Results 1 to 27 of 27
    Jan 2007
    I keep trying to backup saw 3 and I used ripit and it keeps giving me this error
    Waiting for Decrypter to be ready
    ERROR! Unable to patch decrypter!
    Done ripping ...
    Decrypter ripping time: 00:00:04
    The rip seems to have been aborted, RipIt4Me cannot continue
    Done at 16:53:10
    Elapsed time: 00:02:37
    What does that mean?
  2. it's currently a problematic disc. Wait a day or two. DVDFab Decrypter usually comes up with the solution.
    "Half empty or half full, it's still only half a glass" - What Dave Says
  3. Member rvelez's Avatar
    Oct 2005
    Update FixVTS to 1.603 and try again.
  4. as I posted on the other thread, it still doesn't work.
  5. why they keep opening new threads about the same topic
    3 in 2 days so far
  6. sometimes the search doesn't work, that's why.
  7. Originally Posted by sapiendut
    https://forum.videohelp.com/viewtopic.php?t=319513&highlight=
    Jan 2007
    I finally back up my Saw 3: I have the same problem with dvd fab and anydvd with clonedvd2. So I read some forums and RIPIT4ME and FIXVTS finally broke the barrier. Ripit4me and fixvts is a zip file. So unzip in desktop. Make you have DVDSHRINK and DVD DECRYPTER. You need these programs. Download 1.) Ripit4me 1.6.4.0 2.)FixVTS 3.) DVD Shrink 4.) DVD Decrypter Next, Install Dvd Shrink and Dvd Decrypter. -skip- if already have them installed. Next, open ripit4me on your desktop and go to LOGS/Setting in the menu bar. Go to preferences and look for Paths to Progams. Once your there, make you have Dvd decrypter first, then dvd shrink second and last click Path to FixVTS: Once you click on it you should a window pop up. Find FixVTS on you desktop and click it twice. Press Ok, 1-Click Mode and if you need help go to http://www.ripit4me.org/guide.html
  9. it extracts no problem but then freezes on me on the fixvts process. Tried it multiple times with the same results.
    Jan 2007
    Backing up SAW 3:
    Download
    1.) Ripit4me 1.6.4.0 2.)FixVTS 1.6.0.3 3.) DVD Shrink 4.) DVD Decrypter
    Ripit4me and fixvts is a zip file. So unzip in desktop. Make sure you have DVDSHRINK and DVD DECRYPTER. Next, Install Dvd Shrink and Dvd Decrypter. -skip- if already have them installed. Next, open ripit4me on your desktop and go to LOGS/Setting in the menu bar. Go to preferences and look for Paths to Progams. Once your there, make you have Dvd decrypter first, then dvd shrink second and last click Path to FixVTS: Once you click on it you should have a window pop up. Find FixVTS on you desktop and click it twice. Press Ok
    NEXT:
    1-Click Mode, Once it reads DVD, click next.
    Dvd Decrypter should rip DVD
    to be sure: it should have the following.
    RipIt4Me Version 1.6.4.0
    Starting 1-click Ripping Procedure at 19:07:31
    Running Windows XP Service Pack 2
    FixVTS version: 1.6.0.3 -- All OK
    DVD Decrypter version: 3.5.4.0
    DVD Shrink version 3.2.0.15
    _________________________
    SPTI layer available
    Ripping mode: Full Rip
    Main title(s):
    Title 8 (VTS 8 PGCs 1) -- 1:48:22s -- 4:3
    Remove Protected Cells = on
    Remove Tiny Cells = on
    Remove Useless Menu Cells = on
    Bypass annoying PGCs = off
    Remove Last VTS = on
    Blank bogus VTS = on
    Run FixVTS on full DVD = on
    Rip JACKET_P folder = off
    Copy IFO mode = 0
    DVD Decrypter IFO parsing mode = 1
    Copying original IFOs into target directory
    100 IFOs copied.
    DVD Volume Label: Saw_3
    Loading IFOs
    DVD is region-free
    Video Format: NTSC
    Done opening IFOs
    Retrieving sectors from DVD drive
    CRC32 value = 0x72DAC2A3
    Creating Protected Sector List (PSL) file
    Done creating PSL file
    Ripping video_ts.vob to detect unreferenced titlesets
    Done ripping ...
    Decrypter ripping time: 00:00:03
    Loading IFOs
    DVD is region-free
    Scanning VTS 1 for BOVs
    Scanning VTS 2 for BOVs
    Scanning VTS 3 for BOVs
    Scanning VTS 4 for BOVs
    Scanning VTS 5 for BOVs
    Scanning VTS 6 for BOVs
    Scanning VTS 7 for BOVs
    Scanning VTS 8 for BOVs
    Scanning VTS 9 for BOVs
    Scanning VTS 10 for BOVs
    Scanning VTS 11 for BOVs
    Scanning VTS 12 for BOVs
    Scanning VTS 13 for BOVs
    Scanning VTS 14 for BOVs
    Scanning VTS 15 for BOVs
    Scanning VTS 16 for BOVs
    Scanning VTS 17 for BOVs
    Scanning VTS 18 for BOVs
    Scanning VTS 19 for BOVs
    Scanning VTS 20 for BOVs
    Scanning VTS 21 for BOVs
    Scanning VTS 22 for BOVs
    Scanning VTS 23 for BOVs
    Scanning VTS 24 for BOVs
    Scanning VTS 25 for BOVs
    Scanning VTS 26 for BOVs
    Scanning VTS 27 for BOVs
    Scanning VTS 28 for BOVs
    Scanning VTS 29 for BOVs
    Scanning VTS 30 for BOVs
    Scanning VTS 31 for BOVs
    Scanning VTS 32 for BOVs
    Scanning VTS 33 for BOVs
    Scanning VTS 34 for BOVs
    Scanning VTS 35 for BOVs
    Scanning VTS 36 for BOVs
    Scanning VTS 37 for BOVs
    Scanning VTS 38 for BOVs
    Scanning VTS 39 for BOVs
    Scanning VTS 40 for BOVs
    Scanning VTS 41 for BOVs
    Scanning VTS 42 for BOVs
    Scanning VTS 43 for BOVs
    Scanning VTS 44 for BOVs
    Scanning VTS 45 for BOVs
    Scanning VTS 46 for BOVs
    Scanning VTS 47 for BOVs
    Scanning VTS 48 for BOVs
    Scanning VTS 49 for BOVs
    Scanning VTS 50 for BOVs
    Scanning VTS 51 for BOVs
    Scanning VTS 52 for BOVs
    Scanning VTS 53 for BOVs
    Scanning VTS 54 for BOVs
    Scanning VTS 55 for BOVs
    Scanning VTS 56 for BOVs
    Scanning VTS 57 for BOVs
    Scanning VTS 58 for BOVs
    Scanning VTS 59 for BOVs
    Scanning VTS 60 for BOVs
    Scanning VTS 61 for BOVs
    Scanning VTS 62 for BOVs
    Scanning VTS 63 for BOVs
    Scanning VTS 64 for BOVs
    Scanning VTS 65 for BOVs
    Scanning VTS 66 for BOVs
    Scanning VTS 67 for BOVs
    Scanning VTS 68 for BOVs
    Scanning VTS 69 for BOVs
    Scanning VTS 70 for BOVs
    Scanning VTS 71 for BOVs
    Scanning VTS 72 for BOVs
    Scanning VTS 73 for BOVs
    Scanning VTS 74 for BOVs
    Scanning VTS 75 for BOVs
    Scanning VTS 76 for BOVs
    Scanning VTS 77 for BOVs
    Scanning VTS 78 for BOVs
    Scanning VTS 79 for BOVs
    Scanning VTS 80 for BOVs
    Scanning VTS 81 for BOVs
    Scanning VTS 82 for BOVs
    Scanning VTS 83 for BOVs
    Scanning VTS 84 for BOVs
    Scanning VTS 85 for BOVs
    Scanning VTS 86 for BOVs
    Scanning VTS 87 for BOVs
    Scanning VTS 88 for BOVs
    Scanning VTS 89 for BOVs
    Scanning VTS 90 for BOVs
    Scanning VTS 91 for BOVs
    Scanning VTS 92 for BOVs
    Scanning VTS 93 for BOVs
    Scanning VTS 94 for BOVs
    Scanning VTS 95 for BOVs
    Scanning VTS 96 for BOVs
    Scanning VTS 97 for BOVs
    Scanning VTS 98 for BOVs
    Scanning VTS 99 for BOVs
    Video Format: NTSC
    Checking once more for unreferenced titlesets...
    Excluding VTS 15 from rip because it is unreferenced.
    Excluding VTS 16 from rip because it is unreferenced.
    Excluding VTS 17 from rip because it is unreferenced.
    Excluding VTS 18 from rip because it is unreferenced.
    Excluding VTS 19 from rip because it is unreferenced.
    Excluding VTS 20 from rip because it is unreferenced.
    Excluding VTS 21 from rip because it is unreferenced.
    Excluding VTS 22 from rip because it is unreferenced.
    Excluding VTS 23 from rip because it is unreferenced.
    Excluding VTS 24 from rip because it is unreferenced.
    Excluding VTS 25 from rip because it is unreferenced.
    Excluding VTS 26 from rip because it is unreferenced.
    Excluding VTS 27 from rip because it is unreferenced.
    Excluding VTS 28 from rip because it is unreferenced.
    Excluding VTS 29 from rip because it is unreferenced.
    Excluding VTS 30 from rip because it is unreferenced.
    Excluding VTS 31 from rip because it is unreferenced.
    Excluding VTS 32 from rip because it is unreferenced.
    Excluding VTS 33 from rip because it is unreferenced.
    Excluding VTS 34 from rip because it is unreferenced.
    Excluding VTS 35 from rip because it is unreferenced.
    Excluding VTS 36 from rip because it is unreferenced.
    Excluding VTS 37 from rip because it is unreferenced.
    Excluding VTS 38 from rip because it is unreferenced.
    Excluding VTS 39 from rip because it is unreferenced.
    Excluding VTS 40 from rip because it is unreferenced.
    Excluding VTS 41 from rip because it is unreferenced.
    Excluding VTS 42 from rip because it is unreferenced.
    Excluding VTS 43 from rip because it is unreferenced.
    Excluding VTS 44 from rip because it is unreferenced.
    Excluding VTS 45 from rip because it is unreferenced.
    Excluding VTS 46 from rip because it is unreferenced.
    Excluding VTS 47 from rip because it is unreferenced.
    Excluding VTS 48 from rip because it is unreferenced.
    Excluding VTS 49 from rip because it is unreferenced.
    Excluding VTS 50 from rip because it is unreferenced.
    Excluding VTS 51 from rip because it is unreferenced.
    Excluding VTS 52 from rip because it is unreferenced.
    Excluding VTS 53 from rip because it is unreferenced.
    Excluding VTS 54 from rip because it is unreferenced.
    Excluding VTS 55 from rip because it is unreferenced.
    Excluding VTS 56 from rip because it is unreferenced.
    Excluding VTS 57 from rip because it is unreferenced.
    Excluding VTS 58 from rip because it is unreferenced.
    Excluding VTS 59 from rip because it is unreferenced.
    Excluding VTS 60 from rip because it is unreferenced.
    Excluding VTS 61 from rip because it is unreferenced.
    Excluding VTS 62 from rip because it is unreferenced.
    Excluding VTS 63 from rip because it is unreferenced.
    Excluding VTS 64 from rip because it is unreferenced.
    Excluding VTS 65 from rip because it is unreferenced.
    Excluding VTS 66 from rip because it is unreferenced.
    Excluding VTS 67 from rip because it is unreferenced.
    Excluding VTS 68 from rip because it is unreferenced.
    Excluding VTS 69 from rip because it is unreferenced.
    Excluding VTS 70 from rip because it is unreferenced.
    Excluding VTS 71 from rip because it is unreferenced.
    Excluding VTS 72 from rip because it is unreferenced.
    Excluding VTS 73 from rip because it is unreferenced.
    Excluding VTS 74 from rip because it is unreferenced.
    Excluding VTS 75 from rip because it is unreferenced.
    Excluding VTS 76 from rip because it is unreferenced.
    Excluding VTS 77 from rip because it is unreferenced.
    Excluding VTS 78 from rip because it is unreferenced.
    Excluding VTS 79 from rip because it is unreferenced.
    Excluding VTS 80 from rip because it is unreferenced.
    Excluding VTS 81 from rip because it is unreferenced.
    Excluding VTS 82 from rip because it is unreferenced.
    Excluding VTS 83 from rip because it is unreferenced.
    Excluding VTS 84 from rip because it is unreferenced.
    Excluding VTS 85 from rip because it is unreferenced.
    Excluding VTS 86 from rip because it is unreferenced.
    Excluding VTS 87 from rip because it is unreferenced.
    Excluding VTS 88 from rip because it is unreferenced.
    Excluding VTS 89 from rip because it is unreferenced.
    Excluding VTS 90 from rip because it is unreferenced.
    Excluding VTS 91 from rip because it is unreferenced.
    Excluding VTS 92 from rip because it is unreferenced.
    Excluding VTS 93 from rip because it is unreferenced.
    Excluding VTS 94 from rip because it is unreferenced.
    Excluding VTS 95 from rip because it is unreferenced.
    Excluding VTS 96 from rip because it is unreferenced.
    Excluding VTS 97 from rip because it is unreferenced.
    Excluding VTS 98 from rip because it is unreferenced.
    Done importing the PSL file, now starting ripping...
    **I will take a while on the first gig file. It should put dummy sectors slowly, once it is done, it should pick up. When it about to finish, a patch file will come up. press ok and it should automatically go to dvd shrink and your done!
  11. to coltsfann: I looked at your log and the disk said region free. did you have anydvd running in the back ground before decrypeter started to rip.... i am trying saw 3 now and for ripit4me to access the disk i had to run anddvd. i turned off anydvd before decrypter started. it is ripping now and i will know tomorrow
    Jan 2007
    sigh.. That is all foreign to me colts but I REALLY appreciate the advice.. I have NO CLUE how to run those two programs. I have dvd shrink and dvd fab.. THANKS again!
    Jan 2007
    anydvd will automatically turn off. besides anydvd is no help
    Jan 2007
    if this is not read, restart your comp and make not put anydvd on autostart. turn it off and reboot and try again
    Jan 2007
    princessme & ladyb1998, if u need more help let me know colts.fan.nm@gmail.com
  16. Member tonydead's Avatar
    Apr 2005
    Colorado
    Originally Posted by coltsfannm
    Backing up SAW 3:
    Download
    NEXT:
    Main title(s):
    Copy IFO mode = 0
    100 IFOs copied.
    Loading IFOs
    DVD is region-free
    Video Format: NTSC
    Done opening IFOs
    Done ripping ...
    Loading IFOs
    DVD is region-free
    Video Format: NTSC
    CONFIRMED. This approach does work, copied full back up in 28m33s with my "muscle car" P4. But, C'MON DFAB and ANYD, get the updates so we don't have to use three different programs (none of which are yours). ??? Ironic how we fall back on ol'Decrypter. You don't need DShrink once you have it on your hard drive, do what you want once it's there. It seems to stall quite a bit with on the first big VOB file, but, after that it's like a knife through hot butter.
    What's the deal with the new DRM on DVDs anyway? Is Lion'sgate owned by SONY or something? Speaking of Lion'sgate......Hostel II on June 8 baby......................
    Back this Up.....(0)
  17. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    After a couple of hours of trying all the methods mentioned and nothing working I was finally able to get this to work using a Beta version of AnyDVD (v6.1.1.0).
    I used this beta of AnyDVD version in conjunction with CloneDVD, it worked perfectly.
    If anyone is interested in trying this, below are some links to the Beta version (it's a 21 day free trial).
    I don't believe this is warez, since it's is still a trial version like they offer on their website.
    http://www.megaupload.com/?d=M5YEP8I7
    http://www.zshare.net/download/setupanydvd6110-zip.html
    http://www.mediafire.com/?3twq0tg2qzk
    Enjoy
  18. i finished saw 3 this morning. with the new version of ripit4me and fixvts saw 3 backup successfully. i used dvd2one to shrink and then nero to burn.
  19. Member Grain's Avatar
    Oct 2005
    Canada
    There's a R1 version out there with the DVD Volume Label of Saw_3_Unrated that still seems to be causing problems.
    Jan 2007
    this message is for mats.hogberg Hmm before you send me a private message you could have seen that I was a newbie and I was TRYING TO LEARN just like the rest of you here and I can NOT post in other threads for a few days or send private messages back... So Please dont message me saying things like that before you know! its RUDE!
  21. Member lumis's Avatar
    Jan 2005
    Newbies should read and not be seen.
  22. The method coltsfannm posted worked like a charm for me. I have the Saw 3 unrated version -- the DVD Volume Label of Saw_3_Unrated Grain was talking about.
    When Decrypter was 99% done I got all kinds of pop-up error messages. I have no idea what they meant. I just kept hitting "OK" until they were gone. Then Shrink opened up and I re-authored creating a file with only the movie. No menus or features or any of that crap. Doing that I got about an 89% compression rate. That's plenty good enough for me. As long as I get above 60% I'm happy.
    As long as you follow those directions exactly (and make sure you have the specified versions of the software) you shouldn't have a problem.
  23. Mod Neophyte redwudz's Avatar
    USA
    All these 'SAW 3' posts might as well be in the same forum since they appear to be DVD to DVDR. Moving you.
  24. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    How did you only get it to 89% ?
    I just did mine and with only the 5.1 audio track i got it at 97%, unrated WS version.
  25. Noah, I don't recall. Maybe there was a 2 channel audio option I left on? Also, while they don't take up a huge amount of space, I always leave the subtitles on.
    I'm not sure man. Now I am wondering myself.
  26. I managed to back it up using the non beta Anydvd and DVDFab 2.9.8.3. When you start DVDfab click on main movie and then uncheck all the extra languages. Easy as pie. No menu.......but simple back up.
  27. Banned
    Jun 2004
    Yeah, i alway's leave the sub's on also for that same reason.
    & RipIt4Me did it as easy as pie, no muss no fuss, 1-click mode.
