner (but also need to purchase a few hundred blank discs)...
    3. Fix up my 2010 MacPro tower (which will try my patience as I need to do a few things to it)...
    4. Purchase an S-VHS player with TBC.
    All of these are going to require an estimated $200 to $300, with the exception of 3.
    Thanks guys. I got a real education from this thread. ’Preciate it.
