  1. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    any software i can use to convert my 5 PC Game or PC Installer CD to 1 DVD. im tired of inserting 1 CD after another when installing my game and other softwares. I was not able to buy then the DVD version so i got these 4-5 CD installers...
    hacking the Net using typewriter :D
    Probably dump ISO's to the disc, and then load each one in Daamon Tools when you need to run them.
    Mar 2004
    London
    1. Install full game.
    2. Remove cd-check - http://www.gamecopyworld.com/
    3. Pack to SFX multi-rar (100mb per segment) - http://www.rarlab.com/
    4. Burn to DVD.
  4. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    which one will i pack to sfx? the fullgame installed in my pc?
  5. u can try this link
    http://www.msfn.org/board/index.php?showtopic=24421
    well u can try 2 sfx the game or just convert ur game setup into SEA(self extracting archive)thru winrar
    Mar 2003
    I think you might need a drink
    Alcohol 120%
    Actually its a good program for making mountable disk images and things that are normally tough to backup
  7. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    i got alcohol 120% but i dont know how to use it to convert my 4-5 cd installer to dvd.
    ill try also winrar...
    Mar 2003
    First you must create an image for each disk
    then
    Look under the device tab for the mount and unmount images commands
    http://support.alcohol-soft.com/en/documentation/alcohol-user-manual.pdf
