Results 1,201 to 1,230 of 1866
i have tried to download off discovery Plus (UK) and no matter what i try i get this message. i done the cookie extraction from browser renamed it to the service but just this.
[Attachment 84335 - Click to enlarge] -
Thank you for this incredibly helpful guide. I got almost the whole way there but have an issue when the videos are decrypted. Do you have any insight into anything that needs changed? I'm using the provided wvd files.
Code:devine dl --list-titles ALL4 https://www.channel4.com/programmes/father-christmas devine dl --list ALL4 https://www.channel4.com/programmes/father-christmas devine -d dl --no-folder ALL4 https://www.channel4.com/programmes/father-christmas ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ C:\Users\Win11X-DL\git\devine-333-poetry-n_m3u8dl_re\devine\devine\commands\ │ │ dl.py:541 in result │ │ │ │ 538 │ │ │ │ │ │ │ ) │ │ 539 │ │ │ │ │ │ │ for i, track in enumerate(title.tracks) │ │ 540 │ │ │ │ │ │ )): │ │ ❱ 541 │ │ │ │ │ │ │ download.result() │ │ 542 │ │ │ except KeyboardInterrupt: │ │ 543 │ │ │ │ console.print(Padding( │ │ 544 │ │ │ │ │ ":x: Download Cancelled...", │ │ │ │ C:\Users\Win11X-DL\AppData\Local\Programs\Python\Python312\Lib\concurrent\fu │ │ tures\_base.py:449 in result │ │ │ │ 446 │ │ │ │ if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]: │ │ 447 │ │ │ │ │ raise CancelledError() │ │ 448 │ │ │ │ elif self._state == FINISHED: │ │ ❱ 449 │ │ │ │ │ return self.__get_result() │ │ 450 │ │ │ │ │ │ 451 │ │ │ │ self._condition.wait(timeout) │ │ 452 │ │ │ │ C:\Users\Win11X-DL\AppData\Local\Programs\Python\Python312\Lib\concurrent\fu │ │ tures\_base.py:401 in __get_result │ │ │ │ 398 │ def __get_result(self): │ │ 399 │ │ if self._exception: │ │ 400 │ │ │ try: │ │ ❱ 401 │ │ │ │ raise self._exception │ │ 402 │ │ │ finally: │ │ 403 │ │ │ │ # Break a reference cycle with the exception in self._ │ │ 404 │ │ │ │ self = None │ │ │ │ C:\Users\Win11X-DL\AppData\Local\Programs\Python\Python312\Lib\concurrent\fu │ │ tures\thread.py:59 in run │ │ │ │ 56 │ │ │ return │ │ 57 │ │ │ │ 58 │ │ try: │ │ ❱ 59 │ │ │ result = self.fn(*self.args, **self.kwargs) │ │ 60 │ │ except BaseException as exc: │ │ 61 │ │ │ self.future.set_exception(exc) │ │ 62 │ │ │ # Break a reference cycle with the exception 'exc' │ │ │ │ C:\Users\Win11X-DL\git\devine-333-poetry-n_m3u8dl_re\devine\devine\core\trac │ │ ks\track.py:242 in download │ │ │ │ 239 │ │ │ │ │ license_widevine=prepare_drm │ │ 240 │ │ │ │ ) │ │ 241 │ │ │ elif self.descriptor == self.Descriptor.DASH: │ │ ❱ 242 │ │ │ │ DASH.download_track( │ │ 243 │ │ │ │ │ track=self, │ │ 244 │ │ │ │ │ save_path=save_path, │ │ 245 │ │ │ │ │ save_dir=save_dir, │ │ │ │ C:\Users\Win11X-DL\git\devine-333-poetry-n_m3u8dl_re\devine\devine\core\mani │ │ fests\dash.py:544 in download_track │ │ │ │ 541 │ │ │ │ 542 │ │ if drm: │ │ 543 │ │ │ progress(downloaded="Decrypting", completed=0, total=100) │ │ ❱ 544 │ │ │ drm.decrypt(save_path) │ │ 545 │ │ │ track.drm = None │ │ 546 │ │ │ events.emit( │ │ 547 │ │ │ │ events.Types.TRACK_DECRYPTED, │ │ │ │ C:\Users\Win11X-DL\git\devine-333-poetry-n_m3u8dl_re\devine\devine\core\drm\ │ │ widevine.py:293 in decrypt │ │ │ │ 290 │ │ │ p.wait() │ │ 291 │ │ │ │ │ 292 │ │ │ if p.returncode != 0 or had_error: │ │ ❱ 293 │ │ │ │ raise subprocess.CalledProcessError(p.returncode, argu │ │ 294 │ │ │ │ │ 295 │ │ │ path.unlink() │ │ 296 │ │ │ if not stream_skipped: │ ╰──────────────────────────────────────────────────────────────────────────────╯ CalledProcessError: Command '['input=C:\\Users\\WIN11X~1\\AppData\\Local\\Temp\\devine\\Audio_80d2799e.mp4,s tream=0,output=C:\\Users\\WIN11X~1\\AppData\\Local\\Temp\\devine\\Audio_80d2799e _decrypted.mp4,output_format=MP4', '--enable_raw_key_decryption', '--keys', 'label=0:key_id=da01f616423372e54af58b99c17cda2f:key=139d7554798bc9f7686dde2d4ad fef60,label=1:key_id=00000000000000000000000000000000:key=139d7554798bc9f7686dde 2d4adfef60', '--temp_dir', WindowsPath('C:/Users/WIN11X~1/AppData/Local/Temp/devine')]' returned non-zero exit status 3221225477. ❌ Download Failed... An unexpected error occurred in one of the download workers. Binary call failed, Process exit code: 3221225477 See the error trace above for more information. (devine-py3.12) PS C:\Users\Win11X-DL\git\devine-333-poetry-n_m3u8dl_re\devine> -
Issue with CBS in that the full length of the video is not being downloaded with Devine
Code:devine dl cbs https://www.cbs.com/shows/video/xUe44fW5zYP0alEG2PkGhVIrojCQ_3FM/
[Attachment 84360 - Click to enlarge]
If I run the same command manually using N_m3u8DL-RE the video is it's proper length.
Code:N_m3u8DL-RE.exe "https://vod-gcs-cedexis.cbsaavideo.com/intl_vms/2024/12/18/2396504643702/3045444_cenc_precon_dash/stream.mpd" --save-name "S38E71" --key 7f47d1b575c54eb8b1123b10f4f1edbc:313175bdcd25e0576526c9e29c738552 -M format=mkv:muxer=mkvmerge -mt -sv res=1080:for=best -sa best -ss all
[Attachment 84361 - Click to enlarge]
Anyone having the same issue with CBS ? -
mine look fine 18 mins 52s
Code:Format : Matroska Format version : Version 4 File size : 356 MiB Duration : 18 min 52 s Overall bit rate : 2 636 kb/s Frame rate : 29.970 FPS Movie name : The Bold and The Beautiful S38E71 12/26/2024 Writing application : mkvmerge v63.0.0 ('Everything') 32-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4
[Attachment 84365 - Click to enlarge] -
Maybe you jumped forward in time as probably at some point soon we will have only six minutes of a TV show and 24 minutes of commercials for each half hour. But with some shows that might be a mercy. I remember B&B and it was the one soap that was so aggravating I wanted to throw the TV out the window. Thankfully we dumped it and never looked back and as a Soap Fan I never saw that happening. I hope someone can revive the Plex service for Devine or Freevine as "Falcon Crest" and "Knots Landing" is on there.
No issues here with CBS. Do you have issues with other Services? If you do, I guess it could be with:
downloader: aria2c
aria2c:
max_concurrent_downloads: 1
file_allocation: prealloc
from your devine cfg --list I had to fudge that around personally to get iP to work correctly. That is what it is at now. May not be the fix, but thought I would bring it up. Good luck! -
Not sure what's going on really. I tried all 3 different downloaders and got the same 6 min video file. It's only an issue with CBS, all other services work fine. Anyway I've got my standalone CBS script working now using stabby's Devine Android app logic, so it's all good.
Hello,
I set Devine up and copied stabbedbybrick's code but keep getting errors that seem to be vpn/proxy-related (SSL). I used available free vpn versions and then downloaded Sawoot's hola-proxy exe and put it in the main Devine folder. The code with the error is as follows, I use bold for the parts I haven't find answers for yet (the example has the episode that is no longer available):
Not sure if this is relevant, but I omitted setting up Profile (cookies and credentials) and Key Vaults and did not modify anything in stabbedbybrick's code. I also tried their code for CTV service and had no problem getting the keys.Code:─────────────────────────────── Service: CBS ─────────────────────────────── Service is Geoblocked in your region, getting a Proxy to us ──────────────────── Series: The Young and The Restless ──────────────────── 1 Season, 1 Episode ─────────────── The Young and The Restless S52E54 12/19/2024 ─────────────── ThePlatform request failed: max() iterable argument is empty, falling back to standard manifest 1 Video └── [H.264, SDR] | en-US | 1920x1080 @ 3472 kb/s, 29.970 FPS ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • FAILED 1 Audio └── [AAC] | en-US | 2.0 | 130 kb/s | United States ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED 1 Subtitle └── [WVTT] | en-US | United States ⠴ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ • --:-- • SKIPPED 2 Chapters ├── 00:00:00.000 └── 00:36:06.000 | Credits Widevine(AAAAWHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADgIARIQeWxqsHz1TZ6gx sz516OFjCIgWVBIZXFZWFJsMzh3MFM5eUxUdkpnOTFmMW5PaEtCUFI4AQ==) └── An exception occurred in the Service's license function: HTTPSConnectionPool(host='cbsi.live.ott.irdeto.com', port=443): Max retries exceeded with url: /widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Def… (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Basic Constraints of CA cert not marked critical (_ssl.c:1018)'))) ❌ Download Failed... HTTPSConnectionPool(host='cbsi.live.ott.irdeto.com', port=443): Max retries exceeded with url: /widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default& ContentId=YPHeqYXRl38w0S9yLTvJg91f1nOhKBPR&at=ABBsaBMagMmYLUc9iXB0lXEK sUQ0%2FMwRn6z3Tg0KKQaH7Q6QGqJcABwlBP4XiMR1b0Q%3D&format=SMIL&assetType s=HLS_AES%7CDASH_LIVE%7CDASH_CENC%7CDASH_CENC_HDR10%7CDASH_LIVE%7CDASH _TA%7CDASH_CENC_PS4&formats=MPEG-DASH%2CMPEG4%2CM3U (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Basic Constraints of CA cert not marked critical (_ssl.c:1018)')))
I read the config documentation but am unsure how to use my proxy. Is it just adding this to the config.yaml or must something else be edited?
I'd appreciate any tips.Code:proxy: us: "proxy"
this may sound like a stupid question but im a little confused on what im doing here is there anyone that could organize the steps\tutorial in order so that i figure out what im doing right?
i know there's a github with steps on there and i got a few things installed (such as the required softwares, services, made the yaml files, downloaded the services folder off of github). but im still stuck on what im supposed to do afterwards so im hoping one of yall could help me figure out what i did wrong -
Getting error when trying to use AMZN
Code:Traceback (most recent call last) ──────────────────────╮ │ in _run_module_as_main:198 │ │ in _run_code:88 │ │ │ │ in <module>:7 │ │ │ │ C:\Users\\AppData\Roaming\Python\Python312\site-packages\click\core. │ │ py:1157 in __call__ │ │ │ │ C:\Users\\AppData\Roaming\Python\Python312\site-packages\click\core. │ │ py:1078 in main │ │ │ │ C:\Users\\AppData\Roaming\Python\Python312\site-packages\click\core. │ │ py:1688 in invoke │ │ │ │ C:\Users\\AppData\Roaming\Python\Python312\site-packages\click\core. │ │ py:1688 in invoke │ │ │ │ py:1657 in _process_result │ │ │ │ C:\Users\\AppData\Roaming\Python\Python312\site-packages\click\core. │ │ py:783 in invoke │ │ │ │ C:\Users\\AppData\Local\Programs\Python\Python312\Lib\site-packages\ │ │ devine\commands\dl.py:301 in result │ │ │ │ 298 │ │ │ │ self.log.info("Authenticated with Service") │ │ 299 │ │ │ │ 300 │ │ with console.status("Fetching Title Metadata...", spinner="dot │ │ ❱ 301 │ │ │ titles = service.get_titles() │ │ 302 │ │ │ if not titles: │ │ 303 │ │ │ │ self.log.error("No titles returned, nothing to downloa │ │ 304 │ │ │ │ sys.exit(1) │ │ │ │ C:\Users\\AppData\Local\devine\services\AMZN\__init__.py:130 in │ │ get_titles │ │ │ │ 127 │ │ │ │ 128 │ │ title_metadata = self.session.post(url='https://atv-ps-eu.prim │ │ 129 │ │ │ │ ❱ 130 │ │ if title_metadata['catalogMetadata']['catalog']['entityType'] │ │ 131 │ │ │ │ │ 132 │ │ │ for manifest_json in title_metadata['playbackUrls']['urlSe │ │ 133 │ │ │ │ if title_metadata['playbackUrls']['urlSets'][manifest_ │ ╰──────────────────────────────────────────────────────────────────────────────╯ KeyError: 'catalogMetadata' -
Honestly, your answer is even in this thread! So I would search more, but this may help a bit, or a lot!
https://forum.videohelp.com/threads/414487-Video-guide-to-get-your-Win-system-set-up-for#post2735083 -
i notice it mentions "device_client_id_blob" and the device private key on the devine website thing with many steps on it (this: https://telegra.ph/Devine-On-Win-v003-04-10). it includes a step where "i think" you could convert it into a wvd file. ive been looking around for the device files in my computer for it and i dont see it in my computer. how do i get that
CBC have changed one or more of their api endpoints. The authentication flow in stabby's code is one of the longest I've seen, especially in a Devine context, so hopefully it's not a complete re-write needed. I've started fiddling around with it but I doubt I'll be able to solve it completely before the master does
Yes, in fact, yt-dlp is silent on CBC, ffmpeg works
Code:ffmpeg -hide_banner -i "https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/index-aes.m3u8?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4&ewid=83317&manifestType=desktop&hdnea=st=1735641712~exp=1735641832~acl=*~hmac=8d6ab1b61ad3975b8e82f0ab32211f12a676897de147b8a51b1f99280b827df5&EIA608ClosedCaptions=true&lang=en" -c copy 1.ts mime type is not rfc8216 compliant [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [hls @ 0000021b55cbf200] Skip ('#EXT-X-INDEPENDENT-SEGMENTS') [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_14_0.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_13_0.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_4.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_5.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_6.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_7.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_8.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [https @ 0000021b5625eec0] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_9.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Skip ('#EXT-X-VERSION:4') [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_14_0_0.aac?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_14_0_1.aac?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_13_0_0.aac?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_13_0_1.aac?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_4_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_5_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_6_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_7_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_8_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] Opening 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/serve.key?hdntl=exp=1735728135~acl=/*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208&aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls' for reading [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_9_0.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=0&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading Input #0, hls, from 'https://cbcrcott-aws-gem.akamaized.net/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/index-aes.m3u8?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4&ewid=83317&manifestType=desktop&hdnea=st=1735641712~exp=1735641832~acl=*~hmac=8d6ab1b61ad3975b8e82f0ab32211f12a676897de147b8a51b1f99280b827df5&EIA608ClosedCaptions=true&lang=en': Duration: 00:21:48.17, start: 2.069656, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 6501902 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:2: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 6501902 Program 1 Metadata: variant_bitrate : 4187805 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:3: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 4187805 Program 2 Metadata: variant_bitrate : 2990710 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:4: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 960x540 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 2990710 Program 3 Metadata: variant_bitrate : 1737612 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:5: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 1737612 Program 4 Metadata: variant_bitrate : 967032 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:6: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 967032 Program 5 Metadata: variant_bitrate : 714221 Stream #0:0(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (visual impaired) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English (Descriptive) Stream #0:7: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 416x234 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 714221 Stream mapping: Stream #0:2 -> #0:0 (copy) Stream #0:0 -> #0:1 (copy) Output #0, mpegts, to '1.ts': Metadata: encoder : Lavf61.7.100 Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn Metadata: variant_bitrate : 6501902 Stream #0:1(eng): Audio: aac (LC), 44100 Hz, stereo, fltp, 191 kb/s (default) Metadata: id3v2_priv.com.apple.streaming.transportStreamTimestamp: \x00\x00\x00\x00\x00\x02\xd7\x9d comment : English Press [q] to stop, [?] for help [hls @ 0000021b55cbf200] Opening 'crypto+https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index_4_1.ts?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_msn=1&aka_hls_version=4&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4' for reading [hls @ 0000021b55cbf200] No longer receiving playlist 3 ('https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_5.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4') [hls @ 0000021b55cbf200] No longer receiving playlist 4 ('https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_6.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4') [hls @ 0000021b55cbf200] No longer receiving playlist 5 ('https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=%2f*~data=hdntl~hmac=cd049d4aae8ff7239845a584318ac894109f8dfc29252945c7c28592cb144208/out/v1/46017913e25a4ffe8ac18a75fae34497/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/17ef4caf6fa64217822b2d16e074e570/6baf985d549245c48f39e42930e10a5e/index-aes_7.m3u8?aka_me_session_id=AAAAAAAAAAAHHHVnAAAAAKAftyq3ZiuxfbvfjiI4IuLqjywjSceq6%2fwuhXPQN1VV9Wc%2f95j1EOjw1efsyhVXvkBxpBMQ5GZV&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4') [hls @ 0000021b55cbf200] No longer receiving playlist 6 ('https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1735728135~acl=% -
Using N_m3u8DL-RE is still my go to.
Changing m3u8 url as iamghost said before, gets you 1080 version - "M3u8 link just Change “desktop” to “smarttv” for 1080p"
https://forum.videohelp.com/threads/408746-gem-cbc-ca-1080p-streams#post2754000
Code:(env) PS C:\dl\Downloads> N_m3u8DL-RE "https://cbcrcott-aws-gem.akamaized.net/out/v1/5033afccf83d486c886304c535035167/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/index-aes.m3u8?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4&ewid=83317&manifestType=smarttv&hdnea=st=1735648963~exp=1735649083~acl=*~hmac=d1c965cad6d1ce78f2bb354fa9db22cddf206c027d11312ca1d6e60fe3fdefe1&EIA608ClosedCaptions=true&lang=en" --save-name "Killing Eve - s01e01" -M format=mkv 07:43:59.218 INFO : N_m3u8DL-RE (Beta version) 20240630 07:43:59.243 INFO : Loading URL: https://cbcrcott-aws-gem.akamaized.net/out/v1/5033afccf83d486c886304c535035167/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/index-aes.m3u8?pckgrp=bf5b9c2800b7e86d48330ceb5add54a4&ewid=83317&manifestType=smarttv&hdnea=st=1735648963~exp=1735649083~acl=*~hmac=d1c965cad6d1ce78f2bb354fa9db22cddf206c027d11312ca1d6e60fe3fdefe1&EIA608ClosedCaptions=true&lang=en 07:43:59.379 INFO : New version detected! v0.3.0-beta 07:43:59.544 INFO : Content Matched: HTTP Live Streaming 07:43:59.546 INFO : Parsing streams... 07:43:59.547 WARN : Master List detected, try parse all streams 07:43:59.565 WARN : Writing meta json 07:43:59.567 INFO : Extracted, there are 8 streams, with 5 basic streams, 3 audio streams, 0 subtitle streams 07:43:59.568 INFO : Vid 1920x1080 | 6811 Kbps | 29.97 | avc1.640028 07:43:59.570 INFO : Vid 1280x720 | 3951 Kbps | 29.97 | avc1.4D401F 07:43:59.574 INFO : Vid 1280x720 | 2961 Kbps | 29.97 | avc1.4D401F 07:43:59.576 INFO : Vid 960x540 | 2191 Kbps | 29.97 | avc1.4D401F 07:43:59.577 INFO : Vid 640x360 | 1311 Kbps | 29.97 | avc1.42C01E 07:43:59.578 INFO : Aud audio_2 | English | eng | 6CH 07:43:59.579 INFO : Aud audio_0 | English | eng | 2CH 07:43:59.580 INFO : Aud audio_1 | English | eng | 2CH 07:44:06.167 INFO : Parsing streams... 07:44:06.555 INFO : Selected streams: 07:44:06.556 INFO : Vid *AES_128 1920x1080 | 6811 Kbps | 29.97 | avc1.640028 | 851 Segments | ~42m34s 07:44:06.557 INFO : Aud audio_2 | English | eng | 6CH | 851 Segments | ~42m34s 07:44:06.558 WARN : Writing meta json 07:44:06.571 INFO : Save Name: Killing Eve - s01e01 07:44:06.573 WARN : MuxAfterDone is detected, binary merging is automatically enabled 07:44:06.576 INFO : Start downloading...Vid 1920x1080 | 6811 Kbps | 29.97 | avc1.640028 07:44:06.860 WARN : Reading media info... 07:44:07.660 INFO : [0x1e1]: Video, h264 (High) ([27][0][0][0]), 1920x1080, 29.97 fps 07:45:12.459 INFO : Binary merging... 07:45:17.194 INFO : Start downloading...Aud audio_2 | English | eng | 6CH 07:45:17.329 WARN : Reading media info... 07:45:17.393 INFO : NaN: Audio, eac3, 192 kb/s 07:45:48.998 INFO : Binary merging... 07:45:49.327 WARN : Killing Eve - s01e01.ts 07:45:49.328 WARN : Killing Eve - s01e01.eng.ts 07:45:49.328 WARN : Muxing to Killing Eve - s01e01.MUX.mkv 07:45:49.399 WARN : [eac3 @ 0000013577962900] Estimating duration from bitrate, this may be inaccurate 07:45:56.889 WARN : Cleaning files... 07:45:57.200 WARN : Rename to Killing Eve - s01e01.mkv 07:45:57.202 INFO : Done
CBC has been nothing but a huge pain in the ass, so you'd be doing me and others here a huge favor if you solved it
I've been working on other things so these services have been put on the backburner for the time being, and I'm not sure when I'll get around to fixing it. I took a quick peek and it looks like the token endpoint is dead and the alternative requires auth codes and other nonsense. -
aight so everything seems to be working but when it came to multiplexing it said this
[Attachment 84497 - Click to enlarge]
[Attachment 84498 - Click to enlarge]
UPDATE: redacted, got it solvedLast edited by iamkennethy_; 31st Dec 2024 at 20:48.
Don't know whether can be useful: I had to reinstall Devine and I managed to do it in the end, but one of the dependencies of the file poetry.lock is old and needs to be changed. "Marisa-trie" is 1.2.1 now, not 1.1.0.
I got exactly the same ERROR when running the Devine/shaka in Windows Sandbox ...
as soon as the files ware downloaded, for some strange reason Windows deleted them ....
and Shaka could not decrypt ..... tried old version, new version just in case it is Shaka, but it must be
Windows Sandbox restrictions of some sort of ......
I have not found a way to execute the commands as regular user either
(everything is executed as Administrator) in Windows Sandbox
for some reason (running Windows 11 23H2) ....
Which environment are you running Devine in? -
Hi,
I'm new here, lurker since 1 week ago that I've been slow and calmly reading, learning and trying to run this tool. Yesterday I finally succeeded. So I'm happy with that, specially knowing that I don't have a programing background
I want to say thank you to everyone who has been part of this project or has been active on this thread. Thanks to @pssh for his tutorials, and specially thanks to @stabbedbybrick for his services and his tireless work and constant answer here.
___
Saying that, I want to ask if anyone know how to install CCExtractor and its prerequisites in a Linux environment without root privileges (?). I installed this tool in a seedbox that I don't have sudo permissions. The system runs in a "Debian 5.10.209-2 (2024-01-31) x86_64".
The tool runs perfectly, I can download videos without problem if I just download VTT subtitles, but I would love to have this tool working 100% so I can make use of the full potential devine.
Best, -
This should work with sudoCode:
#-------------- #LATEST #GPAC; #-------------- sudo apt install -y \ libglew-dev \ libglfw3-dev \ cmake \ gcc \ libcurl4-gnutls-dev \ tesseract-ocr \ libtesseract-dev \ libleptonica-dev \ clang \ libclang-dev \ autoconf \ build-essential \ pkg-config \ g++ \ git \ yasm cd ~/git git clone https://github.com/gpac/gpac.git cd gpac ./configure make -j$(nproc) ./bin/gcc/MP4Box -version; ./bin/gcc/gpac -version; sudo make install MP4Box -version gpac -version #------------------------------------------------------------- #v0.93 (Aug 16, 2021) CCExtractor [needs GPAC installed] !!!! #------------------------------------------------------------- cd ~/git git clone https://github.com/CCExtractor/ccextractor.git cd ~/git/ccextractor/ git checkout c7ebd45 cd ~/git/ccextractor/linux make clean sudo make uninstall make distclean ./autogen.sh ./configure --without-rust make -j$(nproc) ./ccextractor --version sudo make install ccextractor --version cd ~
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 13:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 22:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 02:21 -
H.264 for archival and editing - no go?
By malling in forum Capturing and VCRReplies: 8Last Post: 20th Aug 2019, 00:51 -
Movie music too loud but dialogue too quiet fix needed
By hokkom in forum AudioReplies: 121Last Post: 4th May 2019, 09:51
