Good evening, my friends, I'd like to discuss with you a decryption procedure with site la7.it. As an example, let's consider the following video urlInspecting I can get the data:Code:https://www.la7.it/film-e-fiction/rivedila7/il-processo-di-norimberga-21-06-2024-548773
PSSH
License serverCode:AAAAYXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAEEIARIQ01pp2bOiS8CAQtaiuFqJPRoFQ29uYXgiJDk4MWM2ZmY4LWM5NGItNGZhNS04NjYyLTNiYzY2YWQ1ZGM5OA==mpdCode:https://la7.prod.conax.cloud/widevine/license?d=1719420040062When I put license server and PSSH into keysdb.net or some similar site, it returns an error. Should I use a specific header? What do you think? Thank you very, very much in advance for all help and advices. Have a great eveningCode:https://d3iki3eydrtvsa.cloudfront.net/IlProcessoDiNorimberga_20240620211948/DASH/IlProcessoDiNorimberga_20240620211948.mpd![]()
Results 1 to 19 of 19
The license request can only be used once, presumably because the JWT (submitted with the "preAuthorization" header) contains a JTI to counter replay attacks.
If you block the license request and use it with your own scripts/tools, it'll return the key:
Code:--key d35a69d9b3a24bc08042d6a2b85a893d:cc97cb1d9d7cc66da2b11b2502d56a3d
It worked well for me without blocking the request, I could even get 5 times the key without changing the header.
Thank you very much for prompt answer and key. I'd like to understand which header to use, for example in site keysdb.net or https://old.cdrm-project.com/ in order to get the key, as, if I leave the header pane empty, I get an error. Thank you very much for all your help
Here is a script that will get the job done for you :
You have to edit the path of DEVICEPATH. If you don't have a CDM grab one from here : https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21 or make on from here : https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-StudioHTML Code:from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH import requests import re from bs4 import BeautifulSoup def getkey(preTokenUrl, pssh): pretoken = requests.get(preTokenUrl).json()['preAuthToken'] headers = {'preauthorization': pretoken,} pssh = PSSH(pssh) lic_url = 'https://la7.prod.conax.cloud/widevine/license' device = Device.load(DEVICEPATH) cdm = Cdm.from_device(device) session_id = cdm.open() challenge = cdm.get_license_challenge(session_id, pssh) licence = requests.post(lic_url,headers=headers, data=challenge) licence.raise_for_status() cdm.parse_license(session_id, licence.content) keys = [] for key in cdm.get_keys(session_id): if key.type=='CONTENT': keys.append(f"{key.kid.hex}:{key.key.hex()}") cdm.close(session_id) return keys def getcommand(url): response = requests.get(url) preTokenUrl = re.search(r'preTokenUrl = "(.*?)"', response.text).group(1) videoParams = re.search(r'var videoParams\s*=\s*({.*?});', response.text, re.DOTALL).group(1) videoParams_clean = re.sub(r'([a-zA-Z_]+)\s*:', r'"\1":', videoParams).replace('"https"', 'https') mpd_url = re.search(r'"dash"\s*:\s*"([^"]+)"', videoParams_clean).group(1) title = re.search(r'"title"\s*:\s*"([^"]+)"', videoParams_clean).group(1) pssh = BeautifulSoup(requests.get(mpd_url).text, 'lxml-xml').findAll('cenc:pssh')[1].text keys = getkey(preTokenUrl, pssh) print(f"""N_m3u8DL-RE "{mpd_url}" --save-name "{title}" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key """ + ' --key '.join(keys)) # vidurl = 'https://www.la7.it/film-e-fiction/rivedila7/il-processo-di-norimberga-21-06-2024-548773' DEVICEPATH = "device.wvd" vidurl = input('Enter the URL of the video: ') getcommand(vidurl)
For exemple for : https://www.la7.it/film-e-fiction/rivedila7/il-processo-di-norimberga-21-06-2024-548773 the script return :
Code:N_m3u8DL-RE "https://d3iki3eydrtvsa.cloudfront.net/IlProcessoDiNorimberga_20240620211948/DASH/IlProcessoDiNorimberga_20240620211948.mpd" --save-name "Il processo di Norimberga" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key d35a69d9b3a24bc08042d6a2b85a893d:cc97cb1d9d7cc66da2b11b2502d56a3d
@aqzs, then I might have been really unlucky that the JWT expired below my fingers. The JWT has a lifetime of a couple minutes.
@misek1963: I guess you'll need at least the preAuthorization header. But haven't tested it. -
Yeah, but before writing a script you'll have to analyze the network requests first and manually try what has to be done...
For expire times and generally payload of JWTs simply paste them at https://jwt.io/ -
I usually copy raw curl from network tab, if I see an JWT token I search for it in network tab too and copy the request a curl too. I try removing every part from header that can be removed and automate everything. That's how I mad this script : https://forum.videohelp.com/threads/415062-Help-with-la7-it#post2740871 and many others I shared here ^^
JWT token are json base64 encoded. You can read them with that script :
HTML Code:import json import base64 from pprint import pprint def jd64(input): try: return json.loads(base64.b64decode(input)) except base64.binascii.Error : if '====' in input: return 'Invalid base64-encoded string' else: return jd64(input+'=') tokenpart = 'eyJhbGciOiJFUzI1NiIsImtpZCI6ImRlZmF1bHQiLCJ0eXAiOiJKV1QifQ' pprint(jd64(tokenpart)) -
Yes, I know. I have my own script to decode them. Which I usually do if I see one.
Thank you very, very much, for the script tailored for my need. I've grabbed the CDM and now I've got the two files
andCode:device_client_id_blob.bin
which are located inCode:device_private_key.pem
directory. I've edited DEVICEPATH in several ways but I see all the time an invalid sintax error. Maybe my question is a stupid one, surely it is, but may you kindly advice me in detail how to perform the editing? Thank you very, very much, again, for all your help and efforts. I apologize for the trivial questionCode:T:\Pythonult\
With those 2 files you need to make a CDM using that command :
Or in you case based on name you have :Code:pywidevine create-device -k device_private_key -c device_client_id_blob -t ANDROID -l3 -o WVD
Then you should have a file that end with .wvd, copy the path of that file and put it in the scriptCode:pywidevine create-device -k device_private_key.pem -c device_client_id_blob.bin -t ANDROID -l3 -o WVD
Thank you so much for the code. I've followed your advices and now I've got the following file
Should I leave this name or change it? When I edit the script should I write only the path to the file (that isCode:unknown_android_sdk_built_for_x86_16.0.0_9d1ea0a0_8162_l3.wvd
) or the file, too (that isCode:t:\Puthonult\WVD
) ? Thank you very much for your pacience and precious help. Have a great eveningCode:t:\Puthonult\WVD\unknown_android_sdk_built_for_x86_16.0.0_9d1ea0a0_8162_l3.wvd
in the script write :
Code:DEVICEPATH = 't:/Puthonult/WVD/unknown_android_sdk_built_for_x86_16.0.0_9d1ea0a0_8162_l3.wvd'
Thank you very much, really, for all your so kind help and efforts in explaining in detail all steps. After modifying the script I've been able to launch it. Anyway after inserting the video url (video plays in browser) I get the following error messages
What do you think about this? Thanks, again, for all help. Have a nice dayCode:la7.py Enter the URL of the video: https://www.la7.it/film-e-fiction/rivedila7/il-processo-di-norimberga-21-06-2024-548773 Traceback (most recent call last): File "T:\Pythonult\la7.py", line 49, in <module> getcommand(vidurl) File "T:\Pythonult\la7.py", line 41, in getcommand pssh = BeautifulSoup(requests.get(mpd_url).text, 'lxml-xml').findAll('cenc:pssh')[1].text ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "T:\Python39\Lib\site-packages\bs4\__init__.py", line 250, in __init__ raise FeatureNotFound( bs4.FeatureNotFound: Couldn't find a tree builder with the features you requested: lxml-xml. Do you need to install a parser library?
After some trials and errors I get this message
, so lxml should be in place, anyway the error is still present. Any help? Thanks, again, for all your patience, I'm annoying you all the timeCode:Requirement already satisfied: lxml in t:\pythonult\lib\site-packages (5.2.1)
