  1. Hi. I've used MeGUI 32 bit for years along with Avisynth (installed in C/Prog Files x86). I have an avsi file with some custom functions which is kept in Avisynth's plugins folder. Those functions work with MeGUI 32 bit even when MeGUI's "Always use the included avisynth" box is ticked (don't understand why that is but nevermind...)
    Today, having discovered that there's a MeGUI 64-bit, I downloaded it. I copied the avsi file and put it into MeGUI-64/tools/avs/plugins. It didn't work ("There is no function...") So I put the avsi file into MeGUI-64/tools/avisynth_plugin as well. Still not working. Tried ticking and unticking "Always use the included avisynth" but makes no difference.
    Can anyone suggest what I need to do to get MeGUI-64 to acknowledge my avsi file? Many thanks.
    Dec 2018
    Brasil - BR
    Eu sugiro você instalar "VisualCppRedist_AIO_x86_x64".
    Também baixar e colocar na pasta "plugins64+" Zs_RF_Shared.avsi".
    Você também deve instalar os "plugins", que pede em seus "avsi".
    Dec 2018
    Brasil - BR
    The attached text is in Brazilian Portuguese.
  4. Thanks. I've got it working after installing Avisynth+ 64-bit along with some dll's mentioned in the avisynth wiki.
