Results 1 to 17 of 17
    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    Hey there.
    Nowadays I use a LG DVD/VCR combo, model RC7000B, to convert my VHS tapes to DVD, using its s-video output and s-video input from my Hauppauge card. When the playback time is exactly 1 hour or 2 hours I use the combo itself to record the DVD. But 90% of the time I use my capture card.
    I know VHS has low resolution and there is not much I can do about it, but will a S-VHS VCR help me improve quality? I will not play any S-VHS tape (the chance is really close to zero).
    Maybe a S-VHS with TBC and DNR will help, right?
    Anyway, my choices (if a S-VHS VCR can help me) are:
    JVC SR-S365U - R$ 900 (used twice, almost brand new)
    JVC HR-S5912 - R$ 983 (new)
    JVC HR-S7900 - R$ 1,778 (new)
    JVC HR-S3902U - R$ 900 (new)
    JVC HR-S9911 - R$ 1,500 (new)
    US$ 1 = R$ 2.20 (yes, this things are expensive here :/)
    9911 and 7900 models are the ones with TBC, and I can't afford right now. If TBC is the only thing that would help me improve quality, I'll have to wait some months to get it.
    If just the fact of being a S-VHS VCR will help me, I need to choose between the others.
    Otherwise, I'll stick with my LG RC7000B to play my VHS tapes
    Thanx.
  2. It's an old thread, but you may find this useful:
    https://forum.videohelp.com/viewtopic.php?t=255539&highlight=
    The basics of the thread is that the only players that will enhance the picture will be the S-VHS VCR's with DNR. Just being a S-VHS VCR will not improve the picture quality alone.
    Cole
    Apr 2005
    Hmmm interesting thread.
    Haven't come across this one.
    Thanx, Cole.
    Seems like the TBC/DNR models are the way to go. And I'll have to way more time to get it :/
  4. Member ntscuser's Avatar
    Mar 2003
    All VHS tapes are recorded in S-video mode whether they are S-VHS or standard VHS recordings. To avoid cross-color artefacts and the encoding problems resulting from these you must use a video player with an S-video or component color output. It so happens that in the consumer realm only S-VHS recorders are equipped with S-video outputs of any kind. So yes, you will get an improvement in capture quality from an S-VHS machine whether it has DNR or not.
  5. Originally Posted by ntscuser
    From what I have seen and experienced there is not a great deal of difference on PAL tapes when using S-Video connections; but then I am in PAL land and S-Video connections only really help with NTSC
    Cole
  6. Member ntscuser's Avatar
    Mar 2003
    That depends on the inputs on your capture card. Certainly using the S-video input to my AVer card to capture a PAL VHS version of Insektors produced a vast improvement in encoding quality over using the composite colour input. Some of the more expensive capture cards may have an efficient built-in comb filter to separate the chrominence and luminance signals in which case the differences will not be quite as noticeable but they still exist.
    Apr 2005
    From what I've read the s-video input on my Hauppauge really does the difference. And I'm working with NTSC here.
    Going back to the VCR models, I know the 9911 is good (and the others may be too), but any of you have any comment on the other models I listed?
    Apr 2005
    Well, I kept reading on the subject and maybe a TBC would be better for me.
    My LG VCR already gives me s-video output, which makes my captures better and, as its tuner works with PAL-M systems, I use it for watching cable TV too.
    Instead of buying a new VCR just to capture VHS, maybe buying a TBC would be a better option. Or an external TBC does not help much as an internal one?
    I can buy this one http://www.videousado.com.br/modules/classificados.php?recid=1638
    Datavideo TBC 1000, listed on lordsmurf's site as something he can't live without
    Now I have one more option to make my brain a little more confused.
    TBC will NOT improve image quality, it will only stabilize the signal. You need a good VCR to improve image quality.
    Apr 2005
    When I say quality I mean in general.
    I believe I have a good VCR (at least better then the older one), but I still think my captures can be better.
    As I'm capturing lots of VHS and VHS-C tapes nowadays, most of them a little old, a TBC would help me to stabilize the signal. But I want to make it look better on color, saturation, noise, etc too. And I understand that a TBC will not help much on it. It's just half the way.
    I should have post some samples here, sorry.
    Maybe the best is really get a new device, like one of the VCRs I listed on the first post, with TBC/DNR. Unfortunately I can't get one to test and return.
    Sorry if I'm replying my own posts. I keep reading here and there and keep finding different options to chose. Then I mix that up and make it a mess :/
  11. Video Restorer lordsmurf's Avatar
    Color and saturation is for a proc amp.
    Noise removal is for a line TBC in a VCR, VCR filters, DVD recorder filters, or software
  12. Member ntscuser's Avatar
    Mar 2003
    I don't know about JVC but on my Panasonic S-VHS machine it's not possible to have both TBC and DNR active at the same time. I also found the original source material has to be really, really bad before either feature has much effect.
    Apr 2005
    Thanx, ntscuser. Good to know.
  14. Video Restorer lordsmurf's Avatar
    On JVC, the TBC and DNR are a single processing unit.
    The only thing the JVC cannot do is TBC + Stabilizer
    Apr 2005
    One thing is for sure, I narrowed down my choices to the models with TBC/DNR. Like the 7900 and the 9911. I also found a 6970 model, which is multisystem (according to B&H), but I'm not sure if it works with PAL-M for cabel TV (still waiting for JVC to reply my e-mail). If it does, I can buy it and sell my LG unit. If it does not, I'll try one of the others and keep both VCRs.
    Thanx everyone for the replies.
  16. Preservationist davideck's Avatar
    Feb 2003
    USA
    Instead of buying a new VCR just to capture VHS, maybe buying a TBC would be a better option. Or an external TBC does not help much as an internal one?.
    Another option is to buy a DVD Recorder for use as an External TBC / Frame Synchronizer / Noise Reducer / Proc Amp. Toshiba DVD Recorders are particularly good for this. Excellent TBC Performance.
    Life is better when you focus on the signals instead of the noise.
    Apr 2005
    A recorder like that seems to be good, but really hard to find around here.
