Results 1 to 14 of 14
  1. Hi
    I dunno whether this was the right forum, but it was as close as i could find.
    I need help on the playback of vcds on my playstation.
    I have a vcd adapter for the playstation and when i play vcds , its usually a bit strechted out horizontally so i cant see subtitles etc, but when i press the start button on the controller, it usually fixes it because it turns on PBC(i think thats wot it is, it allows forwarding, pausing etc).
    Here's the problem, i got this Karaoke vcd, and the words of the second line on the bottom are hidden because the screen is streched again, only this time, pressing start to turn on PBC ISNT WORKING!!!! Karaoke just isnt karaoke without the words!!!!! I've tried playing the vcd on the comp n it works fine, i can see the words, so i dont think its the disc (as in its not faulty).
    Can someone PLLLLLLLLLLLLZZZZZZZ help me?!?!?!!
    thank you very very much
    Lazerin
    ps I think PBC stands for PlayBack Control
  2. can someone help me in encoding avi to vcd format (mpeg)
    1) i used v-dub to extract the audio as a wav then saved it
    2)went in tmpenc and coverted the avi to mpeg input the wav file as audio
    3) encodin went fine using tempenc --NO errors
    4) then i tried to play the mpeg file in media player but only the audio worked no video (black SCREEN)
    any suggestions
  3. Hijacked thread!
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    You stole Lazerin's thread. He started by asking a question, but under his question you ask another question instead of posting it yourself in the forum. Thus you Hijacked his thread. Next time start your own to ensue people will see your question topic and not another.
  5. YAH GOOD FOR U !!!!
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    What does that mean? btw, next time why don't you post you question in ALL the forums.
  7. nyeh....no one is helping here....
  8. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Sorry. I have a n64
  9. Natively a PS cant play VCDs you need and adapter for it.
  10. A Playstation One and a Dreamcast can play VCDs but.........
    THEY CAN NOT PLAY THEM WORTH A SHIT!!
    The problems you are having are the same as anyone gets. These machines are not designed to play VCD movies, They are designed for playing Video Games.
    www.dcemulation.com
    www.vcd-trading.com
    Check It out !!!
  11. bah...dont worry, u guys have no idea wot ur talking bout.
    I fixed the problem myself.
    catchya l8r
  12. tgpo SHOULD BE BANNED!!
  13. Lazerin, i was just wondering how much u bought that VCD adapter for PS1 for...
    cuz there are standalone dvd players for $65 (apex has mp3 and SVCD support)
