I have a family member going to the US so i figured they could bring some stuff over here.
TBCs are impossible to obtain in Argentina (as of writing this there is no listing in MercadoLibre (Argentina's version lf eBay) so i figured i'd ask my family member in the US to get some stuff from me (TBC and maybe a better capture card). Im a newbie to TBCs since my capture card has some kind of correction (Pinnacle Moviebox 710-USB).
So, we use both PAL-N and NTSC in Argentina so i was wondering if any frame TBC sold in the states supports both NTSC and PAL (can be PAL-B since i have a PAL-N to PAL-B transcoder) preferrably costing no more than 400-500 dollars.
Now for the card, what should i get that can support both PAL and NTSC that's better than my Pinnacle 710 USB? The pinnacle outputs raw YUY2 video but the image kinda freezes when it's unstable.
Thanks in advance
Results 1 to 26 of 26
Once the codec is installed, you then choose it in the appropriate section of VDub or AmarecTV and away you go. LAGS and HUFF are about 30-40gb per hour, whereas YUYY2 is uncompressed and over 100gb per hour (IIRC).
Re the TBCs, wait for Lordsmurf to comment; I'm sure he will be along soon! -
That's why i installed Windows 7 on a separate hard drive dedicated tl just capturing.
By the way. I haven't gotten the audio input of the card to work anywhere but Pinnacle Studio 9 (studio 9 sucks at capturing I think it even deinterlaces to 25p without asking). I assume this has something to do with Pinnacle's drivers? -
I meant the raw signal the capture card sends over USB. Both VDub and Amarec report the signal coming in to be a YUY2 stream.
I've always got audio from my 710-USB. I was using the 710-USB drivers from here (I haven't used it for a few months as I am now on a new computer):
http://cdn.pinnaclesys.com/SupportFiles/Hardware_Installer/readmeHW10.htm?utm_source=c...0f005a0a1c0e10 -
The AVT-8710 and clones do support a bunch of systems including NTSC, standard PAL, PAL-M and PAL-N though unless you also have a VCR with TBC where the TBC works with the used system their utility is a bit limited since they don't do much to correct horizontal instability on their own. The right DVD-recorder is an option for NTSC but I don't know if there are any that work with PAL-N directly, whether they work with standard PAL depends on what variant it is - models sold in US/Canada are NTSC only while most Panasonics (and newer Pioneer/Sony) sold in Europe, Australia and at least support both NTSC and PAL - no idea about models in South America.
I believe it's YUY2 because in VDub, for example, if you go to capture pin (or filter, i forgot which one it was) it says PAL 720×576i 25 YUY2 so i believe it's YUY2.
It appears during capture and preview. The tape i'm trying to capture is an old tape from 1991 of a crap VCR recording from OTA. The tape had mold (got it cleaned by a proffesional). When the spots that had mold before appear, i think, it produces some white noise bars. Sometimes it doesn't freeze, sometimes it freezes (drops some frames and picture jumps a bit).
My capture card has a composite video out that outputs an already processed signal (encoded and decoded back to composite all inside the capture card) and it does not freeze on those parts. I assume now this is something software related because Amarec drops a LOT less frames than VDub.
As for DVD Recorders they are super hard to find and Panasonics almost never appear in listing, price is very high and mostly they are NTDC units since many peole import them from the US because it's cheaper. I do have a Philips DVDR 3355 if it helps. It does help a bit but when the signal is too unstable (when it freezes on the capture card), the DVD Recorder shows an annoying OSD (you can't turn it off) -
Thoroughly read and digest this post and others by lordsmurf: https://www.digitalfaq.com/forum/video-restore/2251-tbc-time-base.html
Then contact him for his tested and proven TBCs: https://www.digitalfaq.com/forum/marketplace/8243-sale-tbc-1000-a.html . Note that they're 2-3X your budget, but 1000% better than taking a chance online. A TBC isn't something you just walk into a store a buy!
Who is lordsmurf? A regular here and master of digitalfaq.com. And arguably THE Video Capture Guru. He doesn't just say "I think." He knows, as proven once again in this recent thread: https://forum.videohelp.com/threads/409852-Anyone-know-the-year-on-who-was-made-the-DATAVIDEO-SE-500
I'll call him over before false info and leads start being posting.
lordsmurf, lordsmurf, lordsmurf! Oh...just in case..lordsmurf! LOL -
That's not correct. Just a capture card. That model is variable, but can be good.
In fact, some support PAL-N, and you can capture as PAL-N.
Or you'll end up with a flawed model, a trap newbies fall into due to being too cheap.
But the major issue here should be resolved with TBCs in use.
Win10 and AmaRecTV are the issues there, not VirtualDub, and not the capture card.
It's just an awful program.
(I've been looking at the new Pinnacle 25 as a budget editor, but still would never suggest it for capturing. NLEs al suck at capture, be it Premiere or Final Cut, or whatever.)
Yep.
an el cheapo option is a Panasonic DVD recorder (eg ES-10, ES-15, for PAL, EH-57), used as a passthrough to stabilise the video stream. Of course, best is a VCR with a TBC (eg higher end JVCs) but those mentioned DVD recorders do d a great job with flagging/tearing/glitchy videotapes). Dedicated TBCs will be addressed by Lordsmurf, for sure; he may even be able to sell one to your friend.
But you must be careful not to get a flawed version. Cheap units are usually flawed, but I've seen some eBay auctions where idiots bid up the price of flawed models towards greens (nothing greens have caveats as well, and some shyster sellers are now swapping boards).
I went over this in a long post a while back. AmaRecTV isn't doing anything magic, but slight-of-hand in regards to dropped frames. It's essentially an analog version screen recorder for video games, not too different from OBS in that regard (where OBS is digital source screen recorder). There is nothing special it can do vs. VirtualDub. Both will drop, in the same places, on the same sources. But a key variable is proper settings on both.
The "rule of Sheldon" states that it must be in 3s!Want my help? Ask here! (not via PM!)
The full thread dismantling your lies here: https://forum.videohelp.com/threads/409444-Logilink-USB-Video-Audio-Grabber-%28VG0029%29 -
No wish to sidetrack anything. Just giving the correct information to OP and other readers
That is your opinion, and it's not aligned with my fact checking, nor real-world usage. And I'm not the only one. Your constant crusade against VirtualDub, because your hardware had issues, or you had wrong settings, is somewhat ridiculous now. You found a workaround, and I'm glad it works for you, but it's not flawless, not magic. Y
Again, this is a side topic that doesn't need to be revisited in every thread.Want my help? Ask here! (not via PM!)
Let's keep going to help OP... -
That's because both will act the same. Assuming both are set correctly, the determining factor for drops is not the software, but the hardware and signal.
However, what you're referring to here is double conversion. In that situation, errors get baked in, or partially baked in. Errors can still pass, which is why you still get some drops, also why ES10/15 isn't a true TBC, and still passes errors that results in drops and errors (hence why ES10/15 should always be chased with frame TBC, or at very least weak frame TBC).
No correction occurred. Drops, sync, etc -- that's almost always settings in this exact conversation. In some cases, there are oddities in AmaRecTV that are easily explained by what it is, what it was made to do -- and it was not intended to capture videotapes.Want my help? Ask here! (not via PM!)
Disagreeing is fine.
Continuously being an ass is not.
OP did not ask about AmarecTV.Last edited by lordsmurf; 8th Jun 2023 at 14:57.
Logical fallacy 101. Repeating something doesn't make it true.
I'll stop now replying your non-sense, otherwise the topic will be locked by the administrators. But I will always be there any time you'll spread your bullshit without evidences.
edit: do not edit your posts, otherwise the sense of the replies will be lost -
Would you two guys knock it off? This does not look good for the forum.
Originally Posted by Dellsham
No idea. We can shelve discussion of the capture software, it's a sideshow to the main topic here anyway.
Let's go back to the TBC discussion. Now, were where we ... ah yes ... PAL-N, Cypress, Panasonic ES10/15, Philips recorders. Skip back to my long reply, answer anything asked, add commentary needed.Want my help? Ask here! (not via PM!)
Anybody Know Anything About This TBC?
By companda in forum Capturing and VCRReplies: 2Last Post: 24th May 2023, 01:40 -
Stutter with TBC on
By agisthos in forum RestorationReplies: 10Last Post: 23rd Apr 2021, 11:57 -
The Question of TBC's
By anachronon in forum Capturing and VCRReplies: 26Last Post: 8th Mar 2021, 00:51 -
Adding a new External Capture Card to my Hauppauge Colossus Internal Card
By MounaLafi in forum Capturing and VCRReplies: 30Last Post: 21st Feb 2019, 14:40 -
Is a full frame TBC necessary or VCR's builtin TBC enough?
By DNICE_ONE in forum Capturing and VCRReplies: 37Last Post: 22nd Dec 2018, 15:03
