Hi ive got a music video with out of sync audio but the audio is out of sync by different amounts through the vid.Is anyone here willing to get this vid into sync if i give it to them?The vid is 1:07 long and 420mb
Closed Thread
Results 1 to 19 of 19
I'd rather eat a can of worms!
/Mats
A number of method's are available to you if you want to do this yourself , which would save you money .
You could break it up , using virtualdub first .
I normally break the first clip just before it become's noticable .
This clip is left un-adjusted ... the next clip , and those after are edited ...
Then extract the audio to wav using virtualdub .
Then use hyper cube transcoder , load video , and the wav that was extracted .
Play video , and make any adjustment's to the audio as required , then when happy , hit the render button .
Move on and repeat step's for next section that require's adjustment .
Rejoin clip's later in vdub using the append method ... search for post's on append here should turn up some , I have replied to these , read what I have said and you should be fine .
Other method :
Use goldwave to adjust the audio (strech section's to resync) , or reaper which is freeware (dosent handle hugh file's (why I suggested clipping video into section's) .
Yet to write the guide on those ... very busy with other's .
You need to reconnect the adjust audio stream after it is saved back to video clip in virtualdub , and play it back , though virtualdub start's dragging the audio after 6 minute's of playback ... consider connecting new audio in hyper cube transcoder , and check it there .
I have tested hyper cube transcoder with an avi made from a full dvd title ... 700mb's , and it dosent drag the audio at all .
Another good method that work's , especially for mpeg's is visualsubsync .
It too keep's audio in sync while playing it back , but is not a tool for audio resync , you need to use an audio editor for this , but it can loop the playback of the area that has the issue ... a little time consumming , but pro result's take time anyway .
I once did this for someone else ... and I nearly went insane ... I had to hold my tongue when they collected it ... otherwise they were going to get an ear full .
To resync it on your behalf , consider $100.00au as a minimum if I have to do it .
Otherwise be patient , and I'll get a couple more guide's up before soon on some of the tool's mentioned here .
Also take a look in the guide's section for other bit's and piece's ...
Originally Posted by ROF
You are totally wrong actually because someone has uploaded this video on the internet using store and serve and the video is not official material as it has not been released as it is an old tv broadcast.This is totally legal.I agrre with you that people shouldnt download illegaly.
Tv broadcasts are copyrighted and you'd need to contact the affiliate and the owner of the material (the original owner - Iron Maiden) in order to be authorized. That's why I said jail time should be imposed. You don't even realize the crime you've done because you didn't walk into a store or someones home and steal something.
THIS IS THEFT OF INTELLECTUAL PROPERTY!
I'm locking this down until I speak to the other moderators and we agree on what to do.
Please bear with us.
Regards,
Cobra
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
