I get a 'codec missing or unavailable' error when importing into Premiere. They play in VLC, although it resembles streaming video over a really bad connection, stopping to 'buffer' every half second.Code:Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 495 MiB Duration : 2mn 35s Overall bit rate : 26.8 Mbps Encoded date : UTC 2016-09-14 07:27:51 Tagged date : UTC 2016-10-14 20:49:14 Writing library : Apple QuickTime ©TSC : 2500 ©TSZ : 100 Video ID : 1 Format : Intermediate Codec Codec ID : icod Codec ID/Hint : Apple Duration : 2mn 35s Bit rate mode : Variable Bit rate : 25.2 Mbps Width : 960 pixels Height : 540 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Bits/(Pixel*Frame) : 1.945 Stream size : 466 MiB (94%) Language : English Encoded date : UTC 2016-09-14 07:27:51 Tagged date : UTC 2016-09-14 07:27:51 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : sowt Duration : 2mn 35s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 28.4 MiB (6%) Language : English Encoded date : UTC 2016-09-14 07:27:51 Tagged date : UTC 2016-09-14 07:27:51 Material_Duration : 155104 Material_StreamSize : 29779968 Menu ID : 3 Duration : 2mn 35s Language : English Encoded date : UTC 2016-09-14 07:27:51 Tagged date : UTC 2016-09-14 07:27:51 Stream size : 4
I've never had issues with MOV files in CS before.
Results 1 to 26 of 26
'Intermediate Codec' (fourcc 'icod') seems to be unsupported in Windows.
You'll have to use Apple, or convert into something Premiere can read - preferably a lossless format.
In addition to VLC, it looks like ffmpeg can decode it. -
The problem isn't QuickTime, it's the Apple Intermediate Codec which isn't supported by Premiere on Windows. So you need to transcode it to something Premiere will digest, e.g. ProRes. This can be accomplished with the FFmpeg command-line tool.
Code:ffmpeg -i orig_vid.mov -c:v prores -profile:v 3 -c:a copy trans_vid.mov
I've got dozens of files here, is there a way I can do them without having to type every single one in manually?
Well, now that you know how to transcode them, take a look at the supported formats and find one that your computer can handle.
Well...I'm not really sure how to apply that to a different codec, and I don't want to do too much damage to the footage at this stage...
From that list I would test DNxHD and ProRes, both good (fast) editing formats. Not lossless but high quality.
EDIT What did you do to get them to import? Did you use JVRaines' suggestion ie ProRes? That should have worked.Last edited by raffriff42; 16th Oct 2016 at 15:27.
No, it is an actual pause in playback. In VLC, it starts playing, then pauses, then the playback bar gradually fills up with yellow, then playback resumes. So on, so forth. If I drag the play head back to the start, it plays through fine up until the point it had got to previously, then starts pausing again. It's genuinely like a badly-buffering internet video.
Right, so it's still a source problem - since that should not be happening . It's not an encoding problem. It's a source problem. I've dealt with AIC for many years , the ffmpeg workflow works flawlessly with AIC. At 960x540, you're not going to be having HW problems unless it's a very old setup
Do all the videos in the batch exhibit the same behaviour or just that one ? -
Yes, emulate. In the old-school sense, not the computer-science sense.
That is, try to imitate. Use the same codec (but at higher quality), whether that's H.264, MPEG-4 or something else. Use the same container, whether that's MOV, AVI or something else. -
Right.
I forgot to mention: try setting a short GOP length (more frequent keyframes) with -g 15, for fast seeking in the editor. -
After a reboot, it all worked fine. I could play the files in VLC, and in Premiere, with no problems. But when I opened the project into which I'd imported all the files, in the bottom left corner it said "Loading [file] (x remaining)", where x gradually decreased as each file loaded, eventually getting stuck at 5. I tried to manually link the first of those five unloaded files, but Premiere stopped responding. Close Premiere, reopened it, opened the project again, and now it's stuck at 19 remaining.
I tried deleting and reimporting one of the files that wouldn't load, after repeatedly opening the project until it was down to two unloaded files, and it just got stuck at 0%.
Bump?
I have about a week to turn these into something, so this is pretty urgent. -
Stunned silence from my end. Post #19 sounds like a completely different problem. I don't know enough about Premiere to help you with that.
That's very odd. I think your computer has other problems besides a missing codec or two.
I don't know what to say since (a) I don't use Premiere, (b) you don't give us enough information, and (c) you seem to switch topics without warning. -
What more information do you need, and how am I switching topics? I'm trying to import these files into Premiere, that's all I've been trying to do.
Hey, koberulz. I have never used AIC, but looking at the MediaInfo, it appears to have a fairly modest bitrate—27 Mbps, amiright? Anyway, if you tried transcoding it to ProRes HQ per JVRaines's ffmpeg script example and are having playing playback issues, perhaps your computer can't handle that bitrate since HQ is around 220 Mbps. I would try the LT profile as it should have plenty of bitrate and there is no reason to go all the way to HQ. You may even want to try the the proxy profile as well along with the kostya variant of prores:
Also, what color is the playback bar at the top of the timeline in PP? Is it red?Code:ffmpeg -i in.mov -c:v prores_ks -profile:v 1 -pix_fmt yuv422p10le -vendor ap10 -c:a copy out.mov
You can also try deleting the adobe media cache and temp files, starting a new project
If this is referring to the (now) prores files you're still having problems with, try converting the AIC to something else. Maybe AVI container instead of MOV format, like ut video codec
But it seems like you have other computer problems if a reboot partially fixed both playback in VLC and premiere. I'd also be looking for other processes, maybe virus / malware -
Unable to open MOV files
By rstuff in forum Newbie / General discussionsReplies: 11Last Post: 7th Aug 2016, 19:41 -
Unable to import MP4 Ac-3 into vegas pro 13
By GalaBK in forum EditingReplies: 1Last Post: 12th Sep 2015, 09:02 -
Unable to import mp4 videos in sony vegas pro 13.Only audio out of video.
By WingSaber in forum Capturing and VCRReplies: 1Last Post: 12th Jul 2015, 16:56 -
how to import mpeg-ps in premiere
By nemorosa in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2015, 14:38 -
.MOV to something that Premiere CS3 will import
By Ygramul in forum Video ConversionReplies: 10Last Post: 13th Aug 2012, 06:18
