    Aug 2023
    Can't get Spotless() to work in Staxrip
    I have downloaded
    * Spotless: https://www.mediafire.com/file/qwngxko60k86850/Spotless_1.07_20220928.zip/file - added to Settings\Plugins\AviSynth
    * MedianBlur2 (which should include MedianBlurTemporal): https://github.com/pinterf/MedianBlur2/releases - added to Apps\Plugins\AVS\MedianBlur2
    But I get "There is no function named MedianBlurTemporal), and points to Spotless v1.07.avsi line 121
    Do I have an incorrect version of any of these, or have I put any of them in the wrong directory?
    Mar 2008
    I dont know if there is a way to add it using the Staxrip interface (I'm looking at version 1.7.0.0) although this suggests there is a way to add items using the Profile:
    https://forum.videohelp.com/threads/373899-Staxrip-QTGMC#post2408341
    Perhaps an easier way is to have Avisynth+ installed and add the dll to the avisynth\plugins64 folder - it will find it automatically
    Aug 2023
    I have Avisynth installed and put MedianBlur2.dll and mvtools2.dll inside, while keeping Spotless inside Settings/Plugins/AviSynth in StaxRip.
    But I still can't see Spotless inside Misc for some reason, even after restarting application?Image
    [Attachment 86501 - Click to enlarge]
    Mar 2008
    You have to add it to the filter profile (right click in the filters area, select profiles)
