I have read about media builder and have tried it,so far unsuccessfully.It seemed like it was going to start working when I finaly got divxmux.exe in there but it gos to a dos screen then exits
This will be for a standalone dvd player that is divx ultra certified
could someone please send me in the right direction maybe some links?
Thankyou
I think the menus with only work with the newest Divx 6 codec, not with Xvids. I assume you have one of the few newer players that can use the Divx 6 menu options? You have probably seen the Media Builder homepage: http://userxp.tripod.com/mb.htm Not a lot on other forums about the tool.
This page from Divx might seem a little less complicated: http://labs.divx.com/DivXMediaTool
It looks like a lot of this is in the beta stage. -
ok lets say that I am doing them all as divx
I have tried mediabuilder and cannot get it to work
when I put create file it goes for a second to a dos window then stops -
I'm pretty sure those DivX tools only let you put a menu PER FILE. This would let you simulate DVD-style language/chapter selection (I think?), but it sounds like you're trying to put a menu on the whole DISK...most DivX compatible players just give a plain filename list and nothing more.
Trevor -
ok I've got some divx files that were encoded all the same way,what your saying is that they have to be joined and then I can use a menu?
Ok so how would I go about creating a menu assuming I have them all joined into one avi?
Simple Script to Prepare Your DivX/Xvid AVIs for Transcoding
By Soopafresh in forum Video ConversionReplies: 17Last Post: 13th Jul 2009, 20:30 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 08:57 -
how do I make a DVD with Divx or Xvid videos and have a menu that works
By Onceler2 in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 19:14 -
Can't get my AVIs to make a 3 hour long dvd. :(
By Nicole78 in forum Video ConversionReplies: 5Last Post: 14th Apr 2008, 15:05 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
