Results 1 to 11 of 11
  1. Member hydra3333's Avatar
    Oct 2009
    Australia
    Someone I know has a few DVDs which they have purchased and want to watch without benefit of a DVD player.
    I gather something like this commandline may have worked in the past, eg to capture title 4 from the DVD in the J: drive into an mpeg2 .ts file
    "C:\VLC\vlc.exe" dvdsimple:///J:#4 --sout "#standard{access=file,mux=ts,dst=The.Party.01.mpg}" vlc://quit
    Unfortunately, the person does not recall if it ever worked, however now with the latest version of VLC it apparently just appears to start VLC and sit there doing nothing.
    Any advice on getting the VLC commandline working would be appreciated.
    In the meantime the individual found a manual hack approach along these lines:
    Use VLC live to record multiple titles on a DVD to .TS and then convert them to .MPG and then .MP4
    DETERMINE THE CORRECT TITLE NUMBERS ON THE DVD IN CASE THEY ARE NON-INTUITIVE
    Open a DVD (Media, Disc)
    Play, and see the DVD main menu
    Choose a title and click on it to play it
    Press PAUSE and then drag the timeline slider back to 00:00
    Right click on the playing area and click on "Playback" "Title" then observe the playing title number in the Pop-out menu
    Right click on the playing area and click on "Playback" "Stop" then click the "Play" button to go back and see the main menu
    Repeat for next title number to find
    Quit and Restart VLC
    CAPTURE THE CORRECT TITLE NUMBERS to .TS
    From the menu Media, Convert/Save, Disc
    Set the "Starting Position" Title number you determined above, eg 4
    Click the Convert/Save button
    Choose the "Convert" radio button
    In the Profile drop-down, choose "original_video_audio"
    Click Browse to choose the destination path and unique filename for this title on the DVD - you MUST add ".TS" extension to the end for it to work properly
    FIRST READ THE NOTE BELOW then click the Start button
    NOTE: the conversion will start at title number selected eg 4, but it will NOT stop at the end of it
    YOU need to manually click the stop button once that title has converted and it has just started on the next title
    so keep an eye on the PROGRESS BAR and be ready click the "stop" square button
    Then quit VLC and repeat for the NEXT title you noted (do not forget to change the title number at the start )
    CONVERT THE .TS TO USABLE .mpg files
    Now use VideoReDo to QuickStreamFix the .TS files (which unfortunately play jerkily) into "nice" mpeg2 .mpg files
    Now use VideoReDo to trim the new QSF'd .mpg files,
    since you have captured a part of the next title at the end, and save to a new extension, eg .qsf.cut.mpg
    CONVERT THE USABLE .mpg FILES TO .mp4 FILES
    Change the lines
    G:
    CD G:\DVD\name_of_folder
    to point to the disk and folder where you captured the .TS files and QSF's them to .mpg
    Look at the "REM" lines which have "Call :mpg_to_mp4"
    Change their filenames to the ones you have QSF's and trimmed cut (no extension)
    Un-REM the relevant lines
    Check the ffmpeg settings in function :mpg_to_mp4
    for example whether audio dynanorm is to be done or not
    Then run this .bat file to convert the .mpg files to .mp4
  2. Rip with Makemkv, then play the resulting mkv with the player you like
  3. For once, MakeMKV might be the right answer !
    Reminds me of a famous french sketch called “Télémagouilles” from the trio Les Inconnus, where a male comedian impersonating an abysmally stupid blond woman at a parody of a TV game show kept repeating “Stéphanie de Monaco !” to almost every question asked by the host, until a question came for which the answer was actually Stéphanie de Monaco — and she replied “Madonna !”
    https://all-french-gifs.tumblr.com/post/66817094969/photoset_iframe/all-french-gifs/tu...h5zh/500/false
  4. Originally Posted by abolibibelot View Post
    Bow down, God has spoken
  5. Member Skiller's Avatar
    Oct 2013
    Germany
    VOB2MPG, but MKV is able to keep the chapters which a plain MPG file can't. Therefore MKV is the better alternative I'd say.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    hydra3333 Overly complex and fiddly when MakeMKV can save all the titles on a disc or just the main movie complete with all languages and subtitles and chapters - or you can select what components you want and ditch the superfluous tracks. I transferred all my DVD's and Blu rays to my NAS. Put the discs away safely with my physical disc player/s. Simple and quick solution.
    Aug 2006
    VOB2MPG doesn't work if you are running Windows 10 64 bit without some help. See https://forum.videohelp.com/threads/376694-Instructions-for-Running-on-Windows-10#post2430545
  8. Instead of vob2mpg you can use clever Ffmpeg-GUI on Win64
  9. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thank you.
  10. Member hydra3333's Avatar
    Oct 2009
    Australia
    A pity no one had a working VLC commandline.
    Oh well.
    The linux build instructions for makemkv at https://forum.makemkv.com/forum/viewtopic.php?f=3&t=224 did not work for me, I must be doing something wrong.
    Anyway, I ended up with this which seemed to work under Ubuntu 21.10:
    #!/bin/bash
    # to get rid of MSDOS format do this to this file: sudo sed -i s/\\r//g ./filename
    # or, open in nano, control-o and then then alt-M a few times to toggle msdos format off and then save
    echo "Creating the Linux version of makemkv ..."
    set -x
    # 0. Install prerequisites
    set -x
    cd ~/Desktop
    sudo chmod +777 -R *
    sudo apt -y update
    sudo apt install -y apt-utils
    sudo apt install -y debconf debconf-utils
    sudo apt install -y locales
    sudo locale-gen en_AU.UTF-8
    sudo update-locale LANG='en_AU.UTF-8' LANGUAGE='en_AU:en' LC_ALL='en_AU.UTF-8'
    export LANG='en_AU.UTF-8' LANGUAGE='en_AU:en' LC_ALL='en_AU.UTF-8'
    sudo apt upgrade -y
    sudo apt-get install -y git build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev qtbase5-dev zlib1g-dev
    sudo apt install -y curl
    sudo apt install -y wget
    sudo apt install -y nano
    #sudo apt install -y ubuntu-restricted-extras
    sudo apt install -y build-essential
    # The commands below configures alternative for each version and associate a priority with it.
    # The default version is the one with the highest priority, in our case that is gcc-10.
    sudo apt install -y gcc-8 g++-8 gcc-9 g++-9 gcc-10 g++-10 gcc-11 g++-11
    sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-10 100 --slave /usr/bin/g++ g++ /usr/bin/g++-10 --slave /usr/bin/gcov gcov /usr/bin/gcov-10
    sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-9   90 --slave /usr/bin/g++ g++ /usr/bin/g++-9  --slave /usr/bin/gcov gcov /usr/bin/gcov-9
    sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-8   80 --slave /usr/bin/g++ g++ /usr/bin/g++-8  --slave /usr/bin/gcov gcov /usr/bin/gcov-8
    # Later if you want to change the default version use the update-alternatives command:
    # sudo update-alternatives --config gcc
    sudo apt install -y make
    sudo apt install -y automake
    sudo apt install -y cmake
    sudo apt install -y yasm
    sudo apt install -y pkg-config
    sudo apt install -y autogen
    sudo apt install -y autoconf
    sudo apt install -y autoconf-archive
    sudo apt install -y libtool-bin
    sudo apt install -y ninja-build
    sudo apt install -y clang
    #sudo apt install -y git
    read -p "After installing prerequisites, press Enter to continue"
    # 1. download the fdk-aac source from git: https://github.com/mstorsjo/fdk-aac.git and build it
    set -x
    cd ~/Desktop
    sudo rm -vfR fdk-aac_git
    git clone --depth 1 https://github.com/mstorsjo/fdk-aac.git fdk-aac_git
    cd fdk-aac_git
    pwd
    autoreconf -fiv
    export CFLAGS="-fPIC"
    export CXXFLAGS=$CFLAGS
    export CPPFLAGS=$CFLAGS
    export LDFLAGS=$CFLAGS
    PKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig ./configure --prefix=/tmp/ffmpeg --disable-shared --enable-static
    make
    sudo make install
    read -p "After installing fdk-aac, press Enter to continue"
    # 2. download the ffmpeg source from git: git://git.ffmpeg.org/ffmpeg.git and build the libraries
    set -x
    cd ~/Desktop
    sudo rm -vfR ffmpeg_git
    git clone --depth 1 git://git.ffmpeg.org/ffmpeg.git ffmpeg_git
    cd ffmpeg_git
    pwd
    PKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig ./configure --prefix=/tmp/ffmpeg --enable-static --disable-shared --enable-pic --enable-libfdk-aac --disable-doc --disable-programs
    make
    make install
    read -p "After installing ffmpeg library, press Enter to continue"
    # 3. configure and build makemkv-oss:
    set -x
    cd ~/Desktop
    m_ver="1.16.5"
    sudo rm -vfR "makemkv-oss-${m_ver}"
    mkdir -p "makemkv-oss-${m_ver}"
    cd "makemkv-oss-${m_ver}"
    pwd
    #https://forum.makemkv.com/forum/viewtopic.php?f=3&t=224
    #https://www.makemkv.com/download/makemkv-bin-1.16.5.tar.gz
    #https://www.makemkv.com/download/makemkv-oss-1.16.5.tar.gz
    url="https://www.makemkv.com/download/makemkv-oss-${m_ver}.tar.gz"
    curl -4 -H 'Pragma: no-cache' -H 'Cache-Control: no-cache' -H 'Cache-Control: max-age=0' "$url" --retry 50 -L --output "makemkv-oss-${m_ver}.tar.gz" # -L means "allow redirection" or some odd :|
    tar xvzf "makemkv-oss-${m_ver}.tar.gz"
    cd "makemkv-oss-${m_ver}" # again
    pwd
    make
    sudo make install
    read -p "After installing makemkv-oss, press Enter to continue"
    # 4. configure and build makemkv
    set -x
    cd ~/Desktop
    m_ver="1.16.5"
    sudo rm -vfR "makemkv-bin-${m_ver}"
    mkdir -p "makemkv-bin-${m_ver}"
    cd "makemkv-bin-${m_ver}"
    pwd
    url="https://www.makemkv.com/download/makemkv-bin-${m_ver}.tar.gz"
    curl -4 -H 'Pragma: no-cache' -H 'Cache-Control: no-cache' -H 'Cache-Control: max-age=0' "$url" --retry 50 -L --output "makemkv-bin-${m_ver}.tar.gz" # -L means "allow redirection" or some odd :|
    tar xvzf "makemkv-bin-${m_ver}.tar.gz"
    cd "makemkv-bin-${m_ver}" # again
    pwd
    #PKG_CONFIG_PATH=/tmp/ffmpeg/lib/pkgconfig ./configure
    ./configure
    make
    sudo make install
    read -p "After installing makemkv-bin, press Enter to continue"
