I've searched the forums and found various topics that deal with "squished" images. None seem to fit my direct problem, although alph's response Posted: Jul 07, 2005 18:20 on the newbie forum might help a bit with further explanation.
Anyway, I have a disk image for a DVD that I did not generate. When I view the VIDEO_TS contents with Apple's DVD player and VLC, or when I burn the contents to DVD and watch on my standalone DVD player, the image is squished. This isn't a case of the image needed to be reset in MyDVDEDIT to 16:9 (because the aspect ratio of the DVD is not 16:9); rather, it looks as if the image is being squished by the letterbox. So it's 4:3 with a letterbox and it seems as if I could pull the image up and down (thus removing the letterbox) then the image would look like a normal 4:3 image.
FYI:
DVD was recorded on a DVD Recorder from an American sports network and then a disc image was created on an IBM computer (probably with Nero).
MyDVDEDIT IFO tab tells me that VTS 1 and VTS 2 are 4:3, NTSC, and 720 X 480 (MPEG-2/VBR)
MyDVDEDIT PGC tab tells me that Line 1 R7 = R6 and Line 2 R6 =0 (I don't know what this means, but just in case...)
Again, if I switch 4:3 to 16:9 auto Pan&Scan and Letterbox, the image is still squished but is now also stretched. So it is clearly a 4:3 setting but also has letterbox. I noted above that alph's response might help but it doesn't see as if there's a way to preview resolution changes in MyDVDEdit if I need to switch from 720 X 480 so I figured I'd start here rather than burn through DVD-Rs.
Can I fix this problem and if so, how? Thanks.
Results 1 to 1 of 1
video clip squished/squeezed from the sides
By shaema in forum Video ConversionReplies: 4Last Post: 10th Apr 2011, 13:23 -
image squished vertically and letterboxed
By blitzen in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2009, 19:01 -
Exporting video is Squished (Horizontally)
By Daniel Arroyo in forum MacReplies: 3Last Post: 22nd Oct 2008, 09:06 -
AVI to DVD looking squished problem
By mashimiriam in forum Newbie / General discussionsReplies: 8Last Post: 31st Mar 2008, 19:17 -
Problem with 480p capture. Video seems squished...
By Mysteriouskk in forum Capturing and VCRReplies: 11Last Post: 9th Feb 2008, 01:24
