WARNING: The program was developed by another person, not the OP. For official support, consider opening an issue on its GitHub page, or sending an e-mail to the address seen in commits.
This program is primarily intended as a fallback mean for unintercepted EME operation if Vineless fails to work, as well as for the perfectionists who want the replacement CDM to be in the same location as the original one. For most other cases, it is unnecessarily complicated, and Vineless should be used instead.
Official GitHub page for the program is available here, together with installation instructions.
OpenWV is an open source reimplementation for Widevine library present in Google Chrome web browser and downloaded on first use in Firefox. It doesn't, however, come with a CDM, so to use it, you need to find one yourself.
Its benefit over other programs released earlier is that you don't have to run untrustworthy official Widevine library to obtain information needed to receive keys. However, these programs can still be used together with OpenWV. Additionally, with OpenWV, you can stream content in your browser while using a CDM other than ChromeCDM, which might result in better quality content being provided depending on the CDM and the streaming service.
Once the library is replaced, you can use it to just play Widevine content, or you can launch your web browser from command line, and see the keys that were loaded. On Linux, it is enough to just launch the browser. On Windows, the following commands are needed:
Firefox:
Last edited by ytdlhelp; 22nd Aug 2025 at 11:48. Reason: Add a line about Vineless recommendation, to avoid people from unnecessarily trying complicated solutions
Pre-built Windows versions (built on 64-bit Windows 10, compatibility with other Windows versions and architectures not tested) are provided due to complications with building this software (a lot of disk space required). The CDM used is the first one from here.
After the update, no "old" version is needed anymore, as both CDM interfaces 10 and 11 are supported now.Last edited by ytdlhelp; 22nd Aug 2025 at 11:36. Reason: Updated to latest version
Keys for vdocipher
https://www.vdocipher.com/
https://www.vdocipher.com/video-security/
Code:*** You are running in background task mode. *** *** You are running in headless mode. console.error: "C:\\Users\\ \\AppData\\Local\\Mozilla\\Firefox\\Profiles\\bmk0254v.default-release" "" 0 ".purge.bg_rm" "" console.warn: "Skipping Glean as no metrics id is passed" [OpenWV INFO ] OpenWV version 1.0.0 initializing [OpenWV INFO ] Registered new session BA238352A05EFCA131AC29FAF5150DDF [OpenWV INFO ] Registered new session 13DD8D32F662AB46D8BF9E07CE9FC029 [OpenWV INFO ] Registered new session E97C7B6ECA87A81913BE6175BA9B6857 [OpenWV INFO ] Registered new session F03AC3A74E7735525F9D381ACD95EBDD [OpenWV INFO ] Service certificate provider: license.widevine.com [OpenWV INFO ] Service certificate provider: license.widevine.com [OpenWV INFO ] Service certificate provider: license.widevine.com [OpenWV INFO ] Service certificate provider: license.widevine.com [OpenWV INFO ] Loaded key: 5ed258662b788dcde85dc9cb7089a2eb9856b3bfb09d705a9e272329ec52b5cb07fa37d35afbd80e3b9da2cd345af0a8ac5aaafc204b672f08ab211dc77d317b [Signing] [OpenWV INFO ] Loaded key: bc4fceef795251288471c3b817f75e8b:802e6854da026e45ead571ed18b1061d [Content: "UHD1"] [OpenWV INFO ] Loaded key: a3633877eab35fa1821dd14c0fdbe6fb:13b9279efc88fac1263d7de8e47dab89 [Content: "HD"] [OpenWV INFO ] Loaded key: f6059a3880185904a3e40848ff664b53:5d3ec302361a446a094fa569ba5a4b13 [Content: "SD"] [OpenWV INFO ] Loaded key: f83482f1c8255e8db31fa10b2e40a145:d5d98598c754df127b08aa68ef137bb9 [Content: "AUDIO"] [OpenWV INFO ] Loaded key: fa99091ad4bc5dee5387189914ef37f8cce6f517eae00966e9795d0632b8c9713a7c275a4574b56b450ab633b4af4b6de91fdf6f9db74a5021a1d464b2cde742 [Signing] [OpenWV INFO ] Loaded key: c117d204b0ad506f8eff4efc563c0f75:f12283aedf468bfc17b61b1dcf107c3b [Content: "UHD1"] [OpenWV INFO ] Loaded key: 5415f4b24c955adaa1c3b7be3059a2a9:1ec4bdbcbdb7458a107f0a361799974f [Content: "HD"] [OpenWV INFO ] Loaded key: aa4cea1b870658d4bfc82872003cb6d9:5b7549688894d832c7a73266bd586ec5 [Content: "SD"] [OpenWV INFO ] Loaded key: a7d786c469c9558494ebf62227e6486c:faf6952c760c044bf50853a76c91a6a6 [Content: "AUDIO"] [OpenWV INFO ] Loaded key: b76f7878c1e479ed2ef2b7ba8b7346e502f028bc2cc11c3777bd55bd66853f7ff84fa0f52bd948a63a9f254a11fe2a6f1242d3e7716533d390355561eb447a19 [Signing] [OpenWV INFO ] Loaded key: 25e71357438158cca81e874273a81c2b:1cee0f3a6c082ae1b29e06c0fe95f67c [Content: "UHD1"] [OpenWV INFO ] Loaded key: d3710758eb7f5d46b90bfd8ef639a306:098d01555a41af032f62b702e98119c6 [Content: "HD"] [OpenWV INFO ] Loaded key: eb4e643d27205b7ea2497d147bea5dab:207df521ccbe1986b28423918d8d155b [Content: "SD"] [OpenWV INFO ] Loaded key: 094a7e2e6c815aa18c3d89ce76a45f7c:c1055fa8d0325ba743a97af0e6795790 [Content: "AUDIO"] [OpenWV INFO ] Loaded key: f55dcfdd29a9d713ae0b99ad18fb77516a07bd2c5af43ce985878635740ac5fa54e86aa4b862ea58ddd9e8417024ca51919aec95a7216cda94c3cd72c90aad72 [Signing] [OpenWV INFO ] Loaded key: 319adfe433575f5ba81cb5aee573f46c:929c1c9e91f36b6d1b83927974b4a703 [Content: "UHD1"] [OpenWV INFO ] Loaded key: b70943b3b7725902b98d36de9ae09f9b:6f18290010504a4def15efe44a975e4a [Content: "HD"] [OpenWV INFO ] Loaded key: 6de24511ec2d537a8cebffbf2956f994:e43c3510c77c36d3ee63ef5e0930f5b9 [Content: "SD"] [OpenWV INFO ] Loaded key: 818d3ef5129d5c5e9e85965e6ace4861:a400055b8dee1cfd059796dab1339cac [Content: "AUDIO"] [OpenWV INFO ] OpenWV version 1.0.0 initializing [OpenWV INFO ] Registered new session 72A95882DC610D15799D8EE9CF2E7FDB [OpenWV INFO ] Service certificate provider: license.widevine.com [OpenWV INFO ] Loaded key: 4fa04ba139dff83ae13079f237a2a84662a825f3f83e564a875d7109320a4055ba16e0573325fa9b9ad0ec890ee72f92961824f5db1ac8421f5d5f312f658dea [Signing] [OpenWV INFO ] Loaded key: eaa6cab618a454588eaef56d20e96b6e:50b97074ddfbc20c3ce7be1de0208734 [Content: "UHD1"] [OpenWV INFO ] Loaded key: 0ccba3918015569d83b564725f8b42d6:efbe28be0bd74e94f8129d2f8316bf31 [Content: "HD"] [OpenWV INFO ] Loaded key: 5f23efb159755324bff8ba6b34a087ae:8827d705c509ca24e4c41cb27bd9a2db [Content: "SD"] [OpenWV INFO ] Loaded key: 231a072af6665ffbb84966f6c92695da:923cdb3e1f0f2ee6f36af1c23ecd059f [Content: "AUDIO"] *** You are running in background task mode. *** *** You are running in headless mode. *** You are running in background task mode. *** *** You are running in headless mode.
P.S.
From me a star on the github.comLast edited by ddll2; 24th May 2025 at 08:59.
Turns out that --console is not required
This will work
Code:@echo on "C:\Program Files\Mozilla Firefox\firefox.exe" > D:\firefox_log.txt 2>&1
what CDM version needed for VDOCIPHER ?
I tried two real cdm files but not working , giving (Error 2046 Authentication failed). other sites working ,
my cdm is L3 , one from android 9 , and one from android 13 samsung device . -
for VDOCIPHER use https://github.com/FoxRefire/wvg/tree/next or Tubedigger in MonitorBrowser/RecMode
[OPEN SOURCE] AudioAlign: Audio Synchronization And Analysis Tool
By forart.it in forum Latest Video NewsReplies: 10Last Post: 18th Aug 2025, 06:45 -
Open source editor with decent lumi control?
By Golem in forum EditingReplies: 2Last Post: 16th Feb 2024, 16:21 -
Need help with downloading Streaming Titles in Open Source
By Pingu89210 in forum Video Streaming DownloadingReplies: 3Last Post: 2nd Jun 2022, 14:16 -
Open source video codecs for Windows?
By ziptip in forum EditingReplies: 3Last Post: 14th Apr 2022, 19:18 -
download manifest open source demo video
By Lionking in forum Video Streaming DownloadingReplies: 4Last Post: 9th Jan 2021, 10:31
