Results 1 to 18 of 18
  1. Hi,
    I just installed WidevineProxy2 addon for Firefox and have some questions on how to use it.
    1. What’s the difference between Widevine Device and Remote CDM?
    2. I downloaded remote.json from https://github.com/user-attachments/files/21834836/remote.json
    and registered it in WidevineProxy2 but when I played the test video at https://github.com/DevLARLEY/WidevineProxy2/tree/5ab84cc68a389db1a6e74135c702a8b6ade7eded WidevineProxy2 didn’t respond accordingly.
    3. Are there any difference for conventional usage among all the files at https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21? Why is it called Android Studio? Does it matter for Windows usage?
  2. Originally Posted by blanc View Post
    Hi,
    Widevine Device (.wvd) is a CDM on your computer, which you can download from the "Ready-to-use-CDM" link. Remote CDM means it's not on your device and hosted online so you would provide a URL for that instead.
    You should download some CDM's from the "Ready-to-use-CDM" link and select/load one of them from WidevineProxy2, most websites will work then.
    For conventional usage... no... just download some of them and load 1 in the extension and you'll be good to go.
    Android studio means it was extracted from an android ROM in android studio (emulated).
  3. Thanks. WidevineProxy2 accepts only two types of files: wvd file for Widevine Device and json file for Remote CDM, but there are two files in one zip file: client_id and private_key.pem. How to use these files at https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21?
  4. This one has lots of WVD's.
    Just select "choose file" in the extension and load a wvd. If one doesn't work, try a different one. With most free services they will work, but they might not work for premium like AMZN/NFX.
  5. The video on GH isn't a test video, it's an instructional video for you to watch. The test video is at Bitmovin
  6. Thanks. Please see my attached snapshot. Does it mean the installation is successful?
  7. I also tried widevineproxy 2 but I can't get it to work on discoveryplus what to do
  8. Originally Posted by valelisa39 View Post
    Unshackle & Envied work with DSCP.
  9. I can verify this addon is installed successfully but what shall I do with it? Can I download this DRM video or just watch it online with this tool?
  10. Copy the command from "CMD" box (this is a command for N_m3u8DL-RE )
    [Attachment 91028 - Click to enlarge]
    You need to download N_m3u8DL-RE
    You will also need shaka packager and mp4decrypt.
    Put N_m3u8DL-RE, shaka packager and mp4decrypt all in 1 folder - then open a terminal in that folder and paste the link and the video will download.
  11. Image
    [Attachment 92463 - Click to enlarge]
    im new to this but i was getting this error, could you please explain or help me out. Thanks in advance.
  12. Code:
    N_m3u8DL-RE "https://cdn.bitmovin.com/content/assets/art-of-motion_drm/m3u8s/11331.m3u8" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko ) Chrome/148.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://bitmovin.com" -H "Referer: https://bitmovin.com/" --key ccbf5fb4c2965be7aa130ffb3ba9fd73:9cc0c92044cb1d69433f5f5839a159df --key 9bf0e9cf0d7b55aeb4b289a63bab8610:90f52fd8ca48717b21d0c2fed7a12ae1 --key eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4589152b57d2dacb --key 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def614227b9c0f03e26 --key 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e203004b30c4eaf348f4 --use-shaka-packager -M format=mkv
  13. Originally Posted by YmFzZTY0 View Post
    Thank you so much, it worked
  14. A few days ago, Widevine Proxy2 started failing on more websites. Changing the CDM doesn't help. What could be causing this?
  15. Originally Posted by porinkey View Post
    API licensing changes by the service, a poor proxy/vpn, WP2 accidentality become corrupted (reinstall fresh)
    And being vague on which websites doesn't help anyone to help you finding solutions
    Jul 2026
    Malaysia
    hi, did you can check or try why website sooka.my not work when using this widevineproxy2 ?
  17. Originally Posted by Sleppy92 View Post
    Its not my app, I haven't a clue why it would or wouldn't work on any particular site - but you can open an issue here for the developer to assess:
    https://github.com/DevLARLEY/WidevineProxy2/issues
