Results 1 to 30 of 30
    Dec 2023
    England
    Hello all,
    Really struggling with DAZN after hours of trying different things.
    This is the link to the content: https://www.dazn.com/en-GB/sport/Sport:4rheplujt9zryv3fqvtu1jpah/ay2ravvfnnideip39ha6z...2u4l66o3o6sj9f
    Read a number of different threads to work through the problems. Got the kid:key but still getting the forbidden (403) error when running N_m3u8.
    I've tried about twenty different user agents to no avail now. No idea where else to get them, or if that is still the problem.
    Here is my string entered into the terminal:
    N_m3u8DL-RE "https://dcbvoddazn.akamaized.net/176w4exezh5201d5huvjf80tfc/web/stream.mpd?channel=3919&outlet=dazn-row&plang=en" --use-shaka-packager -mt --key cfb5e2b73bef4f3c878f25ab86a7451f:0d6712bf2a84edcc93d001a9613f6fec -M format=mkv:muxer=mkvmerge -sv best -sa best --save-name "Test" --header="User-Agent: Mozilla/5.0 (Web0S; Linux/SmartTV) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.79 Safari/537.36 WebAppManager"
  2. Tried with German vpn.
    add this to the command
    --append-url-params
    your file
    https://gofile.io/d/0W9qcN
    Dec 2023
    England
    --append-url-params
    your file
    Was this using the same user agent I posted above? I tried again with the German VPN and the extra code you mentioned and it still failed.
    Thanks for the file but more interested in what mistakes I have made so I can download more content from them in the future.
    Dec 2023
    England
    Finally got it working after adding the token to the URL. Thanks for the pointers.
  5. had to update ua to a chromecast awhile ago, but now all ua's i've tested fail on me. anyone know what's up now?
    Dec 2024
    Moscow
    Please advise if there is some way to download from DAZN (Canada) ? Issue is User agent ? Or smth else ?
  7. hello all any news about new user agent dazn , i try with adb and http toolkit i found my user agent android ( phone ) i use it but it don't work any help please
  8. I'm interested too...
  9. App Dazn by subscription
  10. And, is it possible to get mpd links from app? I'm talking about live channels. I think user agent isn't the only thing they've changed.
  11. Originally Posted by ddll2 View Post
    yes
    Any guide to do it?
  12. Originally Posted by LV426 View Post
    yes
    Any guide to do it?
    Options are possible
    https://forum.videohelp.com/threads/414381-N_m3u8DL-RE-Not-Able-to-Download-Stream/page2#post2767026
  13. Originally Posted by ddll2 View Post
    yes
    Any guide to do it?
    I see that your last config works perfect.
    But not working with live channels.
  14. Originally Posted by LV426 View Post
    yes
    Any guide to do it?
    I have no problems with living channels
    p.s.
    there is a nuance - I do not use PM, try to ask an open question in this field
    p.s.p.s.
    Only for free living channels
  15. Originally Posted by ddll2 View Post
    yes
    Any guide to do it?
    p.s.
    Ok, sorry for that, as I told you via PM.
    I asked you for the live channels, because the capture you share for: https://dcj-ak-livedazn.akaimazed.net/...
    Doesn't work.
    I think it could be for the expiration date of the token, but two weeks ago, there was no need of any token to play that kind of channels. And that's the reason 'cause I asked you, if you know that there have been any change about it.
    On the other hand, is that a personal token? I mean, do you have to generate it every time you use that sort of channels?
    Thanks!
  16. token lives 24 hours
  17. Originally Posted by ddll2 View Post
    Need active subscription to generate it?
  18. Originally Posted by ddll2 View Post
    no
    Would you explain to us how to get the token?
  19. So DAZN has been playing around with how to get the token. All attempts to get the token are giving me the same token that does not work, when I try to download with N_m3u8DL-RE I get an error:
    WARN : Response status code does not indicate success: 401 (Unauthorized 667). (1/10)
    From what I've been observing the problem comes because when obtaining the token through the license request this request always returns 401.
    As an example of content we have this (content available with free account):
    https://www.dazn.com/es-ES/competition/Competition:1m5x4n07f2kqkiczebja5etiq/9lm9jb9jmnca8vva1g8ik9qqg/c5cotmjpj6d7vikw8binv9bw6
    MPD of the content:
    https://dai.google.com/ondemand/dash/content/2538524/vid/1c0d4ae14d974d7ecd072d99b65b4f73/GRQ/streams/7d652de2-7f0a-4f9e-b079-5c7347d0b504/manifest.mpd
    full cURL of the license application (where I think the problem is):
    curl 'https://drm.playback.indazn.com/widevine/v1/license?legacyContentId=prod-live1&contentId=1lhjks6usbzzy1qatwuulzdgzw&platform=web&manufacturer=microsoft&model=unknown&appVersion=0.70.2&uid=b266b829-0d50-484a-a363-4ef6d6c62dd0&accountStatus=Partial&assetId=c5cotmjpj6d7vikw8binv9bw6&aexp=1775087999000&tid=08c57257-6c98-4fd6-b68e-76c390f6556c&uexp=1744449090174&mediaType=vod&mediaId=1lhjks6usbzzy1qatwuulzdgzw&metadata=country%3Des%26ftv%3Dtrue&hash=15f13fcd48b5d37b974093792e46334fd93e1feda27efc1b9b2bc3a761ae37af' -X POST -H 'User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:137.0) Gecko/20100101 Firefox/137.0' -H 'Accept: */*' -H 'Accept-Language: en-US,en;q=0.5' -H 'Accept-Encoding: gzip, deflate, br, zstd' -H 'authorization: Bearer ....' -H 'Content-Type: application/octet-stream' -H 'x-correlation-id: adfd422e-52cf-4cdc-a33a-404b69dffc49' -H 'Origin: https://www.dazn.com' -H 'Connection: keep-alive' -H 'Referer: https://www.dazn.com/' -H 'Sec-Fetch-Dest: empty' -H 'Sec-Fetch-Mode: cors' -H 'Sec-Fetch-Site: cross-site' -H 'Pragma: no-cache' -H 'Cache-Control: no-cache' -H 'TE: trailers' --data-raw $'\x08\x04'
    No matter what I do, I always get this key:
    Request used in N_m3u8DL-RE to download the stream:
    N_m3u8DL-RE -M format=mkv --append-url-params "https://dai.google.com/ondemand/dash/content/2538524/vid/1c0d4ae14d974d7ecd072d99b65b4f73/GRQ/streams/7d652de2-7f0a-4f9e-b079-5c7347d0b504/manifest.mpd" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:137.0) Gecko/20100101 Firefox/137.0" -H "Accept: */*" -H "Origin: https://www.dazn.com" -H "Referer: https://www.dazn.com/" --key cfb5e2b73bef4f3c878f25ab86a7451f:0d6712bf2a84edcc93d001a9613f6fec
    And as I said N_m3u8DL-RE detects the video and audio streams correctly but at the moment of starting the download it fails with a 401. It is not a problem of the header, I have tried several combinations that worked and the result is always the same.
    Any idea what might be going on and how to fix it? Assistance is appreciated!
  20. I'm trying to watch in Ottnavigator this free channel for Dazn (need only registration, not a payd channel)
    #EXTINF:-1 ,Radio Tv serie A
    #KODIPROP:inputstream.adaptive.license_type=clearkey
    #EXTVLCOPT:http-user-agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36 Edg/135.0.0.0
    #KODIPROP:inputstream.adaptive.license_key=2689e6467c335599b85ddf05973ab259:f1c10278c1f7876822fc1796fe142511
    https://dcs-ak-livedazn.akamaized.net/dash/dazn-linear-223/stream.mpd?p=web
    but i get error 401. I think is a user agent problem, someone can help me?
  21. Originally Posted by roveciw933 View Post
    When you have url's with "akamaized" you need to generate token to watch the channel. But no one tells the way to get it. There isn't any public info about it.
  22. Originally Posted by LV426 View Post
    I know how to find token and use it with "akamaized" and OttNavigator, but it expires in 24h, it's boring.
    I know also a not tokenized cdn, it works until 3 weeks ago with an user agent, problem i'm not able to find a new working user agent.
  23. So get Dazn token without active subscription it's real o it's a legend?
    I asked about this in many forums, nobody answered.
    Maybe is top secret
  24. Originally Posted by roveciw933 View Post
    Help me fix this stream to watch it in premium ott please!:
    N_m3u8DL-RE "https://dcs-ak-livedazn.akamaized.net/dash/dazn-linear-206/stream.mpd?p=web&dazn-token=st%3D1760365758~exp%3D1760452158~acl%3D%2F*~ id%3D267a654e5c29~data%3Dcountry%3Dit%23asn%3D2102 18%2C198471%2C206150%23path%3D1s%2C2d%23hashp%3D71 46d3dea70044f8d191494cbaf9b170539059551a801458f7e9 193ddef7835d%23hashua%3D8d3a4310782ed11654708481a9 71289b2b41320c78fe2ca10c0be5d9c3af9b5b~hmac%3D5d7b d6209d18da11167ca1a5bb9f7f4da4cf1ab6fe7131f024ae3f 29b022de8d" -H "Accept: */*" -H "Origin: https://www.dazn.com" -H "Referer: https://www.dazn.com/" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/141.0.0.0 Safari/537.36" --key 6164a0abaa7c53c6875fa1e7fe0bb463:271510d3e1259571d cc568a232e397eb --decryption-engine SHAKA_PACKAGER -M format=mp4:muxer=ffmpeg -sv best --save-name "DAZN | TV Live | DAZN 1"
  25. Originally Posted by roveciw933 View Post
    Did you find anything about tokens?
    Talking about not tokenized cdn, do you have any url? Have you try browser inspect tools with that kind of url?
  26. Originally Posted by ddll2 View Post
    yes
    Any guide to do it?
    p.s.
    p.s.p.s.
    Dazn seems to have fixed the bug that allowed events to be viewed without a token, like this example, last week: https://dca-co-live-gcr.gcdn.co/1u8xl7gkcmotq1ka2tu0619cfg/web/stream.mpd?outlet=dazn-row
    Does anyone have a new solution?
