Page 3 of 3
FirstFirst 1 2 3
Results 61 to 85 of 85
    Nov 2015
    Spain
    Please, could anyone share a CDM that works for 4K?
    Thanks.
    Dec 2021
    england
    some site use l3 can fetch 4k, l1 will get 4k most streaming site
    playready can also fetch 4k most of them
    what site you trying get 4K
    Nov 2015
    Spain
    I am asking in general; a file from a 4K television has been shared here that should allow downloading 4K from any source.
    Dec 2021
    england
    I can download 4K some most site with L3.wvd and SL3000.prd
    Nov 2015
    Spain
    And where can I download these files from?
    Dec 2021
    england
    cdm?
    here... andriod l3 cdm
    playready over there>
    https://forum.videohelp.com/threads/416567-PRD-Devices/page2?highlight=sl3000#post2773099
    if you thinking about rip 4k you will need script and tools to download 4K
    Nov 2015
    Spain
    Do these files not work with browser extensions such as Vineless or Widevineproxy2?
    Vineless allows use Playready files.
    Dec 2021
    england
    nope, because your using browser, like disney+ upto 720p, with tool upto 4k DV/HDR.
    tool is andriod tv output
    Feb 2026
    google.com
    Originally Posted by PSXman_uk View Post
    For people who are having issues with dumping there own and for people who want to use real cdms instead of the ones from Android Studio
    Lets see how long it takes for them to turn up on gifthub this time TBF I don't really care would be nice for whoever to put they were from here same thing happened with the Playready prds I gave not to worry though its all good Karma enjoy...
    https://files.videohelp.com/u/33133/samsung_sm-a025g_16.0.0_929e205b_22589_l3.wvd
    When I tried to use it via Vinetrimmer (for netflix 1080p), I got the error:
    - No ESN specified.
    The one in my netflix.yml is
    esn_map:
    # key map of CDM WVD `SystemID = 'ESN you want to use for that CDM WVD'`
    8159: 'NFANDROID1-PRV-P-GOOGLEPIXEL'
    And in my vinetrimmer.yml
    cdm:
      default: 'hisense_smarttv_he55a7000euwts_sl3000'
      Netflix: 'samsung_sm-a025g_16.0.0_929e205b_22589_l3'
    So, how to get its ESN?
    Dec 2021
    england
    - No ESN specified.
    esn_map:
    cdm:
    you cant download nf with this android L3 cdm
    this l3 cdm for ESN is
    22589: 'NFANDROID1-PRV-P-GOOGLEPIXEL'
    but it will not work
  11. For NF 1080p, you need Chrome L3, which practically no one has unless they pay someone (Zane) monthly, or you need a shared key database like DRMLab's vault, which is completely free https://forum.videohelp.com/threads/417972-DRMLab-Project-v2-0#post2791275, or you can purchase Streamfab.
    With a well-configured L3, you could download at maximum SD resolution.
    Feb 2026
    México, Estado de México, Tezoyuca.
    Originally Posted by Goku73 View Post
    Netflix uses Message Security Layer (MSL) for data transfer and it does a check of the device that on connects to its system and its serial number (ESN) if the serial number does not match the device it makes error and does not proceed with the connection of the device so you are not able to take the keys with vinetrimmer you are only able at the moment with CDM chrome L3 possibly API. The Steps the system does are as in the figure,
    the loading of the API
    Initializing the MSL client
    generation of the ESN
    successful handshake
    But without the right device in this case the API chrome L3
    and the right ESN nothing works
    With The L1 you add one more control that makes nothing work, at the moment an L1 is unusable for Netflix, as I said before only a few in the world manage to use instead of L3 also a Playready CDM that has also other additional control besides the ESN which are the kpe and kph.
    kpe and kph is a key pair provided to the device at manufacturer level that is used to do the key exchange with MSL handshake
    can be seen here https://github.com/Netflix/msl/blob/master/tests/src/main/java/com/netflix/msl/entitya...ctory.java#L42
    Hello, @goku73, Could you please tell me how you manage to load the remote device? I've searched all over the internet for chromecdm.wvd without success, and of course, I only found paid versions. In the image, I see that you managed to do it with VineTrmmer. I'm ignorant about programming (end user) and I don't know how to do it. I would appreciate your help with this. Thank you for your attention, and a hug from México.
    [Attachment 91373 - Click to enlarge]
  13. Exactly like the paid version, but without putting in what you don't have, host and key. The problem is that you need to have a backup vault, as I said above.
    on vinetrimmer.yml:
    cdm:
    Netflix: 'chrome_api'
    cdm_api:
    - name: 'chrome_api'
    host: ''
    key: ''
    device: 'widevine'
    type: 'CHROME'
    system_id: 36586
    security_level: 3
    Another problem is that they have revoked the latest version of Chrome's CDM, the system_id number should have remained the same, so for the moment there are problems getting 1080p without updating the script.
    Feb 2026
    on vinetrimmer.yml:
    cdm:
    cdm_api:
    host: ''
    key: ''
    device: 'widevine'
    type: 'CHROME'
    system_id: 36586
    security_level: 3
    Thank you so much for replying and sharing this information, Unfortunately, an update is necessary. You do great work, keep it up! Hugs from México.
    P.S. Which version of VT PR are you using?
  15. Originally Posted by silverfox3264 View Post
    on vinetrimmer.yml:
    cdm:
    cdm_api:
    host: ''
    key: ''
    device: 'widevine'
    type: 'CHROME'
    system_id: 36586
    security_level: 3
    The vinetrimmer I use is not available online, but to get or view 1080p, just change the value of payload_challenge in the netflix.yml file located in the \vinetrimmer\config\services folder. You can get it with the script for tampermonkey or greasymonkey eme logger https://greasyfork.org/en/scripts/373903-eme-logger by pressing F12, entering the browser console, starting any NF video file and searching for licence-request.
    Feb 2026
    on vinetrimmer.yml:
    cdm:
    cdm_api:
    host: ''
    key: ''
    device: 'widevine'
    type: 'CHROME'
    system_id: 36586
    security_level: 3
    Thanks again for replying and supporting my attempt to download Netflix videos. It's a great help; it works wonderfully. However, the netflix.py file I'm using doesn't have the remote device configured, and it gives this error:
    File "<string>", line 1, in <module>
    import sys; from importlib import import_module; sys.argv = ['D:\\VT.PR.WV\\.venv\\Scripts\\vt.cmd', 'dl', '-al', 'es-419', '-q', '720', '--keys', '--no-cache', '-w', 's01', 'Netflix', '80109135']; sys.exit(import_module('vinetrimmer.vinetrimmer'). main())
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 1161, in __call__
    return self.main(*args, **kwargs)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 1082, in main
    rv = self.invoke(ctx)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 1443, in invoke
    return ctx.invoke(self.callback, **ctx.params)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 788, in invoke
    return __callback(*args, **kwargs)
    File "D:\VT.PR.WV\vinetrimmer\vinetrimmer.py", line 72, in main
    dl()
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 1697, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\core.py", line 1666, in _process_result
    value = ctx.invoke(self._result_callback, value, **ctx.params)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\click\decorators.py", line 33, in new_func
    return f(get_current_context(), *args, **kwargs)
    File "D:\VT.PR.WV\vinetrimmer\commands\dl.py", line 590, in result
    challenge=ctx.obj.cdm.get_license_challenge(sessio n_id, service_name),
    File "D:\VT.PR.WV\vinetrimmer\utils\widevine\cdm.py ", line 70, in get_license_challenge
    return self.device.get_license_challenge(self.sessions[session_id], service_name)
    File "D:\VT.PR.WV\vinetrimmer\utils\widevine\device.py" , line 379, in get_license_challenge
    res = self.session("GetChallenge", {
    "init": pssh,
    ...<4 lines>...
    "service": service_name
    File "D:\VT.PR.WV\vinetrimmer\utils\widevine\device.py" , line 425, in session
    res = requests.post(
    self.host,
    ...<4 lines>...
    ).json()
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\api.py", line 115, in post
    return request("post", url, data=data, json=json, **kwargs)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\sessions.py", line 575, in request
    prep = self.prepare_request(req)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\sessions.py", line 484, in prepare_request
    p.prepare(
    method=request.method.upper(),
    ...<10 lines>...
    hooks=merge_hooks(request.hooks, self.hooks),
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\models.py", line 367, in prepare
    self.prepare_url(url, params)
    File "D:\VT.PR.WV\.venv\Lib\site-packages\requests\models.py", line 438, in prepare_url
    raise MissingSchema(
    ...<2 lines>...
    requests.exceptions.MissingSchema: Invalid URL '': No scheme supplied. Perhaps you meant https://?
    If you could help me with that, I'd really appreciate it so much, thank you in advance, as I see you're a guru at this. A hug from México!
  17. This is not the right place to discuss this, as I said a few posts above. If you don't have a decryption key database, you can't download it. Go here
    and join the Discord channel. If the invitation doesn't work, ask for another one. There you will find new versions of Vinetrimmer and if you want to use your version, in any case, even just the shared free vault/database and the section to request keys if they are not present in the vault.
    I can't put their vault address out there so publicly.
    Greetings from Italy
  18. Member
    Feb 2026
    Thank you. A hug from Mexico!
    Jun 2026
    Lowestoft UK
    what is this? been sent here..see samsung and Hisense..My pc is a Lenovo..all i want to do is capture the Graspop festival..Had 2 strokes and 10 mini strokes. Have dementia too so i have no idea why i was sent here or what to do
  20. hello im using vineless on mozilla i get error because i dont have wvd file, how i get it for private key and pssh? thanks
  21. PSSH has nothing to do with (btw: your message seems quite off-topic for this thread ...)
    Either grab one from the initial post of this thread or use the "pywidevine" python module to convert using private key and client id:
    pywidevine create-device --help
    INFO:root:pywidevine version 1.9.0 Copyright (c) 2022-2026 rlaphoenix
    INFO:root:https://github.com/devine-dl/pywidevine
    Usage: pywidevine create-device [OPTIONS]
      Create a Widevine Device (.wvd) file from an RSA Private Key (PEM or DER)
      and Client ID Blob. Optionally also a VMP (Verified Media Path) Blob, which
      will be stored in the Client ID.
    Options:
      -t, --type [chrome|android]  Device Type  [required]
      -l, --level INTEGER RANGE    Device Security Level  [1<=x<=3; required]
      -k, --key PATH               Device RSA Private Key in PEM or DER format
                                   [required]
      -c, --client_id PATH         Widevine ClientIdentification Blob file
                                   [required]
      -v, --vmp PATH               Widevine FileHashes Blob file
      -o, --output PATH            Output Path or Directory
      --help                       Show this message and exit.
  22. Hi everyone,
    I’m experimenting with WidevineProxy2 on a specific streaming service (Irdeto-based license server) and running into a VMP rejection issue.
    Here is the behavior:
    When the proxy is disabled, the web player uses the browser's native CDM and playback works perfectly.
    When the proxy is enabled (using an L3 CDM I've configured), the web player immediately throws an Error 3304.
    I checked the network logs for the license request, and the server is actively rejecting the challenge with the following payload:
    {"code":190120,"message":"No keys were added to the license response. The clients' platform status (noVerification) is restricted, the configured policies prevent the return of a license."}
    I understand that noVerification means the license server is enforcing strict VMP (Verified Media Path) policies and rejecting the injected CDM's cryptographic signature.
    My question: Aside from the obvious answer of "your CDM is revoked/blacklisted," is there any configuration trick within the proxy itself, or the way the challenge is formatted, to handle strict VMP checks for services like this? Or is the only real solution here to completely scrap this .wvd file and source a fresh L3 extraction directly from a physical Android device?
    Any advice on the current best practices for dealing with this specific Irdeto VMP block would be appreciated. I just want to know if I'm wasting my time trying to fix my proxy setup when the underlying device file is the actual bottleneck. Thanks!
  23. Member
    Feb 2006
    Originally Posted by paul92 View Post
    Hi everyone,
    unshackle - https://forum.videohelp.com/threads/418705-Unshackle-Modular-Movie-TV-and-Music-Archival-Software
  24. Originally Posted by october262 View Post
    Hi everyone,
    How is unshackle better, will I not have the same CDM issue?
  25. Member
    Feb 2006
    Hi everyone,
    unshackle uses i believe the mobile API for paramount plus.
