There is a LOT of discussion surrounding DVDs as a media, but very little regarding DV tape. Has anyone any personal experience with DV and DVCAM tape insofar as reliability, portability, re-usability, etc? Any difference between a $5.00 Maxell 60 minute tape and a $9.00 Sony? DVCAM truly better than DV?
Pro level MiniDv tapes are built for more rugged use, faster rewind without stretching, etc.Originally Posted by slacker
Start here.
http://www.taperesources.com/faq.html
http://www.taperesources.com/dvcam_tapes.html#article5Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
@slacker, I have no experience with DVCAM tape.
Quick and general.
1. Select one type of tape and stick to it, different tape brands can use different lubricants mixing them can gum up your heads (Sony tech support).
2. If you intend to play the tape in different devices record only in SP mode. Some LP modes don’t travel well. If I am capturing broadcasts or VHS tape I use LP mode. Because the process is digital no bits are lost when using LP as opposed to SP (Sony tech support).
3. Many people (like me) prefer to write timecode over the entire tape before recording anything. This is usually done by recording the tape with the lens cap on, purists say you should use a editor to record a black frame to the entire tape.
4. Some people think the most expensive thing is always the best, this has never been true. Just get a good brand name tape that’s available locally. Paying for shipping can eliminate any savings you thought you were getting.
5. I don’t usually record on a tape more than four times, I have never had any problems. The only reuse problem I had with a tape was when I used my camcorder in still/photo mode. No matter what I did I could not fully erase the tape and record over “the photos”.Emray holdar naaro watt -
I tend to be very conservative on use of LP mode and don't recommend it for any serious work. LP mode uses thinner tracks (6.7 micron tracks instead of 10 microns for standard DV and 18 microns for DVCAM). Unlike analog, the downside of LP mode is not recording quality, it is ability to track during playback at all. Digital playback is either good or total failure. DV camcorders have error correction for small dropouts but that can't correct tracking errors.Originally Posted by holdar
- LP is extremely risky for playback on other equipment
- LP won't play on most pro DVCAM equipment at all.
- LP is at risk of not playing on the same camcorder in the future if the tape path wears or goes slightly out of alignment. SP is much more robust.
The only time I would consider using LP mode is for these cases:
- Event recording where the extra recording time is essential to avoid changing tape and missing action. In that case, I would create a backup on HDD or SP tapes at the first opportunity.
- Media dubs where the goal is DVDR backup. Any long term backup in DV format would be done in SP mode.
I always do this to avoid timecode gaps. Proper use of "cue to end" can substitute for striping tape but I still seem find a way to create gaps through user error unless I stripe the tape.Originally Posted by holdar
Costco and Sams always have good 62 minute MiniDV prices without relying on sales or rebates. DVCAM tapes are very expensive locally and difficult to find.Originally Posted by holdar
I always use new or near new tape for serious event projects, location work, etc. But for general use I reuse tapes until they get >5 yrs old and have had no real problems so far. I use DVCAM tape for work-in-progress project backups even when using DV mode. These tapes get heavy winding.Originally Posted by holdar
I use both consumer MiniDV and DVCAM camcorders.Recommends: Kiva.org - Loans that change lives.
This is an area I am most unfamiliar with and, because of that, I wind up quite probably spending more money than I ought to for the added emotional security of knowing I went with the best, or my version of it, which may, in fact, be totally wrong. I appreciate your time and comments. Thank you sirs!
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 00:01 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
Backup of MiniDV tapes
By m0cka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 22nd Oct 2012, 10:54 -
miniDV tapes to DVD
By zoranb in forum MacReplies: 37Last Post: 7th May 2011, 16:32 -
copy miniDV tapes
By circc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Feb 2008, 19:27
