WARNING: The extension was developed by another person, not the OP. For official support, consider opening an issue on its GitHub page, or sending an e-mail to the address seen in commits.
Official GitHub page for the extension is available here, together with installation instructions.
Vineless is a replacement extension for WidevineProxy2 and PlayreadyProxy2. Unlike the mentioned extensions, key systems are implemented entirely in the extension, and acquired keys are then proxified to ClearKey. For average user it means PlayReady support in non-Edge browsers.
Results 1 to 20 of 20
Can this program generate the N_m3u8DL-RE command to copy and paste into N_m3u8DL-RE? Thank you for letting us know about this new tool. I hope they get one that can generate a N_m3u8DL-RE command for content that isn't encrypted.
yes they do, same like widevineproxy2
but I have test this and widevineproxy2
this one will not work on pcok and amzn but dtv is work not wvp2
so I keep this one for working on some site -
This program sometimes fails to work where OpenWV or WidevineProxy2 work. I sent an e-mail to the author, but not sure if it gets noticed.
I installed it on Firefox alongside WidevineProxy2. I tried it on Plex and WidevineProxy2 generated the keys and N-m3u8DL-RE command but Vineless has generated nothing. I used the same .wvd as WidevineProxy2 as the first one I put in didn't work so I thought use the same one as WidevineProxy2 and it should work. Can Vineless and WidevineProxy2 co-exist in the same browser. Thanks in advance for any guidance.
Could not reproduce. For me both extensions work. Make sure DRM notification (black circle with white chain) is not displayed when the video is playing, otherwise it means Vineless doesn't work. They can co-exist as long as one of them is fully disabled (on extensions page). Attempting to use both at the same time will lead to conflicts.
Thank you ytdlhelp. I disabled WidevineProxy2 on the extensions page and gave it another try. This time the N-m3u8DL-RE command was there and worked. I really hope that for the websites with no encryption that this program can at some point generate the N_m3u8DL-RE command that could come in quite handy.
the download buttons on the extension, if pressed, do nothing. They should expect to download widevine and playredy remote cdm...
hey,
does anyone know how to clear the keys automatic after closing the browser or for any other action?
or any other solution to change the order of the keys?
maybe its possible to do it by editing some files of the extension instead of coding?
thx in advance,
tom -
I tried with AMZN, but i can't get any cmd that works.
my error:Code:N_m3u8DL-RE "https://abf75oqaaaaaaaamnupkjhgtgagny.ta.pop-vod-dash.main.amazon.pv-cdn.net/dm/3$0CiEIARoFaXRfSVQgSDABUgaAwAKB8AN6A4C4F4IBAQGIAQQYAQ/ww_dub/1968/cc58/daf7/495e-93e6-26c6b904e72e/1abd6186-0c85-412b-9918-0f4fa6768c8a_corrected.mpd?amznDtid=AOAGZA014O5RE&encoding=segmentBase" -H "Accept: */*" -H "Origin: https://www.primevideo.com" -H "Referer: https://www.primevideo.com/" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/144.0.0.0 Safari/537.36" --key fa2dff1c12ba4a469d47275b9c7e6ffd:c214186cf33934602f1ad164f08af40f --decryption-engine SHAKA_PACKAGER -M format=mkv:muxer=ffmpeg -sv best -sa all -ss all --save-name "Prime Video: A Working Man"
URL:Code:PS Z:\DRM\app_files> .\N_m3u8DL-RE.exe "https://abf75oqaaaaaaaamnupkjhgtgagny.ta.pop-vod-dash.main.amazon.pv-cdn.net/dm/3$0CiEIARoFaXRfSVQgSDABUgaAwAKB8AN6A4C4F4IBAQGIAQQYAQ/ww_dub/1968/cc58/daf7/495e-93e6-26c6b904e72e/1abd6186-0c85-412b-9918-0f4fa6768c8a_corrected.mpd?amznDtid=AOAGZA014O5RE&encoding=segmentBase" -H "Accept: */*" -H "Origin: https://www.primevideo.com" -H "Referer: https://www.primevideo.com/" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/144.0.0.0 Safari/537.36" --key fa2dff1c12ba4a469d47275b9c7e6ffd:c214186cf33934602f1ad164f08af40f --decryption-engine SHAKA_PACKAGER -M format=mkv:muxer=ffmpeg -sv best -sa all -ss all --save-name "Prime Video: A Working Man" --custom-proxy http://127.0.0.1:1080 11:52:45.720 INFO : N_m3u8DL-RE (Beta version) 20251029 11:52:45.777 INFO : Loading URL: https://abf75oqaaaaaaaamnupkjhgtgagny.ta.pop-vod-dash.main.amazon.pv-cdn.net/dm/3/ww_dub/1968/cc58/daf7/495e-93e6-26c6b904e72e/1abd6186-0c85-412b-9918-0f4fa6768c8a_corrected.mpd?amznDtid=AOAGZA014O5RE&encoding=segmentBase 11:52:46.047 WARN : Response status code does not indicate success: 403 (Forbidden). (1/10)
Code:https://www.primevideo.com/region/eu/detail/0ITZA4TF86MJAR5S8D3HDNXQN7/ref=atv_hm_hom_c_TE8LoN_2_2?jic=8%7CEgRzdm9k
[Release] OpenWV open source Widevine library replacement for web browsers
By ytdlhelp in forum Video Streaming DownloadingReplies: 12Last Post: 7th Nov 2025, 04:17 -
Both Widevine and Playready protection on RaiPlay
By SZplayer in forum Video Streaming DownloadingReplies: 82Last Post: 2nd Aug 2024, 08:43 -
Strip Playready and Widevine DRM
By freaknik in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jun 2024, 16:20 -
Playready keys are Widevine available as well?
By stevepen1974 in forum Video Streaming DownloadingReplies: 9Last Post: 10th Nov 2023, 02:57 -
Can PlayReady be keys be acquired like Widevine?
By besweeet in forum Video Streaming DownloadingReplies: 9Last Post: 11th Jan 2023, 17:16
