Hi all,
after capturing my first VHS, I wanted to deinterlace it with QTGMC, but the result is not appealing. The video stutters and the audio is out of sync.
VHS capture:
I captured the VHS with VirtualDub 1.9.11 in combination with an JVC S9500 and GV-USB2.
Video codec: HuffYUV (fastest)
Audio codec: PCM
The capture worked without any issue. I got 0 frames dropped and around 400 inserted over 40 min.
The AVI file is playing without any issue and the audio is in sync.
QTGMC:
Regarding the deinterlacing process, I used this project package:
https://forum.videohelp.com/threads/405720-FFmpeg-QTGMC-Easy%21
I adjusted the qtgmc.avs like this:
These are the lines I added:HTML Code:SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE) #Define file name filename = "D:\test.avi" #QTGMC portable script #Tested with [url=https://www.videohelp.com/software/Avisynth]Avisynth[/url]+ 3.7.2(r3661) 64 bits and [url=https://www.videohelp.com/software/ffmpeg]FFMPEG[/url] 5.1.2-full_build-www.gyan.dev 2022-09-26 #To know more about AviSynth go to : [url]http://avisynth.nl/[/url] #To know more about FFmpeg go to : [url]https://ffmpeg.org/[/url] LoadPlugin("FFT3DFilter.dll") #FFmpegSource v2.40 plugin : [url]http://avisynth.nl/index.php/FFMS2[/url] #To know more bout loading video files in Avisynth : [url]http://avisynth.nl/index.php/FAQ_loading_clips[/url] LoadPlugin("ffms2.dll") #MaskTools2 v2.2.30 plugin : avisynth.nl/index.php/Masktools2 LoadPlugin("masktools2.dll") #Rgtools v1.2 plugin : [url]http://avisynth.nl/index.php/RgTools[/url] LoadPlugin("Rgtools.dll") #MVTools v2.7.45 with depans v20210608 plugin : [url]http://avisynth.nl/index.php/MVTools[/url] LoadPlugin("mvtools2.dll") #Nnedi3 v0.9.4.60 Plugin : [url]http://avisynth.nl/index.php/Nnedi3[/url] LoadPlugin("nnedi3.dll") #Zs_RF_Shared v1.159 script : [url]http://avisynth.nl/index.php/Zs_RF_Shared[/url] Import("Zs_RF_Shared.avsi") #QTGMC v3.383s script : [url]http://avisynth.nl/index.php/QTGMC[/url] Import("QTGMC.avsi") #Opening of video file (the video file opened here is "in.mp4" and it has NO audio tack, you must replace "in.mp4" by the name of your video file) #FFMpegSource2(filename) #Opening of video file (the video file opened here is "in.mp4" and it as an audio track, you must replace "in.mp4" by the name of your video file) FFMpegSource2(filename,atrack=1) #Converion to YV12 color format: [url]http://avisynth.nl/index.php/ConvertToYV12[/url] ConvertToYV12() #Applying QTGMC in faster mode QTGMC(Preset="Placebo") # Enable MT using 16 cores (logical, not physical)! SetFilterMTMode("QTGMC", 2) Prefetch(15)
- SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
- LoadPlugin("FFT3DFilter.dll")
- SetFilterMTMode("QTGMC", 2)
- Prefetch(15)
FFMPEG:
Finally, I used this FFMPEG command to run QTGMC:
.\ffmpeg -i "D:\QTGMC\qtgmc.avs" -c:v libx264 -preset veryslow -qp 0 -c:a pcm_s16le -aspect 4:3 output.mkv
Samples:
VHS capture: https://drive.google.com/file/d/1aVPHdJ-Z2KkOX8tujAbrNuERr054cymO
QTGMC: https://drive.google.com/file/d/1BRFZgjNWp6EeTykZabnt6pnxum655idN
The final QTGMC video stutters and the audio is out of sync.
What did I do wrong?
				Results 1 to 23 of 23
	That's an issue! The rest comes later...The capture worked without any issue. I got 0 frames dropped and around 400 inserted over 40 min.
	I want to keep it as lossless as possible. Thats why I choose 0 and not any crf value.
 AVI:
 HTML Code:Format/Info : Audio Video Interleave Format settings : PcmWaveformat File size : 505 MiB Duration : 1 min 0 s Overall bit rate : 70.5 Mb/s Frame rate : 25.000 FPS Writing application : Lavf61.1.100 Video ID : 0 Format : [url=https://www.videohelp.com/software/HuffYUV]HuffYUV[/url] Format version : Version 2 Codec ID : HFYU Duration : 1 min 0 s Bit rate : 69.0 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 5:4 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Bits/(Pixel*Frame) : 6.652 Stream size : 494 MiB (98%) Audio ID : 1 Format : PCM Format settings : Little / Signed Codec ID : 1 Duration : 1 min 0 s Bit rate mode : Constant Bit rate : 1 536 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Bit depth : 16 bits Stream size : 11.0 MiB (2%) Alignment : Aligned on interleaves Interleave, duration : 17 ms (0.42 video frame) Interleave, preload duration : 42 ms
 MKV:
 HTML Code:Format : Matroska Format version : Version 4 File size : 538 MiB Duration : 1 min 0 s Overall bit rate : 75.1 Mb/s Frame rate : 49.068 FPS Writing application : Lavf59.27.100 Writing library : Lavf59.27.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High 4:4:4 Predictive@L4 Format settings : CABAC / 16 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 16 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 min 0 s Bit rate : 72.1 Mb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 49.068 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 3.542 Stream size : 516 MiB (96%) Writing library : x264 core 164 r3099 e067ab0 Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0 Default : No Forced : No Audio ID : 2 Format : PCM Format settings : Little / Signed Codec ID : A_PCM/INT/LIT Duration : 1 min 0 s Bit rate mode : Constant Bit rate : 1 536 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Bit depth : 16 bits Stream size : 11.0 MiB (2%) Writing library : Lavc59.37.100 pcm_s16le Default : No Forced : No
 But how can I prevent it? I even see the frame drops when watching the VHS normally. I assume the tape has an issue.
	If the inserted/dropped frames do not depend on external environment but on tape condition, the only hope is to fix a potential time base problem with an external TBC. If there is a physical damage on the tape, there is no solution.
 In the sample you posted there are 28 inserted frames. You can navigate across them opening the file in VirtualDub and using the menu "Go -> Prev drop frame" and "Next drop frame" to check their consistency against what you see when playing the tape.
	crf 0 is lossless for 8 bit videos as well as cq 0. To the last bit  But in any other case you should always prefer crf over cq. CQ is wastes of space. But in any other case you should always prefer crf over cq. CQ is wastes of space.
	Maybe I didn't explain it well enough. I don't have the feeling that the video is stuttering like a game with low FPS.
 When I watch the interlaced video, it gives me a "smooth" feeling and is comfortable to watch.
 But when checking the deinterlaced version, it feels junky, like something would be off.
 For example, when the people are leaving the bus (00:01) or when the guy is holding the blue strings (00:22).
 This happens especially during motion.
 Is it possible that the deinterlacing is putting together the wrong line pairs?
	Did you place AssumeTFF() in your script?Is it possible that the deinterlacing is putting together the wrong line pairs?
	This was the solution. No, AssumeTFF() was not added. Now I added it and it looks fine.
 QTGMC with TFF: https://drive.google.com/file/d/1OqVKAeORIfOaxGEgGps1Mw1hRZFdYjYu
 Not saying that you are wrong, but in my small 1 min test video, there was no difference in file size between cq 0 and crf 0.
 The difference I noticed was between AssumeBFF() and AssumeTFF().
 What do you think about my capture and the final deinterlaced output?
 Any feedback which I could take into account?Last edited by Name; 8th Jan 2025 at 19:24.
	The only problem I still couldn't fix is the audio part.
 The AVI file has the video and audio in sync.
 After deinterlacing, the audio is off.
 Even when I mux the deinterlaced video stream and the AVI audio stream via mkvToolNix, in the end the audio is off again.
 Any idea what I'm missing here?
	Verify the number of frames before and after QTGMC. There should be twice as many after. Check the frame rate before and after. It should be twice as much after. Twice as many frames at twice the frame rate should be exactly the same running time.
	I would like to come back to the dropped frames.
 1) Can I find out what was causing the frame drops? When performing the capture, I can see that the CPU utilization is at around 20 % and at a certain point the preview window starts to stutter, and the dropped frames counter increases. My assumption was it is related to the tape itself.
 2) How is VirtualDub handling dropped frames? At the beginning, I thought dropped frames will the compensated by adding duplicated frames to keep it at constant 25 FPS.
 But when I checked the timing settings, I saw the option to adjust the audio to it. Which I can hear in the capture when I reach the problematic sections. The video stutters and the audio changes the pitch.
 Are my VirtualDub settings fine?
 [Attachment 84715 - Click to enlarge]
	Your VirtualDub settings look ok; you may want to enable "Automatically disable ..." to experiment.
 Dropping frames depends on tape conditions and/or on capturing (hardware/software) conditions.
 The first if fixable only with an external TBC.
 For the second you can test Vdub settings, fine tune your system (disable video preview while capturing, no internet, no antivirus, no processes running in background, capturing to a dedicated disk, etc; i do not even touch the mouse while capturing), explore other software (AmarecTV, VirtualVCR, GraphEdit).
 In your sample you suffered of inserted frames, not dropped frames, which is even more difficult to debug, and which can be related/unrelated to frame drops.
 Sometimes it depends on the tape (I found on one tape exactely the same frame inserted at the same exact timing across 5 different captures), sometime not...
	Disable audio playback in virtualdub while capturing. Also, don't compress audio while capturing.
	Thanks for all the input.
 This sounds interesting. Because I noticed the stutter always at the same spot of the tape when I did some test captures.
 This would already indicate that it is tape related, or not?
 I never worked on the PC while I was capturing, so it would be strange that this issue always appeared at the same spot by chance.
	No, it has the priority
  Best Deinterlacing like QTGMCBy Jay123210599 in forum Newbie / General discussionsReplies: 10Last Post: 4th Dec 2023, 20:40
  QTGMC Deinterlacing PresetsBy Jay123210599 in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2023, 23:26
  QTGMC MKV DeinterlacingBy Jay123210599 in forum Newbie / General discussionsReplies: 6Last Post: 26th Oct 2023, 17:16
  Flickering after deinterlacing with QTGMCBy Sunk in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2023, 12:48
  Is there a GUI just for QTGMC deinterlacing that has a queue?By LaserBones in forum Newbie / General discussionsReplies: 12Last Post: 2nd Jun 2021, 23:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
