Hi. I need help. Im converting avi's which are 23fps using winavi and/or VSO Divx to DVD. I convert at auto framerate and auto aspect. ive tried converting Pal and NTSC but all avi's that are 23fps are constantly jerky and its winding me up. Anyone know whats happening??????
Results 1 to 17 of 17
ConvertXtoDVD (DivxtoDVD's payware big brother) converts 23.976 avis to 23.976 with 2:3 pulldown.
Read my blog here.
how do i convert to 23fps with convertxtodvd. i try and it converts to 29fps.????
Originally Posted by BaldrickBoth these guys mean 23.976 to 29.97 with 2:3 pulldown. An NTSC DVD requires a 29.97 display framerate.Originally Posted by gunslingerICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Sorry - typo. ConvertXtoDVD does it automagically when it detects 23.976 source. You will see it in the logs when it is processing.
You also have the option of encoding at 23.976 using an encoder that doesn't do pulldown, then using dgpulldown afterwards to add it in. Same outcome.Read my blog here.
Well ive encoded with ConvertXtoDVD and the outcome is still a jerky dvd. Mybe im doing something wrong. Below ive typed out what the log says.
The Log says:
Video bitrate 0/6359/8052 Kbps 9min/avg/max)
Widescreen (16:9) set automatically
NTSC 29.97FPS output format set automatically
Video source original frame rate: 23.98
Padded source image: Left 0, Top 56, Right 0, Bottom 56
Video stream #0 Pulldown: 23.976->29.97 Fps
Output Stream#0-Video: mpeg2video, yuv420p, 720x480, q=2-31, 6359kb/s
Can anyone tell me if this sounds right.????? -
Your log looks okay. Maybe your viewer is not giving you a smooth playback. Or, maybe the original AVI wasn't of high enough quality.
Where (or when) does it look jerky?ICBM target coordinates:
It is constant jerkyness. Most noticable when the camera pans along a road for example. The source avis are high quality. Maybe its summit i'll just have to put up with.
Maybe you have a field order problem. Like you encoded it bottom field first and are playing it top field first. Something like this would definitely cause jerkiness.
Is this not just a natural consequence of the pulldown? An option would be to speed up the video and audio to 25fps and make pal dvds. That should retain the fluidity you require. But then you have a different problem - fixing the audio pitch.
When you get to the end of the log, how many duplicated frames are there ? It will tell you if it created any. If pulldown has been successfully used, instead of actually changing the framerate, there will only be a handful. If the framerate has been changed there will be thousands of extra frames.
I suspect your problem is your player and TV not working together correctly. I'll tell you why I suspect this.
Recently I aquired a new DVD player. It is a Divx certified player, and it was given to me by one of my utilities providers as a loyalty bribe. It is an LG. The picture quality is OK (not as good as my Pioneer), but it plays most avis. It was region locked to Region 4, but a quick fiddle with the remote fixed that. I threw in a test disc - an avi with a 23.976 framerate, and it plays back without issue - except that my TV is seeing a PAL signal, and the zooms and pans are jerky.
So I test it with a DVD that I know has been correctly encoded at 23.976 with 2:3 pulldown, and get the same thing. Not happy.
After some more ferreting around, it turns out that the format can be altered PAL, NTSC or AUTO, but holding down a key on the remote for 5 seconds after turning the thing on (nice and obvious and easy to find in the small print at the back of the manual - thanks LG). So I set the format to Auto. I put on a disc with 6 avi files - a mixture of PAL and NTSC 23.976 material - and test it. It switches format as required. The TV detects the format changes, as it should. And the zooms and pans are now as smooth as you can get from NTSC.
So I think ConvertXtoDVD is doing what it should. You have to make sure that the player is outputting a native NTSC signal, and that your TV is able to accept a native NTSC signal, or it really doesn't matter what you do.Read my blog here.
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 23:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 04:20 -
Help Aspect Ratios & Frame Rates
By CTP-Crystal in forum Newbie / General discussionsReplies: 21Last Post: 1st May 2009, 19:10 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 12:15
