Hi there... I have a set of DVD files, VOBs, BUPs, and IFOs, that if I burned on disc, would play the content as desired. Now, I also have another set of DVD files, also VOBs, BUPs, and IFOs, that if I burned on disc, would play pretty much the same content, however there is a bit more additional footage on the first set of files that I want to splice into the second set of files, however there is some content in the second set that I need to splice out.
What steps and apps would I need to accomplish such a goal? All help would be appreciated.
Thanks![]()
A simple way is to import videos track by track to TDA by dragging VIDEO_TS.IFO file to SOURCE window. For each imported track you'll have an option to use original chapter information on time-line for setting start/end points for cutting what you are importing. After you do it for all videos separately you can build new DVD folders with or without menu.
Hey there Alex.. thanks for the prompt reply. I still however would need an actual tutorial, as I haven't used TGMPEncDVD Author really much, so I don't have the mastery skills necessary to handle the required task on my own with your simple instructions. If you can point me to a resource on a step by step that would be great.
Just to elaborate a bit... one of the DVDs only has a little bit of data at the tail end I need and would like to splice into the other dvd. I think that would be the best way for me to handle it. The VOB that I want to splice into the longer DVD would need to be edited to about 1/4 or so in length, as I only need the last say 5 or 10 mins of it.
Anyhow, if you can either write a tutorial
or find one that would pretty much suit my needs exactly, that would be so much appreciated. I personally wouldn't mind writing one myself, if I was able to do this successfully with the minimal amount of applications being used. I think this would be a very useful tool for making like a music video collection of favorites on one disc. Anyhow, let me know your thoughts. Thanks
Splicing / editing H264 with zero or minimal re-encoding?
By Asterra in forum Video ConversionReplies: 8Last Post: 12th Apr 2012, 14:25 -
Editing one of the .VOB files
By Yaro in forum EditingReplies: 94Last Post: 4th Sep 2009, 16:52 -
Editing VOB files
By lika in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 14:51 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
editing vob files
By newtie in forum Authoring (DVD)Replies: 7Last Post: 5th May 2007, 10:19
