Finally thanks to your help I was able to download DRM protected videos from Raiplay.
The problem is that I only download them up to 1280x720, when I try to download in full hd I get this message from N_m3u8DL-RE and the video is all blurred and in lines:
Binary merging...
09:41:54.242 INFO : Decrypting...
09:41:54.247 WARN : CSI VEGAS 3x10_HD.ita.mp4
09:41:54.248 WARN : CSI VEGAS 3x10_HD.Italiano.m4a
09:41:54.248 WARN : Muxing to CSI VEGAS 3x10_HD.MUX.mkv
09:41:54.400 WARN : [h264 @ 000002bc19284b00] top block unavailable for requested intra mode -1
09:41:54.401 WARN : [h264 @ 000002bc19284b00] error while decoding MB 1 0, bytestream 155298
09:41:54.549 WARN : [aac @ 000002bc19284b00] Prediction is not allowed in AAC-LC.
09:42:03.413 WARN : Cleaning files...
09:42:03.531 WARN : Rename to CSI VEGAS 3x10_HD.mkv
09:42:03.842 INFO : Done
This is the video I would like to download: https://www.raiplay.it/video/2024/08/CSI-Vegas-S3E10-Fino-in-fondo-32f25178-ba5a-49ed-...debdafc74.html
This the code I found with Widevine L£ Guesser 2024: ad0d5942c2023225a9c51c369b69da9d:4c63cf1d8e2610172 73e693347953a8d
This the link I found with The STream detector: https://streamcdng9-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_ro...0ba295ee9e07ca
This the script used: N_m3u8DL-RE --key ad0d5942c2023225a9c51c369b69da9d:4c63cf1d8e2610172 73e693347953a8d "https://streamcdng9-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_RaiPlay_multiaudio/24047990_,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1724743789~exp=1724 743939~acl=/*~hmac=8b824a28a4996a087ffa1659d5d70b7e60143dc455d 4cd12d90ba295ee9e07ca" -M mkv --check-segments-count false --save-name "CSI VEGAS 3x10_HD" --> NOTE: I added the 3600 and 5000 options, I don't know if I did it right
Would anyone be able to tell me where I'm going wrong?
To find the L3 CDM keys I used this guide: https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio
Thank You
Enter the video url: https://www.raiplay.it/video/2024/08/CSI-Vegas-S3E10-Fino-in-fondo-32f25178-ba5a-49ed-ac4b-364debdafc74.html N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_RaiPlay_multiaudio/24047990_,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1724763947~exp=1724764097~acl=/*~hmac=db9c21904cf7ae034861f31d7961e692fbab070b0ef27c89b8187915fa89c206" --save-name "C.S.I.: Vegas S3E10 - Fino in fondo" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 41800f247f8432b1a740902792ef6512:5a390ef2d0979d9c9624dbae456c9bba
To get HD ? There is a trick with https://mediapolisvod.rai.it/relinker/relinkerServlet.htm, see this post for more infos : https://forum.videohelp.com/threads/413755-Help-with-RaiPlay-keys#post2737821
Thank you, I will try to study further.
I ask if you could kindly help me in the meantime with this HD video:
https://www.raiplay.it/video/2024/08/CSI-Vegas-S3E9-Heavy-Metal-08154e77-7e38-462f-986...23c19ba80.html
Thanks a lot -
Enter the video url: https://www.raiplay.it/video/2024/08/CSI-Vegas-S3E9-Heavy-Metal-08154e77-7e38-462f-9863-dcc23c19ba80.html N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_RaiPlay_multiaudio/24047919_,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1724867126~exp=1724867276~acl=/*~hmac=9f75550e2a38b1d6009dbfa59d69923f047c6cd05c960c27800ca8cea7ea1bc9" --save-name "C.S.I.: Vegas S3E9 - Heavy Metal" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 8a2931bb46f63668b325f0d0592c4fad:c843e771d434c851ff6def4859d58a9a
raiplay movie
By ulissess in forum Video Streaming DownloadingReplies: 6Last Post: 2nd Aug 2024, 13:33 -
Help for Downloading from raiplay
By kintaor in forum Video Streaming DownloadingReplies: 4Last Post: 8th Jul 2024, 11:32 -
Need Help to download from RaiPlay
By kintaor in forum Video Streaming DownloadingReplies: 2Last Post: 1st Jul 2024, 01:50 -
Raiplay show
By RandallFlagg in forum Video Streaming DownloadingReplies: 6Last Post: 18th Jan 2024, 12:34 -
RaiPlay Download
By ajones219 in forum Video Streaming DownloadingReplies: 17Last Post: 25th Nov 2021, 02:59
