Page 31 of 63
FirstFirst ... 21 29 30 31 32 33 41 ... LastLast
Results 901 to 930 of 1867
  1. does anyone have a script for cbc-gem?
  2. Originally Posted by bmfexp View Post
    YT-DLP is currently working for CBC Gem. Here is a link to a thread:
    https://forum.videohelp.com/threads/408746-gem-cbc-ca-1080p-streams
  3. Originally Posted by Tom Saurus View Post
    still only grabs 720p for me
  4. Is there a way to automatically switch CDM's if I have multiple? Or maybe a way to generate a new one when needed?
  5. I've tried downloading from ALL4 and ITV and the .mkv files play in VLC & subtitles work, but subtitles don't show up in other apps like mpc-hc, and ffprobe says "Unsupported codec with id 0 for input stream 2" which is the subtitle track. How can I fix this?
  6. Originally Posted by SirBacon View Post
    You can specify cdms for each service if you want in devine.yaml or create a cmd file to replace them when you want you shouldn't really need to replace them unless you burn them tbf.
    I have a lot of device cdms but am still using a really old one
  7. Originally Posted by movid View Post
    Maybe with:
    --sub-format srt
  8. Originally Posted by PunchDrunkL0ve View Post
    Maybe with:
    --sub-format srt
    That works. Wonder why it doesn't do that automatically.
  9. Originally Posted by movid View Post
    Maybe with:
    --sub-format srt
    Needs to be added to the devine.yaml file
    dl:
      sub_format: srt
  10. Originally Posted by PSXman_uk View Post
    Hm, strange. For some reason after downloading about 10-15 episodes it says the license is expired and changing CDM's fixes it.
  11. Originally Posted by PunchDrunkL0ve View Post
    dl:
      sub_format: srt
    But can it depend on the service? Are they all srt?
  12. Originally Posted by movid View Post
    dl:
      sub_format: srt
    VTT is the most common format and --sub-format srt converts all other formats to srt.
  13. Originally Posted by bmfexp View Post
    I have this same problem, I am trying to get 1080p 5.1 like freevine use to do.
  14. Originally Posted by stabbedbybrick View Post
    The easiest route would probably be a batch file in that case. That way, you could batch download whatever from multiple services if you wanted. I might still add the option to input multiple entries, though. Could be useful for particular episodes or movies.
    I'd also recommend any iPlayer users to not update to the latest Devine version (v3.3.3) since it broke the service for some reason.
    Is this still the case?
    if so is the error with 3.3.3
    HTML Code:
    ConnectionError: Failed to request the M3U(8) document.
    Ah from other posts it seems to be the VPN even though i can watch it via browser with the same connection.
    https://forum.videohelp.com/threads/414154-Devine-Modular-Movie-TV-and-Music-Archival-...17#post2741341
  15. Originally Posted by grimeire View Post
    HTML Code:
    Browser and script use different endpoints, and the higher up you go in quality the more restricted they become. Of all the services I've tried, iPlayer definitely has the most aggressive proxy detection. If it helps, I've had best luck with windscribe when it comes to VPN.
  16. Originally Posted by Oldfart1234 View Post
    i've managed to get it to work by recompiling yt-dlp with some fixes, should be in next official release too
  17. Originally Posted by bmfexp View Post
    For once, a streaming service made changes that actually makes it easier for us to get better quality. That's a first
    Looks like DRM protected content is still stuck at 720p, though. At least for free users. If anyone with a premium subscription can confirm or deny this, that'd be great.
    I also forgot to mention I've added ABC iView to the repo, and a small note to the README regarding shaka-packager:
    Originally Posted by README
    Notes:
    If you experience issues with shaka-packager, try downgrading to v2.6.1: https://github.com/shaka-project/shaka-packager/releases/tag/v2.6.1
  18. Does Devine support TTMLv2? Freevee has them but they don't come up with devine dl --list and the Eng CC are not detected by CCExtractor either. Any ideas?
  19. Originally Posted by bmfexp View Post
    Thanks that is awesome. Any idea when the next official release with these fixes will be released?
  20. Originally Posted by PunchDrunkL0ve View Post
    @stabbedbybrick
    Please could you have a look -if my issue is within the remit of this thread? Many thanks.
  21. Originally Posted by PunchDrunkL0ve View Post
    @stabbedbybrick
    Yes, it's supported. But whether they are listed or not depends on if they are available in the manifest or if the service code you're using has those tracks added. For freevee/amazon specifically, you need to add that information manually in the code if they don't show up.
    Since amazon use SDH as type for CC subtitles, that's what I personally use.
    [Attachment 82784 - Click to enlarge]
  22. Originally Posted by stabbedbybrick View Post
    Oh that looks brilliant! Would you be willing to share your service code with me, please! (or at least for the subs?).
  23. Originally Posted by PunchDrunkL0ve View Post
    That's not really possible, I'm afraid. My code is pretty specific to my own environment. But if you have any contact with whoever wrote your service code, tell them that subtitles and their type can be found in the playback response and that they can be added as Subtitle tracks. There, you'll be able to specify SDH, CC, Forced etc.
    A generic example:
    for sub in subtitles:
                tracks.add(
                    Subtitle(
                        id_= # unique id,
                        url= # subtitle URL,
                        codec= # subtitle codec,
                        language= # language code,
                        forced= # True or False taken from sub["displayName"],
                        sdh= # True or False taken from sub["type"]
  24. Originally Posted by stabbedbybrick View Post
    HTML Code:
    Thanks for the reply.
    What Windscribe endpoints are you using? Are you using the free endpoints as they did not work for me.
  25. Originally Posted by grimeire View Post
    I was using the free ones. Some work, some don't. That's just how it goes.
  26. All right, I have a working CBC service with 1080p, DDP5.1:
    [Attachment 82802 - Click to enlarge]
    There are a few of caveats, though:
    1. CCExtractor will fail to extract the subtitles, which in turn will cause the entire process to fail. And I can't find any way to "turn it off", so to speak, without going into the Devine source code. I honestly have no idea why using it wasn't made optional, but it is what it is. The fix is as easy as changing one line of code in `devine/core/tracks.video.py`, but I'm not a fan of publishing code that won't work out of the box. And making this change *might* cause issues for other services in turn.
    2. The audio stream for 5.1 contains some invalid data, which will cause mkvmerge to cough up a few warnings. It still works fine, but worth mentioning.
    3. It currently does not work with the N_m3u8DL-RE branch, and I have no clue why. Default downloaders work fine.
    4. DRM protected content seems limited to 720p no matter what.
    Like I said, I really don't like putting out code that require users to mess around with the source code. But if people are still interested, I guess I can upload it with instructions in the help text. Let me know.
  27. Thank you for making a CBC Service for Devine. As for the 720p limit; a thing to remember about CBC and why I limit my downloads to 540p is that beyond that the files are way to big in size that they would eat up my hard drive space very quickly. I notice that a 44 minute episode on CBC is 631 mb at 540p and you go to 720p it can be over a gigabite per 44 minute episode. Something I am noticing is that all the episodes I have downloaded in my YT-DLP folder shows 44:10 and 631 mb and that makes me think CBC encodes for a certain size not for a certain quality factor. See when I do an encode of my own I use Vidcoder and go for a CF of 20 or 18 and that means if the video has a lot of action that the encoder gives what is need and if you have scenes that don't have as much action it gives you what is needed so the file sizes vary.
  28. Member
    Dec 2022
    Lesotho
    CBC GEM like most other streaming sites target a certain bit rate per resolution. Time x bit rate = size.
  29. Member
    Dec 2022
    Lesotho
    I would be interested please.
    Weird that CCExtractor will fail to extract subs as that's its almost singular role in life.
    The arguments I use to extract subs from CBC shows are as follows.
    ccextractorwinfull.exe "%video%" -autoprogram -trim --norollup -out=webvtt-full
  30. Originally Posted by stabbedbybrick View Post
    I am interested. Thanks.
