Does anyone own this PC? It says it has one PCI slot, but that it is used. What is it used for? I saw one post where someone said they added a TV tuner card. This small computer has no fan, so if it is powerful enough and can accept a tuner card, it might make a good PVR.
Results 1 to 13 of 13
Looks like its occupied by a modem.His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
What is that Orange RCA connector next to the kbd and mouse din-5 connectors for ?
Does anyone know if it is possible to add a capture card, or video card with capture and S-video out for connecting to a TV?
If you do not need the modem then remove it and install your video/capture card there.
bits -
Can the on-board video be disabled in favor of a video card with capture/S-video out?
yes it can be but you may not necessarily need or want to. It just depends on what you want to do.Originally Posted by drstewbits
Ask HP. I was looking into this model before, and found out that there was no possible way to add a 2nd hard drive. I know that's not what you were asking so that's why I've add the Contact HP link.
What We Do In Life, Echoes In Eternity.... -
I'm assuming that's a SPDIF in or out.Originally Posted by SingSingHis name was MackemX
Does anyone know how much power can be delivered to the PCI slot? Can a Hauppauge WinTV-PVR-350 or an ATI 7500 AIW VE work with this computer?
Some of these machines ship with TV tuner cards from the factory. If you haven't bought the machine yet just got to
http://www.shopping.hp.com/webapp/shopping/computer_can_series.do?storeName=computer_s...=s7600y_series
and configure your machine with a TV tuner.
If you already have the machine you can go to
http://h20141.www2.hp.com/hpparts/Search_Results.asp?mscssid=XH0U5LLA4RXT9HH14AK17PD81FCT4L34
and buy the same tuner that HP uses in the production machines as a "spare part"
the part number is EX437-69001 and it only costs $78Go HP Slimline! -
Hey, are you Ken Bosley of HP Marketing? If you are, I posted a message for you on the Pavilion Support forum. I really want to get an s7700y customized Slimline, but it's not available, at least through regular resellers, here in Canada.
Does anyone know how I might get an s7700y to a Canadian address?
Media Center
By superc in forum LinuxReplies: 4Last Post: 7th Jan 2011, 20:39 -
Media Center packages
By nlaak in forum Software PlayingReplies: 3Last Post: 14th May 2009, 15:42 -
Capturing on Hp Media Center PC
By MuffinMaYne in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2007, 12:18 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33 -
Media Center Help
By rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 14:06
