I have heard the claim that encoding at CRf values of 17/18 is the way to get the best quality, but is there any actual reasoning behind this ?
Since CRF values start at zero, is there any particular reason 17-18 is when you will get the best file size reduction with no quality loss, or is this just a subjective range that some people think is true.
For x264 no quality loss would be CRF 0 (lossless). Any larger CRF introduces losses. For most people and typical sources CRF 17 .... 20 is a good compromise between compression (file size) and visual quality. It's subjective and source dependent.
Quality and file size depend on other encoder settings as well. -
It depends on the source. It usually blows up the filesize of already compressed sources (DVD, Blu-ray ....) but may reduce the size somewhat of uncompressed sources. Why don't you just try for your sources what you get for various CRF, and find the compromise which suits your personal preference?
And familiarize with the basics of video encoding and compression.
Simply put and assuming all other encoder parameters are the same:
- Lower CRF means less compression = higher file size with lower losses and less compression artifacts
- Higher CRF means more compression = smaller file size with more losses and more compression artifacts
Find your sweet spot. There is no "best".Last edited by Sharc; 10th Nov 2024 at 05:35.
It is usually sufficient for testing to encode selected short snippets only (motion, rich of details, dark scene). You can't predict the filesize though.
If file size matters and you want to encode for a fixed filesize (bitrate) you need to do 2-pass encoding and set the bitrate. For the calculation of the bitrate take a look here:
https://forum.videohelp.com/threads/416495-Particle-outline-after-conversion#post2756854Last edited by Sharc; 10th Nov 2024 at 12:32. Reason: Link added
make video everyday
CRF or CQP?
By gelo333 in forum Newbie / General discussionsReplies: 60Last Post: 31st May 2023, 07:13 -
About the value of CRF!
By Valentin98 in forum Video ConversionReplies: 10Last Post: 24th May 2022, 14:16 -
CRF values?
By Chauceratemyhamster in forum Video ConversionReplies: 18Last Post: 28th Mar 2021, 21:06 -
x265 - CRF and quantizers
By shazzla in forum Video ConversionReplies: 4Last Post: 1st Feb 2021, 13:34 -
CRF Values
By Anakin in forum Video ConversionReplies: 11Last Post: 7th Sep 2020, 18:12
