Hello,
solved my issues with Mediaset but I don't understand how to find the key from Raiplay
I have these episodes.
Please help me with the keys - the expire in 6 days.
I'm able to find the mpd file link and if I add 5000 after 2400 I can download in 1080 resolution.Code:Leoni di sicilia: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E1-6e605604-d0ce-418a-8f67-eafc10bd0994.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E2-c1b6139f-2d46-4e95-8705-6dbab0f48425.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E3-6dc4c0f4-5951-444c-bdf4-d6b64a07606e.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E4-d0c06dbe-8bc4-4d05-beeb-de527d83de63.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E5-bed548e8-6ecf-4ce4-a83d-30cfb277bb3a.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E6-6df3d30a-ab95-4dae-9c8d-dd75a3d73a89.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E7-b0f15e77-2aec-43a7-93d1-26bac4cf4e97.html https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E8-58097cb5-3a94-4904-a5d7-5d01b2891cc8.html
I can also find inside the mpd file the <cencssh> code
As in Mediaset I have to copy the url when I search in the console lic or getRawWidevine, what do I have to search in Raiplay?
I red something like wv bu what do I have to do with it?
To copy the url path, to double click it or what else?
I red also for some header and that I have to be very fast to paste it into the site that provides the key, but I don't understand nothing more and I didn't find the step by step explain.
Please help me you to learn it and to be able in the future to do all by myself.
As always thanks in advance for your help.
PS - I guess I have to paste these parts (in the screen I'm trying to find the code of episode 5:
Is right what I suppose?
[Attachment 82605 - Click to enlarge]
Results 1 to 25 of 25
Install Widevine L3 GuessorCode:
e22943e1f8b631d2bd50cfcd7e62a3a5:d709a1b51bbdc704a45c4db3ddf58738 7184f5509c3c3ad2b8d35b314323b0e9:5bc37cfeb8d9ec4b72c4c4ec39a07cec 6fe9e5ae057e38fabd033b168e5f201f:2fadf9729989ba0870fbf43f75016a04 08edb88912c53bc38bd8c64976c6dd8e:d39fa288d0818eff47b895c7cd2ab853 40158c1ff4cb3a0f80281357746e73c4:15c3bdf9091e62908d6f14559e02d862 6c90377bcb0236929899b2527e64f0f2:edfb65f54aaebb2822e7d4e7926d305d 3293ba98cee73c63a2640b3330fb1805:3753a2d2b995126af885d985d6e61735 29065877d7ff35b19f4c892fe2d88d28:37e2e590277072c5ac2bafe57b5782ae
https://forum.videohelp.com/threads/414140-%5BRelease%5D-Widevine-L3-Guesser-Extension...-Chrome-All-OS
[Attachment 82606 - Click to enlarge] -
Thank you very much for your replay.
I'm not able to install the extenstion.
I downloaded the code as zip and I wet to firefox to install the addon as it was described in github
I click on load but I don't see the zip fileFirefox
1. Navigate to about:debugging#/runtime/this-firefox
2. Load temporary addon
There's also written:
And there is a guide how to do it but I don't understand it at allAt the same directory of manifest.json(root directory of this extension), put the one of the following Android L3 CDM key pair file(s).
And at he end, if I try to download and encrypt the videos they download but don't encrypt.
The command I used is the same I use for Mediaset. The example is for the episode 5:
orCode:N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266718_,1200,1800,2400,5000/manifest_mvnumber.mpd?hdnea=st=1727882151~exp=1727882301~acl=/*~hmac=4ba3810c35446213d60de9e5d08bcc9496bd079a052d40b34a8d1f02496781fc" --key 40158c1ff4cb3a0f80281357746e73c4:15c3bdf9091e62908d6f14559e02d862 -M format=mp4 --use-shaka-packager --save-name 05_I_leoni_di_Sicilia
Edit:Code:N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266718_,1200,1800,2400,5000/manifest_mvnumber.mpd?hdnea=st=1727882151~exp=1727882301~acl=/*~hmac=4ba3810c35446213d60de9e5d08bcc9496bd079a052d40b34a8d1f02496781fc" --key 40158c1ff4cb3a0f80281357746e73c4:15c3bdf9091e62908d6f14559e02d862 -M format=mp4 --save-name 05_I_leoni_di_Sicilia
I loaded the temporary addon choosing the file manifest.json but when the raiplay video is plaing I open the add-on and there is an error:
[Attachment 82608 - Click to enlarge]Last edited by alba77; 2nd Oct 2024 at 11:40.
@cedric8528,
can you please give me the command to download and decrypt the episodes.
Thanks -
It doesn't work like that, you can't decrypt 1080p videos without the key and you can't obtain the key without properly fetching the manifest.
Here are you keys and download commands for the best resolution available :
Code:url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E1-6e605604-d0ce-418a-8f67-eafc10bd0994.html name: I.leoni.di.Sicilia.S1E1 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24157755_,1200,1800,2400/manifest_mvnumber.mpd?hdnea=st=1727890122~exp=1727890272~acl=/*~hmac=b22a14e3bca2ecbd10e767f8b47cd1a4348d106a57c7e11e33d35f5b38c887c1 pssh: AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQ4ilD4fi2MdK9UM/NfmKjpRoFTmFncmEiPGRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MTU3NzU1XywxMjAwLDE4MDAsMjQwMA== keys: ['e22943e1f8b631d2bd50cfcd7e62a3a5:d709a1b51bbdc704a45c4db3ddf58738'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24157755_,1200,1800,2400/manifest_mvnumber.mpd?hdnea=st=1727890122~exp=1727890272~acl=/*~hmac=b22a14e3bca2ecbd10e767f8b47cd1a4348d106a57c7e11e33d35f5b38c887c1" --save-name "I.leoni.di.Sicilia.S1E1" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key e22943e1f8b631d2bd50cfcd7e62a3a5:d709a1b51bbdc704a45c4db3ddf58738 -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E2-c1b6139f-2d46-4e95-8705-6dbab0f48425.html name: I.leoni.di.Sicilia.S1E2 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24167955_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890127~exp=1727890277~acl=/*~hmac=3676c8c5122d6f0db6a4905400439cc52d698c1084813b651616cb8a831806de pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQkvgkZTy2P364YUTP/mbZZRoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MTY3OTU1XywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['92f824653cb63f7eb86144cffe66d965:85f3109d266f5a0a2ccccdd18ed897f9'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24167955_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890127~exp=1727890277~acl=/*~hmac=3676c8c5122d6f0db6a4905400439cc52d698c1084813b651616cb8a831806de" --save-name "I.leoni.di.Sicilia.S1E2" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 92f824653cb63f7eb86144cffe66d965:85f3109d266f5a0a2ccccdd18ed897f9 -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E3-6dc4c0f4-5951-444c-bdf4-d6b64a07606e.html name: I.leoni.di.Sicilia.S1E3 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24210825_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890132~exp=1727890282~acl=/*~hmac=2fe6b719e3643b9cfb60d43cbe16254c515d90400505d7a10e03bf8e465d5057 pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQZO2eEoTOPQqTYZqy75xygRoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MjEwODI1XywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['64ed9e1284ce3d0a93619ab2ef9c7281:b356611808464a245da0b41d39fc072e'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24210825_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890132~exp=1727890282~acl=/*~hmac=2fe6b719e3643b9cfb60d43cbe16254c515d90400505d7a10e03bf8e465d5057" --save-name "I.leoni.di.Sicilia.S1E3" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 64ed9e1284ce3d0a93619ab2ef9c7281:b356611808464a245da0b41d39fc072e -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E4-d0c06dbe-8bc4-4d05-beeb-de527d83de63.html name: I.leoni.di.Sicilia.S1E4 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24210794_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890138~exp=1727890288~acl=/*~hmac=1923e956abae42f85e5ff44a2de78bbf26d97f8ae958a64f5ac8655607b2b2ab pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQcHgZlricOR+bZGDY7c3z3hoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MjEwNzk0XywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['70781996b89c391f9b6460d8edcdf3de:34dd49c88972fedaaa3c88fa7f3981a7'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24210794_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890138~exp=1727890288~acl=/*~hmac=1923e956abae42f85e5ff44a2de78bbf26d97f8ae958a64f5ac8655607b2b2ab" --save-name "I.leoni.di.Sicilia.S1E4" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 70781996b89c391f9b6460d8edcdf3de:34dd49c88972fedaaa3c88fa7f3981a7 -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E5-bed548e8-6ecf-4ce4-a83d-30cfb277bb3a.html name: I.leoni.di.Sicilia.S1E5 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266718_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890144~exp=1727890294~acl=/*~hmac=9c629f30c7a96c1fd28357ac94a46a976be13a8ad94557e782a0e92f7b120185 pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQ5agbfEMHMlm6k8+QX9RZ3BoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MjY2NzE4XywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['e5a81b7c43073259ba93cf905fd459dc:4e88b7138beed331392c1cd8f87d35fb'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr1/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266718_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890144~exp=1727890294~acl=/*~hmac=9c629f30c7a96c1fd28357ac94a46a976be13a8ad94557e782a0e92f7b120185" --save-name "I.leoni.di.Sicilia.S1E5" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key e5a81b7c43073259ba93cf905fd459dc:4e88b7138beed331392c1cd8f87d35fb -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E6-6df3d30a-ab95-4dae-9c8d-dd75a3d73a89.html name: I.leoni.di.Sicilia.S1E6 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266642_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890149~exp=1727890299~acl=/*~hmac=2ef88226d38642568f004b12882a1b8b472bd7b75d6ce99bba118ee4371e0c5d pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQROW8DoTxNnivc+5/sMVKEBoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MjY2NjQyXywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['44e5bc0e84f13678af73ee7fb0c54a10:51b57748d8ce87aae59acb751196dc94'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24266642_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890149~exp=1727890299~acl=/*~hmac=2ef88226d38642568f004b12882a1b8b472bd7b75d6ce99bba118ee4371e0c5d" --save-name "I.leoni.di.Sicilia.S1E6" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 44e5bc0e84f13678af73ee7fb0c54a10:51b57748d8ce87aae59acb751196dc94 -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E7-b0f15e77-2aec-43a7-93d1-26bac4cf4e97.html name: I.leoni.di.Sicilia.S1E7 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24320081_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890153~exp=1727890303~acl=/*~hmac=b6e95f753f6b755c5bad9523c5b820616d14f4003dcfdaccf9b2f69bb8a409dd pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQYJewoVyONo2HLsBk/pgI6xoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MzIwMDgxXywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['6097b0a15c8e368d872ec064fe9808eb:d016a98a5a97116aea2874ca121f86a5'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24320081_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890153~exp=1727890303~acl=/*~hmac=b6e95f753f6b755c5bad9523c5b820616d14f4003dcfdaccf9b2f69bb8a409dd" --save-name "I.leoni.di.Sicilia.S1E7" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 6097b0a15c8e368d872ec064fe9808eb:d016a98a5a97116aea2874ca121f86a5 -------------------------------------------------- url: https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E8-58097cb5-3a94-4904-a5d7-5d01b2891cc8.html name: I.leoni.di.Sicilia.S1E8 content_url: https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24320112_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890158~exp=1727890308~acl=/*~hmac=f4a3615cb0ef61de0d96ba33e1427a99b172312e93dccef3e9c25915b7bad2f1 pssh: AAAAg3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAGMIARIQmLI/6mhOOgOQtnAsRrGseBoFTmFncmEiRmRybV9yb290L0RSTU5hZ3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MzIwMTEyXywxMjAwLDE4MDAsMjQwMCwzNjAwLDUwMDA= keys: ['98b23fea684e3a0390b6702c46b1ac78:ca31117f74c9896990ccc37ae6a06945'] N_m3u8DL-RE "https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24320112_,1200,1800,2400,3600,5000/manifest_mvnumber.mpd?hdnea=st=1727890158~exp=1727890308~acl=/*~hmac=f4a3615cb0ef61de0d96ba33e1427a99b172312e93dccef3e9c25915b7bad2f1" --save-name "I.leoni.di.Sicilia.S1E8" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 98b23fea684e3a0390b6702c46b1ac78:ca31117f74c9896990ccc37ae6a06945
Thank you very much. I'm grateful for the commands and the codes you gave me.
Strangely on my windows 11 pc it doesn't decrypt if I don't add " --use-shaka-packager" but in a Windows 10 I don't need to add it.
In any case I didn't understand this:
What the manifest is?you can't obtain the key without properly fetching the manifest -
Widevine L3 Guessor for raiplay only helps you up to 720p and the keys for 1080p are different, raiplay displays by choice up to 720p, to get 1080p you have to force it if you only add the 5000 to the playlist you only get the video but not the relevant nv-authorization to get the key
Thanks for the replay.
I see @aqzs in the 1st video gave me the code up to 2400 but from the 2ond to the 8ght he gave me the cose and the key for the 5000 (1080p)
So it was possible in some way
I see also for the 1st episode there is the 5000
Mediaset is much easier than Raiplay RDM. For RAI not RDM I use Stacher.
In any case I wasn't able to configure L3 Guessor.
What exactly do I have to copy and paste to?Code:https://keysdb.net/ or https://cdrm-project.com/
WAW - how lucky I'm. You're the guy from the italian blog about RaiPlay where I asked to you to give me the help writing me by email. I connected in few time that the nick is the same. And my is the same too.Last edited by alba77; 2nd Oct 2024 at 13:32.
I believe we spoke on Lazza's Italian raiplay stacher page, you need PSHH, license and nv-authorizations but nv-authorizations lasts only 10 seconds you have to refresh the page quickly and copy the value starting with ey... etc.
or use this in python
Code:from pywidevine.cdm import Cdm from pywidevine.device import Device from pywidevine.pssh import PSSH import requests # prepare pssh pssh = PSSH("PSSH") # load device device = Device.load("C:\Device.wvd") # load cdm cdm = Cdm.from_device(device) # open cdm session session_id = cdm.open() # get license challenge challenge = cdm.get_license_challenge(session_id, pssh) # send license challenge (assuming a generic license server SDK with no API front) licence = requests.post("https://...", data=challenge, headers={"Nv-Authorizations": "link"} licence.raise_for_status() # parse license challenge cdm.parse_license(session_id, licence.content) # print keys for key in cdm.get_keys(session_id): print(f"[{key.type}] {key.kid.hex}:{key.key.hex()}") # close session, disposes of session data cdm.close(session_id)Last edited by Goku73; 2nd Oct 2024 at 13:45.
Exactly. I asked you there because I wasn't able to find the replay of my question and so for this reason I opened a new thread here.
I find easily the PSHH in the mpd code and paste it to the website where I'm going to get the key,
After I search wv, right?
Do I have to riglt click over it and copy the URL (like I do for Mediaset)?
Where do I find the string with ey... ecc.?
Is it in this screen?
My Python path is C:\Users\user\AppData\Local\Programs\Python\Python 312
Do I have to run the python.exe file?
In your code what do I have to replace with the string of the video I need to download?
I see this line "licence = requests.post("https://...", data=challenge, " what do I have to punt instead of https://...?Last edited by alba77; 2nd Oct 2024 at 13:54.
no, like this, you also have to write nv-authorizations: then a space and then ey... although in the new site I don't know if it works maybe you also need to put the inverted commas "
if you write to me in private I'll explain how to get 1080pLast edited by Goku73; 2nd Oct 2024 at 14:02.
I have contacted you privately, I will explain everything better
Goku could you write to me privately, I tried but I couldn't, it's not trivial. Please.
Through my systems I think that what I put below is at most in 720p but I wanted to be sure. https://www.raiplay.it/video/2023/01/La-bella-stagione-34376cdc-49fd-4b6d-914f-3746df502f64.html -
I found in developer tools network fetch/xhr https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/dom2/Italy/podcastcdn/raitre/Gli_sp...uyGq&aifp=V001
https://streamcdng8-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/dom2/Italy/podcastcdn/r...uyGq&aifp=V001
https://streamcdng8-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/dom2/Italy/podcastcdn/r...-f2-v1-a1.m3u8
is correct add 5000, after 2400, ?
I also found https://creativemedia4-rai-it.akamaized.net/Italy/podcastcdn/raitre/Gli_speciali_di_Ra...52540_2400.mp4
https://creativemedia3-rai-it.akamaized.net/Italy/podcastcdn/raitre/Gli_speciali_di_Ra...52540_1800.mp4
with the extension Rai Play video download , script for tampermonkey (https://greasyfork.org/it/scripts/2128-rai-play-video-download) -
Maximum up to 2400:
I have contacted you privatelyCode:https://b70cb04c54ab478189e9d8ee45637b13.msvdn.net/dom2/Italy/podcastcdn/raitre/Gli_speciali_di_Raitre/Documentari_RaiTre_EP_Puntate/18852540_,1800,2400,.mp4.csmil/playlist.m3u8?auth=daEcAbFancadVbca6aNaHaWaOdMdUdIaTd2-bNc3MR-c0-GksuuGn&aifp=V001
Hi fellow friends!
This is my first post here even though I've been following this and many other threads since at least 10 years
My question is pretty simple and I'm sure it's been somehow already addressed: is there any way I can get the .mpd link and the nv-authorizations token of a raiplay link from outside Italy without resorting to VPN? Just to be clear, it's not that I don't want to spend money for a VPN, the problem is that nowadays almost none of them works!
Thanks! -
your request makes no sense: to get auth token you need to play the video (or better need the right lic request to the server). RaiPlay work with italian IP so if you are out of the IT country you will obviously have a different IP. so need VPN
the best VPN are Nord, Express and windscribe and with these you're on safe side. just you are near to IT like France, swiss, or Germany maybe you can play (or get token) without VPN. test it -
Thanks for the answer, which makes fully sense. Perhaps I should have phrased more directly: is it possible to bypass the geo-locking without VPN?
The thing is, the content itself is not geo-locked (the mpd link, provided you can get it
, opens without problems from anywhere) and you only need the token for few seconds :P
By the way, is the token the only way to get a widevine key? -
You must have permission to start the video, you can easily take link and key with this extension:
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
To take 1080p just force the User Agent by replacing it with TV or RAI in uppercase as long as 1080p resolution exists for that video
for example:
Follow the screen steps, 1, 2 and 3 then refresh the page and you will have 1080p, then at your discretion take everything manually or with the suggested extension i.e. widevineproxy2 -
yes agree. but for play video or get auth still need ita IP
without this IP you cant send request to the server so nothing data. that's all.
ask here for mpd, full command or token only. share video link only. a lot of guys here can help you -
you can try Hola Vpn Addon for Chrome which works with Raiplay.
And WidevineProxy2 to get the key and command to download.
[Attachment 87296 - Click to enlarge] -
Hi @goku73 could you please contact me about the raiplay download? Thank you so much!
Raiplay: find a way to get the key above 2400 bitrate
By lucacolaiacomo in forum Video Streaming DownloadingReplies: 2Last Post: 28th Mar 2025, 07:57 -
Help for Downloading from raiplay
By kintaor in forum Video Streaming DownloadingReplies: 4Last Post: 8th Jul 2024, 11:32 -
Help for downloading from RaiPlay
By kintaor in forum Video Streaming DownloadingReplies: 3Last Post: 25th Jun 2024, 08:56 -
Help with (cached) key RaiPlay
By misiek1963 in forum Video Streaming DownloadingReplies: 3Last Post: 6th Jun 2024, 12:16 -
Need Help for Finding the KEY from MPD
By juan in forum Video Streaming DownloadingReplies: 2Last Post: 22nd May 2024, 10:06
ssh> code
