Hello,
I recently saw a program that claimed it could, with a cdrw drive, burn a dvd. Is this possible? If so, how? Thanks a lot- Aaron
Yes, it is possible to burn DVD to CDRW. This is called miniDVD and is supported by only 2% of all DVD players. You can only fit 15 minutes of DVD quality video in one CDR/W.
I hope this helps. -
what those products also don't tell u is that they mean DVDRips, ie DivX (MPEG-4, only playable on computers) and/or SVCDs (MPEG-2, standalone compatible). DVDs can not be written to CD, simply b/c of size. MiniDVD is taking the ripped VOBs from the DVD that you ripped, downsampling them, and placing them on a CD. as Pharaoh said, there is LITTLE standalone support for this so its not even worth it. other than that, the only "DVDs" on CD are DVDRips.
hi all. iam a newby and this question iam gonna ask may sound a little too easy or odd u could say, but can anyone please help me.
i want to know how to make a minidvd. :lol: i would be greatfull if i could get some help with this. -
Of course its not possible Goring. If it were then what would be the point of dvd burners? Either the program was a fake or you misread what it was claiming.
Rexneel to make a minidvd you need dvd authoring software that lets you burn on cdr/w media. This function is really for playtesting your disks before wasting dvd-r media, its not actually supposed to be used as a viable format but like someone else mentioned there are a very select few dvd players which can play these, though you usually have to modify the player first.
Anyway with the software simply take any video and encode it according to the dvd standard or use an existing dvd and just re-author the vobs using the dvd authoring software. -
nope u cant burn DVDs witha CDRW. its physically impossible to do it with a single laser while DVDs use dual lasers.
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Problem on a few dvds when trying to copy to hard drive
By Dekaspace in forum DVD RippingReplies: 5Last Post: 22nd Jul 2008, 14:18
