Hi,
I have some huge mpeg-2 files, ripped from DVDs, that I want to convert to AVI.
I use FFMPEG and give this command :
ffmpeg.exe -i movie.mpg -f avi -vcodec mpeg4 -b 600 -bf 2 -sameq -acodec mp3 -ab 128 my_movie2.avi
it works but I have 2 problems :
If I omit "-sameq" parameter the resulting AVI is bad, the image flicks, there is some pixels around
Otherwise, if I include "-sameq", the programm ignores the bitrate value and the resulting is a Huge size AVI.
please, can someone help me ?
thanks
Well -sameq means same quality as the source so of course it ignores bitrate. Fact is that 600 is probably too low a bitrate for DVD res MPEG-4. Try -vcodec h264, a higher bitrate or resizing down.
Just tried it and it works fine here. Did you enable x264 when compiling?
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-theora --enable-mp3lame --enable-libogg --enable-vorbis --enable-faad --enable-faac --enable-xvid --enable-x264 --enable-mingw32 --enable-a52 --enable-dts --enable-pp --enable-gpl --enable-memalign-hack --enable-amr_nb --enable-amr_wb
libavutil version: 49.0.0
libavcodec version: 51.5.0
libavformat version: 50.2.1
built on Feb 15 2006 02:18:12, gcc: 4.0.2 -
thanks for your help, and sorry my ignorance
My system is Windows XP, I have FFMPEG executable for windows
None of that configuration switches works with me
what the correct command to enable that ?
is like this :
ffmpeg.exe -i movie.mpg -f avi -vcodec h264 -b 600 -bf 2 -acodec mp3 -ab 128 my_movie2.avi --enable-x264
I don't have : libavutil libavcodec libavformat, either
just have FFMPEG.EXE (built on Feb 22 2005 04:58:29, gcc: 3.4.2 (mingw-special) and a DLL named pthreadGC2.dll -
Those are the switches that were used with ./configure. For yours --enable-pthreads was obviously used. I don't bother with that normally since I only have one core and it creates an extra dependancy.
libavutil, avcodec and avformat are part of ffmpeg.
Doesn't sound like you compiled it though. Where did it come from? ffmpeg -formats will list what is supported, but you can also tell if x264 was enabled as above in bold. --enable-gpl is also required since x264 is gpl. Could be that whoever compiled it want to keep it lgpl. So no x264, xvid, etc.
err, hang on feb 2005. I was thinking feb 22 2006, although only an hour or so in.
ffmpeg version 0.4.9-pre1, build 4743, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-vorbis --enable-faad --enable-faac --enable-xvid --enable-mingw32 --enable-a52 --enable-dts --enable-pp --enable-gpl --enable-memalign-hack
ffmpeg 0.4.9-pre1
libavcodec 4743
libavformat 4621
That is actually one of my old builds. pthread wasn't enabled though so I don't know why that dll is present. Should just be ffmpeg.exe and ffplay.exe
As you can see x264 is not enabled. I don't think ffmpeg even supported it back then.
Also remember x264 was just one suggestion. Lowering the res would help since the bitrate would be more suitable. Upping the bitrate wouldn't be possible though if that was what you calculated for a 700MB encode. -
I downloaded my version of FFMPEG from videohelp
ffmpeggui03c.zip
I am totally null to C or C++ code, I am experienced with DOT.NET only.
I would like to have a full version of FFMPEG with all that configurations enabled, mainly MP3+WAV+DTS+DIVX+RMVB+WMV+WMA
but, anyway, I managed to solve my problem thanks to your help...
The only problem is : How to resize the image in order to avoid squeezed and thin images, or fat ones ?
don't know what calculations must I do to correctly resize the image, either :
from MPG to AVI using FFMPEG (and -s switch)
or from AVI to DVD using AVISYNTH frameserver (Lanczos4Resize + AddBorders) -
Yeah, the ffmpeggui package got updated with my ffmpeg build of the time. I have compiled numerous other builds since then though, including one yesterday.
Thin is fine. The original DVD would be thin too. You just need to set the PAR approriatly so that it resizes correctly on playback. Otherwise just calculate and crop/resize to 1:1.
FFmpeg on Win only - FAQ can ffmpeg realize screen capture
By feelart in forum Capturing and VCRReplies: 1Last Post: 14th Feb 2012, 04:11 -
Which ffmpeg options are used behind the scenes by ffmpeg?
By roberto.aloi in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2011, 05:09 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Difference between ffmpeg -threads and ffmpeg-mt
By Calidore in forum Video ConversionReplies: 2Last Post: 7th Mar 2010, 22:44 -
FFMPEG QUESTION :How do I take one frame and make a jpeg with FFMPEG?
By goheadtry in forum Newbie / General discussionsReplies: 1Last Post: 18th Sep 2007, 02:55
