Results 1 to 25 of 25
  1. Good afternoon. maybe somebody of you, friends, may help with Raiplay keys. I'm able to get PSSH and license url https://rai6nb5f.anycast.nagra.com/RAI6NB5F/wvls/contentlicenseservice/v1/licenses, but insering them into https://keysdb.net/ I get an error. Maybe should I use a specific header?
    I'd need keys for the following videos
    https://www.raiplay.it/video/2024/03/Le-indagini-di-Sister-Boniface-S1E1-Cause-innatur...d14db6c85.html
    https://www.raiplay.it/video/2024/03/Le-indagini-di-Sister-Boniface-S1E2-Motore-ciak-o...3a3e33991.html
    Thank you very, very much, in advance for all kind help and advice
  2. Code:
    2bfef0e5eba73248886917975081920f:083ca3631b2affea1ba4ea99e009ff3b
    bfa3bad1b9de391ab83d588d5fd20162:d996d462c933f201ec4f4439b58e2325
    [Attachment 77582 - Click to enlarge]
    nv-authorizations expires fast...
    you have to be faster
  3. Oh, thank you, thank you so much for the keys. May you explain where I can find the nv-authorizations string? Is it possible to obtain it from chrome console? Thank you very much, in advance for all help
  4. Originally Posted by misiek1963 View Post
    Yes, it's in the request headers of the license url.
  5. Thank you very very much for advice. I was able to find nv-authorizations in license header tab, but it expires instantaneously and when I copy it and paste into https://keysdb.net/ I get an error {"code":400,"error":true,"message":"Wrong headers: while scanning a simple key\n in \"\", line 2, column 1:\n eyJhbGciOiJIUzI1NiIsImtpZCI6IjE5 ... \n ^\ncould not find expected ':'\n in \"\", line 2, column 404:\n ... hhKgouNiSGwnv-T6flxi1533ddYuTXfc\n ^"}. Any help to capture it sufficiently fast? Thank you so much in advance
  6. Thank you very much for the answer. I already use https://keysdb.net/ but the problem is to copy and paste nv-license fastly enough before it expires. Please help
    Dec 2021
    england
    first put pssh and license url in https://keysdb.net/
    go to license url refresh browser page (F5) to get fresh lic url, copy nv-authorizations, paste on keydb quickly, then you will get key
  8. Originally Posted by misiek1963 View Post
    Your problem is not the token expiring, but it's a syntax problem that I described here earlier today: https://forum.videohelp.com/threads/410463-how-get-pssh-key-from-mediaset/page2#post2727326
  9. Originally Posted by white_snake View Post
    Thank you so much for the answer and explanations. I've replaced the line with a space and I could obtain the key for the following video https://www.raiplay.it/video/2021/06/Marvels-Runaways-S3E1-36a1a538-1150-4de5-87ce-3df8e574841a.html I took as a test, but only using https://cdrm-project.com/ site. I had to be very fast in copying authorizathions, but at last I was able to succeed. Thank you so much, again, for all kind help. Goodnight
  10. Originally Posted by misiek1963 View Post
    np, that's a rookie mistake we all made at some point. Goodnight
  11. Good evening, my friends. I'd like to discuss with you a problem I've experienced withe a RaiPlay video. The link is the following: https://www.raiplay.it/video/2021/10/Luomo-fedele-08299d41-29ab-4b67-9e18-6c0adffe4175.html.
    In this case, by inspection, I found PSSH and authorization and, in the end the key:
    af15920564ff36ebaa3ce249f5cdc8c6:3fae4f30ab39832d4051b073acb0e070
    Anyway, in this case, a full hd video is available so, if we want to download we should use the following .mpd file, which we obtain modificating a bit the original .mpd file we find inspecting:
    https://streamcdnr20-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_RaiPlay_multiaudio/15064540_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1714400815~exp=1714400965~acl=/*~hmac=2dc53becf23312c384d6a2cbcf8ddb5f8f329c07a9f988507887a7c01377519e
    Opening this last file with notepad we have
    <?xml version="1.0" encoding="UTF-8"?>
    <MPD xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xmlns="urn:mpeg:dash:schema:mpd:2011"
         xmlns:xlink="http://www.w3.org/1999/xlink"
         xmlns:cenc="urn:mpeg:cenc:2013"
         xsi:schemaLocation="urn:mpeg:DASH:schema:MPD:2011 http://standards.iso.org/ittf/PubliclyAvailableStandards/MPEG-DASH_schema_files/DASH-MPD.xsd"
         profiles="urn:mpeg:dash:profile:isoff-live:2011"
         type="static"
         publishTime="2024-05-30T11:54:09.518Z"
         mediaPresentationDuration="PT1H12M47.28S"
         minBufferTime="PT1.5S">
    <ProgramInformation>
        <Title>drm_root/DRMNagra_RaiPlay_multiaudio/15064540_,1200,1800,2400,3600,5000</Title>
    </ProgramInformation>
    <Period id="0" start="PT0.0S">
        <AdaptationSet id="0" group="1" mimeType="video/mp4" lang="ita" maxWidth="1920" maxHeight="1080" par="16:9" frameRate="25" segmentAlignment="true" startWithSAP="1" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
            <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc" cenc:default_KID="598ae8b2-87ec-3ccc-96d9-a60592c1a2c1"/>
            <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed" value="Widevine">
                <cenc:pssh>AAAAhHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGQIARIQWYrosofsPMyW2aYFksGiwRoFTmFncmEiR2RybV9yb290L0RSTU5hZ3JhX1JhaVBsYXlfbXVsdGlhdWRpby8xNTA2NDU0MF8sMTIwMCwxODAwLDI0MDAsMzYwMCw1MDAw</cenc:pssh>
            </ContentProtection>
            <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95" value="Playready">
                <cenc:pssh>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</cenc:pssh>
            <SegmentTemplate presentationTimeOffset="0" timescale="90000" duration="900000" startNumber="1" media="segment_ctvideo_rid$RepresentationID$_cn$Number$_mpd.m4s" initialization="segment_ctvideo_rid$RepresentationID$_cinit_mpd.m4s"/>
            <Representation id="p0va0br1799885" codecs="avc1.4d401f" width="1024" height="576" sar="1:1" bandwidth="1799885" />
            <Representation id="p0va0br2399858" codecs="avc1.4d4028" width="1280" height="720" sar="1:1" bandwidth="2399858" />
            <Representation id="p0va0br3599803" codecs="avc1.4d4029" width="1440" height="810" sar="1:1" bandwidth="3599803" />
            <Representation id="p0va0br4999739" codecs="avc1.640033" width="1920" height="1080" sar="1:1" bandwidth="4999739" />
        </AdaptationSet>
        <AdaptationSet id="1" group="2" mimeType="audio/mp4" lang="Italiano" segmentAlignment="true" startWithSAP="1" subsegmentAlignment="true" subsegmentStartsWithSAP="1">
            <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="2"/>
            <SegmentTemplate presentationTimeOffset="0" timescale="44100" duration="441000" startNumber="1" media="segment_ctaudio_rid$RepresentationID$_cn$Number$_mpd.m4s" initialization="segment_ctaudio_rid$RepresentationID$_cinit_mpd.m4s"/>
            <Representation id="p0aa0br192400" codecs="mp4a.40.2" audioSamplingRate="44100" bandwidth="192400">
            </Representation>
        </AdaptationSet>
    </Period>
    </MPD>
    and we see that the PSSH and Kid are different from the ones we used to find key, so the key we have previously found isn't suitable to decrypt higher resolution videos. The question is: how to find the right key? What do you think about? Thank you very, very much, in advance, for all help and advice. Have a great evening
  12. Code:
    598ae8b287ec3ccc96d9a60592c1a2c1:9737b178f18c7807c713dc66b39cbb89
  13. Originally Posted by Goku73 View Post
    Thank you so very much for the key. Anyway I'd like to learn how you got it. I'd need to know the procedure to get the right Nv-authorization, so to use keysdb.net or similar site in order to obtain the key. The PSSH is
    am I right?
    Thank you very, very much, for all help. Have a nice day
  14. Originally Posted by misiek1963 View Post
    am I right?
    You need to open up the network inspector and look for requests made to a widevine server - this can be found my searching for "wv","widevine" or similar. Then click on that request, it will open a window where you can then look for "headers". Nv-authorization will be sent as a header value.
  15. Originally Posted by keep_it_breezy View Post
    am I right?
    Thank you for answer. I've already done it, but I can see PSSH and headers which are valid only for 720 resolution video, so I'm not able to get a valid key for higher resolutions, that is 810 and 1080. You may see it opening video url https://www.raiplay.it/video/2021/10/Luomo-fedele-08299d41-29ab-4b67-9e18-6c0adffe4175.html
  16. Originally Posted by misiek1963 View Post
    am I right?
    This might seem like a silly question, but are we sure that Raiplay supports 1080P for L3 CDM's?
  17. Member aqzs's Avatar
    Mar 2024
    Paris
    With this command :
    N_m3u8DL-RE "https://streamcdnr20-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_RaiPlay_multiaudio/15064540_,1200,1800,2400/manifest_mvnumber.mpd?hdnea=st=1717174883~exp=1717175033~acl=/*~hmac=7433e2a6224892097a60fdb1f61c7ba6e612d3df811483a2dd17381c6669789d" --key af15920564ff36ebaa3ce249f5cdc8c6:3fae4f30ab39832d4051b073acb0e070 -M format=mkv
    I'm only getting 720p : https://www.swisstransfer.com/d/002fa876-1abe-43e1-9222-b5e8d2daea19
    On which plateforme are you playing that video to get 1080p ?
    From
    https://mediapolisvod.rai.it/relinker/relinkerServlet.htm?.........
    Im getting the mpd url, which is 720p only.
  18. Originally Posted by keep_it_breezy View Post
    am I right?
    For the video above https://www.raiplay.it/video/2021/10/Luomo-fedele-08299d41-29ab-4b67-9e18-6c0adffe4175.html it does, and with the key kindly provided by Goku73 it is possible to decrypt 1080 video
  19. Originally Posted by aqzs View Post
    With this command :
    From
    And this is the problem, aqzs, you addressed it very well, if you modify the string of .mpd file in this way
    you may get two more resolutions, which are decryptable using the key above, that is
    Anyway such resolutions seem not playable in the video url https://www.raiplay.it/video/2021/10/Luomo-fedele-08299d41-29ab-4b67-9e18-6c0adffe4175.html, so I don't know how this key could be obtained
  20. The display of the 1080p link must be forced in the browser so as to also take the relevant Nv-authorization, I am not sure I want to disclose the procedure publicly, but if you are really interested please contact me privately, I am Italian, we can talk in Italian in private. I can tell you that you don't need the console, to get started you just need a JSON formatter extension for chrome, or use Firefox which already has it built in, rename the episode link changing the final .html to .json and get this
    https://www.raiplay.it/video/2021/10/Luomo-fedele-08299d41-29ab-4b67-9e18-6c0adffe4175.json
    I will work on this link:
    https://mediapolisvod.rai.it/relinker/relinkerServlet.htm?cont=VL8hnxnq1jhyJf0jnNqpCQeeqqEEqualeeqqEEqual
    but I will go no further
    subtitles can also be found on this page if present
    example of another link
    if they are present, simply right-click and ‘save as’.
  21. Someone can explain me how to download / see 1080p on Raiplay?
    I'm not able to write to Goku.
    Thanks,
    Edo
  22. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You can't PM someone until you have posted something.
    https://forum.videohelp.com/threads/407748-Just-signed-up-and-cannot-private-message-a...ne#post2673847
    You should try again
  23. Thanks, now I can do
