hi all who is reading this ,i'm new at this i'm probley not in the right place ,sorry for that can some tell me how to hack into my DVD player it is Tevion MD 80137 please all i've read are old from 2002. thanks i've bought region 1 but i am on 4 .hope to here from someone please.Cheers m/m![]()
Hi m/m,
Welcome to the forums.
Is your player in the "DVD Hacks" list? The link is on the left hand side of this page <---
If not, have you tried a Google search?
Failing that, you could rip the DVD, shrink it (if needed), and burn to a DVD+/-R. During this process, you can choose to remove the region code so that it'll play on any region player.
I hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thanks i've burned it &put in my DVD to add .The thing is where do they write the ansewerOriginally Posted by daamon
So you've ripped, shrunk (if needed) and burned a DVD backup? Did it work OK?Originally Posted by m/m
I'm not quite sure what you mean... Are you asking to have your player's hack details added to the list? If it gets done, I presume it'll be in that same list...Originally Posted by m/mThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 22:10 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Total Newbie -- Best/cheap way to rewrite a Region 2 DVD to Region 1
By jteselle in forum Newbie / General discussionsReplies: 6Last Post: 3rd Nov 2009, 12:49 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58
