Is there a way to get these without having a Premium account? I can download the 720p videos fine, but I can't upgrade to Premium because my bank card doesn't have a CA billing address. If being actually logged in/sending Premium credentials is necessary, then I'm dead in the water, but if it's just a question of a different link structure...
Or, alternatively, does anyone know of a solution for the card billing address issue?
EDIT: It seems that with CBC GEM, all you have to do is literally enter the url of the episode/movie into yt-dlp as input and it grabs the 1080p stream.
EDIT2: A different problem - the above mentioned method grabs only stereo 192k audio, but there are 5.1 384k streams, like in BTN's rip of Dragon's Den S15E01 which aren't available through this method. Any ideas on how to get that one? Or is it a premium-only feature?
Results 1 to 22 of 22
Seems as though CBC has made a change overnight. I no longer can get the 1080p streams. The player video quality cog shows 'Low' and 'Average' but the 'High/1080p' is greyed out.
Follow this issue on the yt-dlp github regarding cbc gem changes, no fix yet - https://github.com/yt-dlp/yt-dlp/issues/6395
good, somebody found a fix: https://github.com/yt-dlp/yt-dlp/issues/6395#issuecomment-1462442492
Just add /media/ after https://gem.cbc.ca/ -
Please for dummies such as myself please give instructions on how to download from CBC Gem. I do remember I tried that media trick at one point and it worked but either it doesn't work now or I have forgotten exactly how to get it. I usually go for 640 x 360 quality with English audio.
Thank you in advance and if it is really complex I probably won't be able to accomplish it but I will try. -
I am happy with 540p any higher the files take up too much hard drive space. But it is good for those who desire 1080p can get it if they want.
I just use mkvtoolnix to mux them into a mkv container. Takes a few seconds.
I'm sure the fix will be included in the next release of yt-dlp. -
I have had a problem today with CBC Gem via YT-DLP. The video seems to download but fails in the muxing stage and you end up with a 35 minute video instead of 44:10
Thanks in advance for any advice pertaining to this matter.Code:Microsoft Windows [Version 10.0.22631.4317] (c) Microsoft Corporation. All rights reserved. C:\Users\sheld\Desktop\YT-DLP Video Downloader>yt-dlp --username --password --verbose --no-overwrites --write-sub -S "res:540" https://gem.cbc.ca/media/heartland/s18e04 [debug] Command-line config: ['--username', 'PRIVATE', '--password', 'PRIVATE', '--verbose', '--no-overwrites', '--write-sub', '-S', 'res:540', 'https://gem.cbc.ca/media/heartland/s18e04'] [debug] Encodings: locale cp1252, fs utf-8, pref cp1252, out utf-8, error utf-8, screen utf-8 [debug] yt-dlp version stable@2024.10.22 from yt-dlp/yt-dlp [67adeb7ba] (win_exe) [debug] Python 3.8.10 (CPython AMD64 64bit) - Windows-10-10.0.22631-SP0 (OpenSSL 1.1.1k 25 Mar 2021) [debug] exe versions: ffmpeg 6.1.1-full_build-www.gyan.dev (setts), ffprobe 6.1.1-full_build-www.gyan.dev [debug] Optional libraries: Cryptodome-3.21.0, brotli-1.1.0, certifi-2024.08.30, curl_cffi-0.5.10, mutagen-1.47.0, requests-2.32.3, sqlite3-3.35.5, urllib3-2.2.3, websockets-13.1 [debug] Proxy map: {} [debug] Request Handlers: urllib, requests, websockets, curl_cffi [debug] Loaded 1839 extractors [debug] Using fake IP 99.226.169.81 (CA) as X-Forwarded-For [debug] Loading cbcgem.claims_token from cache [gem.cbc.ca] Extracting URL: https://gem.cbc.ca/media/heartland/s18e04 [gem.cbc.ca] heartland/s18e04: Downloading JSON metadata [gem.cbc.ca] heartland/s18e04: Downloading JSON metadata [gem.cbc.ca] heartland/s18e04: Downloading m3u8 information [debug] Sort order given by user: res:540 [debug] Formats sorted by: hasvid, ie_pref, res:540(540.0), lang, quality, fps, hdr:12(7), vcodec:vp9.2(10), channels, acodec, size, br, asr, proto, vext, aext, hasaud, source, id [debug] Default format spec: bestvideo*+bestaudio/best [info] heartland/s18e04: Downloading 1 format(s): hls-2191+hls-audio_2-English [info] There are no subtitles for the requested languages [debug] Invoking hlsnative downloader on "https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1729707252~acl=%2f*~data=hdntl~hmac=3b8c2f3e5b96445e96d483377d1575d679966eab0813925b289764d4b64894cf/out/v1/d6eccc4ae1ce4e1b861fc4f144d935c5/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/436ea5bccb784b8491274fc697589c82/6baf985d549245c48f39e42930e10a5e/index-aes_4.m3u8?aka_me_session_id=AAAAAAAAAAD0PBlnAAAAAB5rOW3YDZup2BVdO0mfMscY7TpTiv3Nxb0cWD+d4yJkzxn70cfCtAc+aY0ApI7WC31DJBauX9ut&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4" [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 883 [download] Destination: Into the Unknown [heartland⧸s18e04].fhls-2191.mp4 [debug] File locking is not supported. Proceeding without locking [download] 100% of 599.53MiB in 00:10:27 at 978.78KiB/s [debug] Invoking hlsnative downloader on "https://cbcrcott-aws-gem.akamaized.net/hdntl=exp=1729707252~acl=%2f*~data=hdntl~hmac=3b8c2f3e5b96445e96d483377d1575d679966eab0813925b289764d4b64894cf/out/v1/d6eccc4ae1ce4e1b861fc4f144d935c5/026bf27581e640c4b4fb78ae5aaa5021/4992c413374a4be4af23a7b5453f28df/436ea5bccb784b8491274fc697589c82/6baf985d549245c48f39e42930e10a5e/index-aes_16_0.m3u8?aka_me_session_id=AAAAAAAAAAD0PBlnAAAAAB5rOW3YDZup2BVdO0mfMscY7TpTiv3Nxb0cWD+d4yJkzxn70cfCtAc+aY0ApI7WC31DJBauX9ut&aka_media_format_type=hls&pckgrp=bf5b9c2800b7e86d48330ceb5add54a4" [hlsnative] Downloading m3u8 manifest [hlsnative] Total fragments: 883 [download] Destination: Into the Unknown [heartland⧸s18e04].fhls-audio_2-English.mp4 [download] 100% of 60.72MiB in 00:01:40 at 617.34KiB/s [debug] ffmpeg command line: ffprobe -show_streams "file:Into the Unknown [heartland⧸s18e04].fhls-audio_2-English.mp4" [Merger] Merging formats into "Into the Unknown [heartland⧸s18e04].mp4" [debug] ffmpeg command line: ffmpeg -y -loglevel repeat+info -i "file:Into the Unknown [heartland⧸s18e04].fhls-2191.mp4" -i "file:Into the Unknown [heartland⧸s18e04].fhls-audio_2-English.mp4" -c copy -map 0:v:0 -map 1:a:0 -movflags +faststart "file:Into the Unknown [heartland⧸s18e04].temp.mp4" [debug] ffmpeg version 6.1.1-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12.2.0 (Rev10, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --pkg-config=pkgconf --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-dxva2 --enable-d3d11va --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 58. 29.100 / 58. 29.100 libavcodec 60. 31.102 / 60. 31.102 libavformat 60. 16.100 / 60. 16.100 libavdevice 60. 3.100 / 60. 3.100 libavfilter 9. 12.100 / 9. 12.100 libswscale 7. 5.100 / 7. 5.100 libswresample 4. 12.100 / 4. 12.100 libpostproc 57. 3.100 / 57. 3.100 Input #0, mpegts, from 'file:Into the Unknown [heartland⧸s18e04].fhls-2191.mp4': Duration: 00:44:10.31, start: 2.095867, bitrate: 1897 kb/s Program 1 Stream #0:0[0x1e1]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(progressive), 960x540 [SAR 1:1 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn [eac3 @ 000001c12ad188c0] Estimating duration from bitrate, this may be inaccurate Input #1, eac3, from 'file:Into the Unknown [heartland⧸s18e04].fhls-audio_2-English.mp4': Duration: 00:44:13.02, start: 0.000000, bitrate: 192 kb/s Stream #1:0: Audio: eac3, 48000 Hz, 5.1(side), fltp, 192 kb/s [mp4 @ 000001c12b445cc0] track 1: codec frame size is not set Output #0, mp4, to 'file:Into the Unknown [heartland⧸s18e04].temp.mp4': Metadata: encoder : Lavf60.16.100 Stream #0:0: Video: h264 (Main) (avc1 / 0x31637661), yuv420p(progressive), 960x540 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn Stream #0:1: Audio: eac3 (ec-3 / 0x332D6365), 48000 Hz, 5.1(side), fltp, 192 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy) Press [q] to stop, [?] for help size= 0kB time=-00:00:00.03 bitrate= -0.0kbits/s speed=N/A size= 167936kB time=00:11:30.75 bitrate=1991.6kbits/s speed=1.38e+03x size= 331008kB time=00:22:40.92 bitrate=1992.5kbits/s speed=1.36e+03x size= 478208kB time=00:32:46.56 bitrate=1992.0kbits/s speed=1.3e+03x size= 480000kB time=00:32:53.82 bitrate=1992.2kbits/s speed= 889x size= 485120kB time=00:33:14.49 bitrate=1992.5kbits/s speed= 733x [vost#0:0/copy @ 000001c12b36b040] Error submitting a packet to the muxer: Invalid data found when processing input [out#0/mp4 @ 000001c12b37b280] Error muxing a packet [mp4 @ 000001c12b445cc0] Starting second pass: moving the moov atom to the beginning of the file [out#0/mp4 @ 000001c12b37b280] video:469279kB audio:50095kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.256329% size= 520706kB time=00:35:35.36 bitrate=1997.6kbits/s speed= 567x Conversion failed! ERROR: Postprocessing: Conversion failed! Traceback (most recent call last): File "yt_dlp\YoutubeDL.py", line 3560, in process_info File "yt_dlp\YoutubeDL.py", line 3744, in post_process File "yt_dlp\YoutubeDL.py", line 3726, in run_all_pps File "yt_dlp\YoutubeDL.py", line 3704, in run_pp File "yt_dlp\postprocessor\common.py", line 23, in run File "yt_dlp\postprocessor\common.py", line 128, in wrapper File "yt_dlp\postprocessor\ffmpeg.py", line 840, in run File "yt_dlp\postprocessor\ffmpeg.py", line 330, in run_ffmpeg_multiple_files File "yt_dlp\postprocessor\ffmpeg.py", line 368, in real_run_ffmpeg yt_dlp.postprocessor.ffmpeg.FFmpegPostProcessorError: Conversion failed! C:\Users\sheld\Desktop\YT-DLP Video Downloader>Last edited by Tom Saurus; 22nd Oct 2024 at 14:42. Reason: Additional Information
I am using the version they released on October 22nd, 2024. I thought perhaps it was the fault of my FFMPEG being a 2023 version so I got the newest YT-DLP version put in the folder and I still have this problem. Maybe I should go back to the previous version of YT-DLP and see if there is this problem. Thank you for your input.
about .gem files
By PUOPUO in forum Video Streaming DownloadingReplies: 13Last Post: 11th Jan 2026, 13:43 -
Downloading from CBC canada
By kpt21 in forum Video Streaming DownloadingReplies: 35Last Post: 26th Jul 2021, 13:51 -
Can anyone help me download off CTV/CBC ?
By kristinaz91 in forum Video Streaming DownloadingReplies: 3Last Post: 7th Mar 2021, 17:20 -
Tearing my hair out trying to download various HLS video streams in 1080p
By Videoenthusiat in forum Video Streaming DownloadingReplies: 20Last Post: 23rd Apr 2020, 07:49 -
need help for video from cbc.ca (I'm geoblocked)
By drai in forum Video Streaming DownloadingReplies: 21Last Post: 1st Mar 2018, 06:04
