Results 1 to 21 of 21
  1. Good afternoon, it's been some days that I tried to decrypt a video that uses a MPD+AES 128 CBC key, I tried seeking the tutorial:
    https://forum.videohelp.com/threads/413718-My-journey-with-AES-128-encrypted-HLS
    https://forum.videohelp.com/threads/414202-%5BSOLVED%5D-AES-128-encryption-using-a-DAS...-manifest-file
    I checked also other topics, but I didn't find anything regarding MPD + AES 128 that resembles the problem I have.
    Sorry to the staff if it was asked before(it seems not)
    I checked the requests(all of them) but I didn't find any possible "key". What to do in such cases? I tried to access the link:
    keyUriTemplate
    But nothing, it fails asking for a parameter.
    I was able to find the IV and also the code that "decrypts" the frames in javascript, but it's a mess.
    Any suggestion to what to do in such cases?
    What makes me wonder is that there is no request to the "CryptoPeriod keyUriTemplate=" found in the mpd, still the webpage can decrypt the frames.
    Before I was able to use yt-dlp and it was enough to download it(simple MPD no encryption), but now it's impossible.
    For stream(by microsoft) they were using M3U8 + AES 128 CBC if I'm not wrong and I could get the keys by the requests, while on sharepoint I can't find it.
    If someone can point me to some guides/tutorials it would help me a lot.
  2. Originally Posted by raknitir View Post
    keyUriTemplate
    share video url
  3. Yes please i've been looking for a manifest like this
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  4. Sadly I can't it's a work account and a work video any idea of where to look? Is it possible that the key is inside the url(so without making a request?)
    I'm continuing searching a solution.
  5. The key and IV are inside the manifest.
    Could you send me a PM regrading the manifest? I really need it to develop my downloader.
  6. @larley
    have you tried the search filed on the forum? there are many posts about aes-128
    https://www.videohelp.com/search?siteurl=forum.videohelp.com&q=aes-128
  7. Yes, for HLS, but not DASH. There's only one thread about this but the site metioned removed the Manifests and is now serving raw video files.
  8. I may have found the key any idea of how to decrypt the file? I tried N_m3u8DL-RE but it doesn't decrypt it even if I provide the supposed key(the files downloaded are the same as the ones I downloaded before encrypted) and IV.
  9. 1) I downloaded the key by using the URI in the KeyURITemplate found in the MPD manifest and I replaced the & with &.
    2) I downloaded all the segments using the youtube-dlp with the --keep-fragments argument
    3) I modified and used the script found thanks to the solution suggested by larley. That generated two m3u8s and the main one
    4) Then I used N_m3u8DL-RE with the main.m3u8 and the key I found previously if the key it's in the same folder it's enough the name of it for example "Key"
    I tried to download a video I already had downloaded and it seems that the bitrate is half the original for the mp4.
    While the audio gives that warning while merging:
    Non-monotonic DTS in output stream.... This may result in incorrect timestamps in the output file.
    I noticed also that the audio fragments are 2 times the video's ones(for example 1000 video fragments and 2000 audio fragments)
    How to make sure to download the best resolution with yt-dlp?(I can't use -F because is DRM) Just to make does it downloads the best?
    Thanks to larley for his help.
    I hope this really short "guide" can help someone.
  10. Code:
    --allow-u
    with either
    -f "bv,ba"
    or
    -F
    and
    -f <id>+<id>
  11. Thanks a lot, do you know of any solution to Non-monotonic DTS in output stream.... This may result in incorrect timestamps in the output file. for the audio file?
  12. Thanks I'll make some tests to understand why.
  13. I downloaded the same video 3 times and it seems the last fragment of the video file is different in one download while in the other two downloads has the same hash. I used the following command, did I do something wrong?
    yt-dlp "" --allow-unplayable-formats -o "video" -R "infinite" --fragment-retries "infinite" --file-access-retries "infinite" --retry-sleep linear=1::2 --retry-sleep fragment:1 --cookies cookies.txt --limit-rate 40K --concurrent-fragments 4 --keep-fragments
    Are there other tools to download fragments without merging?
    I'm a noob sorry.
  14. The downloader i mentioned here: https://forum.videohelp.com/threads/415144-AES-128-in-DASH-MPD-file#post2741789 with:
    --skip-merge
    (not sure why you would want to skip merging if it already decrypts them for you)
  15. Because N_m3u8DL-RE.exe doesn't decrypt it(MPD + AES 128) and I have to download the fragments using yt-dlp, generate the needed .m3u8 and then run N_m3u8DL-RE on the m3u8. Am I missing something? Thanks for the help.
  16. Did you use the modified version that i referenced and provided the key?
    --custom-hls-key <key>
    The modified downloader should error out with 'need the key' or something when needed but not specified.
  17. Thanks, I didn't notice it(I read the post above it). I'll try it soon.
  18. It doesn't detect it's AES 128 and doesn't decrypt it.
  19. I noticed the last fragment(encrypted) changes every time I download the file, is it corrupted? How can I solve it? Please help me.
