Results 1 to 9 of 9
    Feb 2006
    Is there something similar to DVD Shrink for a MAC?
    SGHOGAN
    Feb 2006
    sghogan
    Take a look at DVD2oneX...Also Toast 7 has compression facility...don't forget to try searching the forums for DVD compression on the Mac...
    ...J
    DVD Remaster is also excellent.
  4. Popcorn - compress and burn, ~ $40
    Toast - compress and burn, and more, ~ $80
    DVD2One - compress and burn, ~ $60
    DVD Remaster - compress only, ~ $40
    FastDVDCopy - compress and burn, ~ $80
    DragonFlix - compress and burn, ~ $40
    Feb 2006
    Thanks to everyone for the responses
    SGHOGAN
  6. Member bokguay's Avatar
    Mar 2006
    California
    What about the most important part about DVDShrink which is that it's free
    Feb 2006
    I was hopeing for something free but it looks like that won't be the case for a mac.
    SGHOGAN
    Nov 2007
    Shrinky-DVD-ink has an interface similar to DVD Shrink
    www.shrinky-dvd-ink.com
    Aug 2005
    Palo Alto, California USA
    A not-free, but inexpensive, option is ffmpegx. Once you've paid your registration fee, you can gain access to its shrink tool. I've never used it, and it looks very basic, but it should get the job done if you only care about preserving the main title. If you need to do a lot of complex reauthoring, then you'll need to use something else. But for a basic "shrink the main feature to fit on a DVD5" task, ffmpegx should work.
