I just bought my first DVD Writer which is a LG Electronics GSA H10N. I have no idea as to which DVD blanks to buy. Could someone tell which are the best ones for my DVD Writer? I am referring to DVD -R/W; DVD +R/RW. Thanks
Media manufactored in Japan have the best reputation. Especially, Tayio Yuden & Verbatim. Remember to check the package(s) for the words, "Made in Japan."
You can usually get good deals on media from Rima.com, Supermediastore.com, and Meritline.com. NEVER buy anything from Wallyworld. -
With the Verbatim which do I get: 4X, 8X, or 16X.
Verbatim 16X DVD-R DataLifePlus Media Shiny Silver in Cake Box Spindle. Do I want the DataLifePlus?
If I take say 16X and put it in a 8x burner will it work? -
According to Supermediastore:
4X = 1X- 4X DVD recording speed
8X = 1X- 8X DVD recording speed
16X = 1X-16X DVD recording speed
Note: Your results may vary. So, don't buy a large quantity until you've tested a small quantity.
RE: buying Datalife, DatalifePlus or DigitalMovie, that's entirely up to you. They should all work fine. Again, make sure the package says, "Made in Japan" or you could be getting a second rate disc.
https://www.videohelp.com/dvdmedia.php?dvdmediasearch=verbatim&dvdmediadvdridsearch=&ty...+or+List+Media -
BTW, all Taiyo Yuden discs are made in Japan (unlike Verbatim discs).
4X = 1X- 4X DVD record speed
8X = 4X- 8X DVD record speed
16X = 1X-16X DVD record speed
As above, your results may vary. So test a small quantity before buying a large quantity.
Good luck!
