  1. I'm trying to extract the subtitles from this website... but they are displayed like the image.. could someone help me..
    https://kisskh.co/Drama/My-Dearest-Nemesis/Episode-12?id=10170&ep=178314&page=0&pageSize=100
    Thanks in advance
    責任者-MDX
  2. I found this guide of: 2nHxWW6GkN1l916N3ayz8HQoi , https://forum.videohelp.com/threads/417527-help-in-decrypting-the-subtitle#post2766956
    I'll put it into practice... if anyone knows another method I would appreciate it.
    責任者-MDX
  3. Originally Posted by sekininsha View Post
    https://www.swisstransfer.com/d/57d2324c-4a8a-464a-9e7f-1136653ea0be
  4. this is the interesting part
    We have an obfuscated function responsible for decrypting encrypted texts in subtitle files:
    function _$af182998(n, e) {
        if (jso$ft$uoel$_33(jso$ft$giden$window()[_$_7270[3]][_$_7270[2]][_$_7270[1]](_$_7270[0]))) {
            return _$_7270[4]
        ;var i = jso$ft$giden$JSON()[_$_7270[6]](jso$ft$giden$atob()(_$_7270[5]));
        return e[_$_7270[12]][_$_7270[11]](n, e[_$_7270[8]][_$_7270[7]][_$_7270[6]](_$_7270[10]), i)[_$_7270[9]](e[_$_7270[8]][_$_7270[7]])
    After analysis using Chrome DevTools, we identified it uses the following array:
    _$_7270 = [
        "kisskh",
        "includes",
        "href",
        "location",
        "k-i-s-s-k-h.-l-a",
        "eyJpdiI6eyJ3b3JkcyI6WzEzODIzNjc4MTksMTQ2NTMzMzg1OSwxOTAyNDA2MjI0LDExNjQ4NTQ4MzhdLCJzaWdCeXRlcyI6MTZ9fQ==",
        "parse",
        "Utf8",
        "enc",
        "toString",
        "AmSmZVcH93UQUezi",
        "decrypt",
        "AES",
        "k-i-s-s-k-h.-c-o",
        "eyJpdiI6eyJ3b3JkcyI6Wzk0Njg5NDY5NiwxNjM0NzQ5MDI5LDExMjc1MDgwODIsMTM5NjI3MTE4M10sInNpZ0J5dGVzIjoxNn19",
        "sWODXX04QRTkHdlZ"
    After deobfuscation, the function becomes clear:
    function jso$ft$uoel$_33(a) {
        return !a
    function jso$ft$giden$window() {
        return window
    function jso$ft$giden$JSON() {
        return JSON
    function jso$ft$giden$atob() {
        return atob
        if (jso$ft$uoel$_33(jso$ft$giden$window(), location.href.includes("kisskh"))) {
            return "k-i-s-s-k-h.-l-a"
        var i = jso$ft$giden$JSON().parse(jso$ft$giden$atob("eyJpdiI6eyJ3b3JkcyI6WzEzODIzNjc4MTksMTQ2NTMzMzg1OSwxOTAyNDA2MjI0LDExNjQ4NTQ4MzhdLCJzaWdCeXRlcyI6MTZ9fQ=="));
        return e.AES.decrypt(n, e.enc.Utf8.parse("AmSmZVcH93UQUezi"), i).toString(e.enc.Utf8)
    Function Workflow Explained
    1. URL Verification:
    - Checks if current URL contains "kisskh"
    - Returns fixed fallback text (`k-i-s-s-k-h.-l-a`) if verification fails
    2. IV Preparation:
    - Decodes base64 IV string to JSON:
    - Represents 128-bit IV for AES-CBC mode
           "iv": {
             "words": [1382367819, 1465333859, 1902406224, 1164854838],
             "sigBytes": 16
    3. Key Preparation:
    - secret key: AmSmZVcH93UQUezi
    - Converts to UTF-8 format using cryptoModule.enc.Utf8.parse()
    4. Decryption Process:
    - Uses AES mode
    - Inputs: Encrypted text + Secret key + IV
    - Output converted to UTF-8 string
    decryption process in python:
    #pip install pycryptodome, requests
    import requests
    from base64 import b64decode
    from Crypto.Cipher import AES
    from Crypto.Util.Padding import unpad
    import re
    import os
    def decrypt_subtitle(encrypted_b64):
        SECRET_KEY = b"AmSmZVcH93UQUezi"
        IV_WORDS = [1382367819, 1465333859, 1902406224, 1164854838]
        iv_bytes = b''.join(word.to_bytes(4, 'big') for word in IV_WORDS)
        try:
            encrypted_data = b64decode(encrypted_b64)
            cipher = AES.new(SECRET_KEY, AES.MODE_CBC, iv_bytes)
            decrypted_padded = cipher.decrypt(encrypted_data)
            return unpad(decrypted_padded, 16).decode('utf-8')
        except Exception as e:
            print(f"Error {e}")
            return ""
    def download_and_process_subtitle(url, output_file):
        try:
            response = requests.get(url)
            response.raise_for_status()
            subtitle_content = response.text
            processed_lines = []
            segments = re.split(r'\n\s*\n', subtitle_content.strip())
            for segment in segments:
                lines = [line.strip() for line in segment.split('\n') if line.strip()]
                # if len(lines) < 3:
                #     continue
                segment_num = lines[0]
                time_range = lines[1]
                encrypted_text = ''.join(lines[2:])
                decrypted_text = decrypt_subtitle(encrypted_text)
                processed_lines.append(f"{segment_num}")
                processed_lines.append(time_range)
                processed_lines.append(decrypted_text)
                processed_lines.append("")
            if processed_lines and processed_lines[-1] == "":
                processed_lines.pop()
            with open(output_file, 'w', encoding='utf-8') as f:
                f.write('\n'.join(processed_lines))
            print(f"saved in: {os.path.abspath(output_file)}")
            return True
        except requests.exceptions.RequestException as e:
            print(f"Error: {e}")
        return False
    if __name__ == "__main__":
        subtitle_url = "https://sub.streamsub.top/One.High-School-Heroes.2025.Ep8.en.srt.txt1?v=qv2hnadrsft"
        output_filename = "subtitle.srt"
        download_and_process_subtitle(subtitle_url, output_filename)
    https://gofile.io/d/NVqvZE
  5. Thanks everyone... well yes both methods work ... yes
    @slayer36 Thanks for the help... I finally managed to do it...
    @imr_saleh ... Thanks for the analysis and this very good and fast solution above all.
    責任者-MDX
